Classic Daily E30 325iX S54 Swap
    • 34844
    #91
    Not with the engine rotated like that.
    • F34R
      sLaughter
      • 12376
      #92
      Looking so good! and lol at an ix being easier than a RWD e30.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • alloydix
        • 106
        #93
        Originally posted by nando
        cheapest is definitely the frankenpan route using all E30 ix parts. the drawbacks are too significant for me to ignore, though.
        You mentioned this in the 24v swap knowledge base thread. Sorry if these drawbacks to having the motor at the m20 angle have been listed clearly in another thread, but I'm wondering what they are?
        I understand sticking to e30 ix parts means being stuck with a weak front diff, but from what I've gathered it seems that most agree it handles 300hp fine, as long as you aren't pushing a whole lot of torque. It also means having to do a custom brake setup, but isn't it possible to make a boosterless brake setup better than stock for not a lot of extra cash?
        • kid325e
          • Sep 2007
          • 6422
          #94
          Jake, this thing on the road yet? Knowing how quick you blow through these projects i'm guessing yes?
          Excited to see if this thing is rolling!
          I emailed you a week or two ago, wasn't sure if you got it? PM me!
          clutchCTRL!
          Move with a purpose.
          - 1991 325iX 4dr/5spd
          - 2000 323i AT
          2016 Mazda CX3 Sport AWD
          • jakeb
            • 1909
            #95
            nope not done yet. Moving along tho. Getting interior work done as well. Just found your email, sorry about missing it. Replied.
            www.classicdaily.net
            1970 m42 swapped 2002
            1985 LS1/T56 Swapped e28 (557e)
            www.blunttech.com - For all your parts needs
            Follow me on Instagram for constant build updates @classicdaily
            https://www.facebook.com/ClassicDailyLLC
            • MyE30
              • Sep 2013
              • 326
              #96
              This great stuff.
              jakeb, I'm not familiar with what the inside of an ix oil pan looks like. Considering the s54 oil pan windage tray design, does your frankenpan provide appropriate oil windage?
              • jakeb
                • 1909
                #97
                Should keep this thread updated as the project is moving along.
                This car is also getting some interior upgrades.
                First going from tan to black.
                Dyeing the carpet....1st step is to clean it a ton
                Then start spraying on some dye.
                fresh dash as well
                Seats getting heat added.
                Black vert sports
                Due to the plenum we needed to remove the booster. So we are going to increased leverage from the brake pedal and also a smaller master cylinder 19mm/19mm
                I started with the massive booster delete but it didn't work. So I had something similar made at the water jet...twice. Things are fitting now.
                The progression...
                The master is just for mock up.
                Exhaust...
                • rzerob
                  • Jun 2013
                  • 2315
                  #98
                  I look forward to reading updates on this build. That exhaust is awesome. The muffler looks short in the pics are you adding long tips?
                  • blunttech
                    • 12850
                    #99
                    I was just out there Monday/Tuesday and saw this. Looks really nice
                    sales@blunttech.com
                    www.blunttech.com
                    Like us on Facebook
                    • E30NJ
                      • Aug 2013
                      • 921
                      #100
                      Nice work! Keep the photos coming.
                      • litu
                        • 848
                        #101
                        Awesome work, keep those pics coming :)
                        https://www.facebook.com/Cry_77_IX-110483784967661
                        https://www.instagram.com/cry_77_ix/
                          • 37833
                          #102
                          Looking good!
                          Grover Beach, California
                          BimmerHeads.com
                          • jakeb
                            • 1909
                            #103
                            Yes there will be tips. It is maybe 8" from the exit
                            • nouseforaname
                              • Jul 2009
                              • 322
                              #104
                              What dye did you use on the carpet?
                              Great thread. Awesome work.
                              • jakeb
                                • 1909
                                #105
                                Using two e46 heater hoses
                                Joining AC lines - high side
                                low side
                                installed
                                Stock oil cooler lines welded to AN 10 fittings.
                                Coming off the engine
                                Getting closer
                                Will use an e28 m5 coolant tank
                                [img]https://lh3.googleusercontent.com/-kUOxpP7OVCg/VF14HEQt7RI/AAAAAAAAQSA/fG_43tpSKmM/s640/IMAGE_196.jpgp/img]
                                return hose
                                e46 FPR
                                Had the lift at the shop to change some light bulbs and snagged this shot
                                Engine was supposed to be running early this week but when we cranked it over there was some noise from the lower end. Come to find out that two rod bolts were just barely hitting the oil pickup tube. So entire engine, trans, front suspension, etc etc came out and the pickup was adjusted. It's all back in now and wiring can get wrapped up.
