Ryan's 1974 M2
  • PeteD
    • 982
    #76
    Wow! Great read so far.
    • 2mAn
      Señior Mod
      • 21017
      #77
      ugh that looks so damn good. this isnt helping the evil thoughts in my head
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • iflytii
        • Jun 2004
        • 482
        #78
        Awesome project! Keep up the good work!
        • econti
          • May 2014
          • 1151
          #79
          That really isn't a lot of tyre you're able to fit under the front
          • RCM3
            • Aug 2011
            • 1304
            #80
            I wanted to run a little more than a 195, but tire sizes available in 16 inches makes that tough. There weren't many other options to keep outer diameter constant if I wanted to run the 215s in the back. I will say that these tires appear to run a little wide, my 215 rears on the Alpinas are wider than my 225 Bridgestones on my set of Euroweaves. They should be more than adequate for the cars purpose for now though.
            -Ryan
            05/87 Henna M3
            04/71 Baikal 2002tii
            • ck_taft325is
              • Sep 2007
              • 6880
              #81
              Updates sir?
              Need a part? PM me.
              • JRKOUPE
                • Dec 2004
                • 3159
                #82
                looking good......
                the bronze was a good choice.
                Im thinking same for my e30 track car, which is red.
                Did you paint or PC?......
                I keep on reading PC ing track wheels has lead many to failure....hmmmm
                • RCM3
                  • Aug 2011
                  • 1304
                  #83
                  Originally posted by ck_taft325is
                  Updates sir?
                  No updates just yet. I managed to get another week off so ill put some more time in and hopefully have the s14 running by the end of the week.
                  Originally posted by JRKOUPE
                  looking good......
                  Thanks, I'm glad last minute I went with the bronze also. I had them painted, and I've had good results with painted wheels over the last 3 years.
                  I really enjoy bronze on red, ran that combo on my last E30!
                  -Ryan
                  05/87 Henna M3
                  • RCM3
                    • Aug 2011
                    • 1304
                    #84
                    Another long day of work completed. It started out with a couple deliveries. One from Mr. Danco, a pair of E21 half shafts. The other from IE, the new 5 speed driveshaft.
                    Thought this was interesting:
                    Despite being handled poorly in delivery everything looked fine.
                    My brother and I spent some time on his E30 convertible today^. Tranny flush, 750iL master cylinder, louder exhaust. Then we got to work on the 2002...
                    Test fit of the 5 speed transmission to mock up the new Massive rear mounts and marked the spot on the tunnel that needs to be massaged a bit for the slave cylinder. Not the best pic but it was getting late. At first the 5 speed transmission was not sitting straight in the tunnel. It was tweaked toward the driver side about 1/2 inch. To remedy this we supported the front of the engine to take the weight off the engine mounts. I had to remove the driver side engine mount and bushing and get it into the vice. I slotted the hole in the engine mount arm where the bushing bolts travels through and also placed a washer between the engine block and the engine mount to space it a tiny bit. This allowed me to adjust the trans dead center in the tunnel. Once it was lined up I tightened the engine mounts back down and now the S14 and trans sit perfectly in line. :)
                    With the transmission supported, I could finally test fit the IE radiator. Clearance between the water pump pulley mounting bolts and the radiator is slim. With some massaging of the radiator support, and some thinner hex key bolts to replace the standard 10mm pulley bolts, I achieved the needed space between pulley and radiator.
                    Finally, I spent some time mocking up the Aardvark Racing 5 speed shifter plate. I'm using the UUC EVO III shifter with early model E30 shifter hardware. I did have to modify the support arm that supports the shifter plate and connects to the transmission. Once modified, I pressed in the IE solid bushing. It'll all be painted up tomorrow now that I know it clears and installs without issue.
                    Tomorrow I will be installing the 5 speed Massive transmission mounts, shortening the transmission crossmember a bit to fit the new mounts, and then test fitting the drive line. Next Ill tackle the pedal box rebuild and the brake booster hardware rebuild with the kits IE offers.
