Classic Daily E30 325iX S54 Swap
  • jakeb
    • 1909
    #61
    Originally posted by MR 325
    Sorry if it's been covered but will there be any issue with the trans and transfer case being at a different angle now?
    The trans are not at a different angle, the engine is. With this swap you use the m20 mounts on the 24v engine.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • jakeb
      • 1909
      #62
      Originally posted by ahriley91
      You could possibly do the booster like the v8 guys do. And like on the e32 i think.
      Yes that is an option. I am not a big fan of that remote booster with all it's linkages though. I will try a GM hydroboost first.
      • Nisse Järnet
        • Aug 2013
        • 1221
        #63
        Looks great :D
        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
        E30 M50 6 spd 764whp @ 24psi.
        E30 M20 6 spd 675whp.
        • rzerob
          • Jun 2013
          • 2315
          #64
          You didn't have to modify the front subframe? I can see this build thread becoming the go to for s54 ix swaps. The oil pan seems like the most difficult part of this build.
          • sam_
            • May 2014
            • 630
            #65
            dunno if this was covered but so just to clarify you work in a shop and this guy just dropped his car off with essentially a blank check for this?
            1991 325i
            flickr
            @sambhaskins
            • roznic
              • Mar 2013
              • 2880
              #66
              WOW, amazing-sub'd.. Def wanna see completed. Great work!!
              • kid325e
                • Sep 2007
                • 6421
                #67
                Man. You keep delivering! What're your plans for the oil dipstick?
                Sent from my Nexus 4 using Tapatalk
                clutchCTRL!
                Move with a purpose.
                - 1991 325iX 4dr/5spd
                - 2000 323i AT
                2016 Mazda CX3 Sport AWD
                • The Dark Side of Will
                  • Jun 2010
                  • 2796
                  #68
                  The front subframe on an iX is completely different than a RWD car.
                  • jakeb
                    • 1909
                    #69
                    Front subframe is untouched...just the modified oil pan. The suspension, drivetrain, etc is just as if the m20 was still in the car.
                    Yes I run/own a shop (www.classicdaily.net) and I am building it for a customer. I wouldn't say he left it with a blank check. There was/is a budget and we do our best to stick to that.
                    I added a 3/4" piece of aluminum tube on the passenger side. Will need to figure out dip stick length once there is oil in the pan.
                    Thanks all. It is a pretty fun swap.
                    • kid325e
                      • Sep 2007
                      • 6421
                      #70
                      Aluminum tube into the oil pan?
                      Thinking this may end up being the best swap for my iX in the future. Keeping my eyes on prices for an S54 now. Can't wait to see this finished!
                      Jake, your work is so damn cool. Thanks for sharing your skills with us and documenting it. I know I appreciate it!
                      clutchCTRL!
                      - 2000 323i AT
                      • jakeb
                        • 1909
                        #71
                        Yes aluminum tube welded into the pan. I'll snap a picture of it once the dip stick is worked out 100%.
                        you're welcome...most of what I learned was from reading build threads so I like to teach if I can. (I was a teacher for 8 years after all)
                        • Bimmer_man
                          • Jan 2013
                          • 1477
                          #72
                          A s54 iX is just so awesome. Subbed i cant wait to see this bad boy run. hope the customer allows a video or two.
                          Float like a cadillac sting like a Bimmer!:)
                          • sam_
                            • May 2014
                            • 630
                            #73
                            very jealous of the owner!
                            1991 325i
                            flickr
                            @sambhaskins
                            • AWDBOB
                              hooptie connoisseur
                              • Aug 2013
                              • 4477
                              #74
                              If you sold these oil pans, I would <3 you forever, and buy another iX.
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #75
                                so amazing cant wait to see this run.
                                1991 318i 4dr slick top
                                Mtech 2 turbo restoration