                    On a side note, I pulled the carpet yesterday and was surprised to see how much sound deadening material there is underneath. I must have removed 20 lbs from the passenger side alone. Once it's all removed from all floor pans and the tunnel, Ill likely add some sort of floor cover back to the passenger front floor board. With that header running underneath, and then the remainder of the exhaust traveling beneath that floorboard, I just want some heat shielding for the new carpet and passengers feet. Looking into a firewall heat shield also to further help heat blockage.
                    -Ryan
                    05/87 Henna M3
                    • CorvallisBMW
                      Long Schlong Longhammer
                      • 13039
                      #85
                      Looking good! :)
                      • RCM3
                        • Aug 2011
                        • 1304
                        #86
                        Tedious things today. Stripped down and cleaned the pedal box and all bits associated with it. Here's where I started:
                        I primed and painted anything metal that was to be reused. The clutch and brake pedals, pedal box itself, brake booster mounting plates, and the booster pivot arm. While those dried I measured, re measured, measured once more and drilled the holes for the 5 speed Massive mounts. Per discussion in Marshall's M2 build on the FAQ, I made sure to grab large washers for the new bolts that secure the mounts. Avoids vibrations through the power train eventually pulling the small bolt heads through the thin sheet metal in the trans tunnel, especially since I have those solid bushings.
                        Back to the pedal box. Followed IEs exploded views of the parts to rebuild the unit. Old plastic sleeves are replace with their kit in favor for small bearings and aluminum spacers. Much nicer! It all went together without surprises. Ill take a few pieces off to install the box tomorrow and reassemble once again onto the car.
                        Tomorrows agenda. Finish the wiring on this guy finally.
                        -Ryan
                        05/87 Henna M3
                        • pietro
                          • Sep 2014
                          • 56
                          #87
                          So nice! Looks super clean… definitely sub'd
                          • deutschman
                            • May 2008
                            • 5958
                            #88
                            I dont know why but I actually enjoyed rebuilding the pedal box on my last 02. Maybe Im weird hahaha
                            Good work!
                            • aintnothang
                              • 743
                              #89
                              I remember see that red vert up in Placerville a few weeks ago.
                              • RCM3
                                • Aug 2011
                                • 1304
                                #90
                                The last few days have been dedicated to E30s and my E39. The 540i needed a big maintenance overhaul. Vacuum leaks had been killing performance and triggering the CEL so I made some time to get all that sorted.
                                A follow up shot of my bros E30. He's seriously beginning to hunt for a nice 2002, considering trading the vert in for an M20 powered square tail. My project in the background.
                                Back to the M2 updates.
                                The day started with some fabrication of the throttle cable brackets needed for the S14. I had a template for both brackets and I followed those specs to create them. Looking around the scrap pile, I found the old 2002 AC radiator brackets and got to work. A few cuts, some drilling, filing, then painting I had the brackets finished. My swap guide says to use a 1975-79 Civic CVCC throttle cable to complete the throttle linkage set up, I haven't made that purchase just yet however.
                                Then I swapped in the new, updated timing chain tensioner. It's an E36 M3 tensioner that works very well in the S14 to provide more consistent chain pressure and to help out on cold starts. Fairly simple job with a deep 32mm socket.
                                Mounted up the E30 battery terminal box on the fire wall for the positive lead. I think ill need to grab another section of E30 battery wiring, in about 1 foot short. Ill grab some at the junk yard later.
                                Finally I dug out the Ground Control invoice with the rates and lengths of my springs.
                                Fronts: 7" x 2.5" 350lb
                                Rears: 8" x 5" 400lb
                                Didn't have a clutch centering tool and the pilot bearing remover on hand so ill get to final assembly of the transmission once I have a few more tools in front of me.
                                I thought this was amusing also, hopefully this fortune comes true!
                                -Ryan
                                05/87 Henna M3
