Classic Daily E30 325iX S54 Swap
  • litu
    • 848
    #106
    Looks cool, those stuff
    https://www.facebook.com/Cry_77_IX-110483784967661
    https://www.instagram.com/cry_77_ix/
    • 328ijunkie
      • May 2007
      • 3961
      #107
      Be careful of the fuel lines to the regulator, weve had them start to leak after ~6months because most off the shelf stuff is only rated for 3-3.5 bar vs the s54 5bar...
      Check Us out on Facebook
      Full Product Line Tuning
      • jakeb
        • 1909
        #108
        i am using BMW hose which is rated at 5bar
        www.classicdaily.net
        1970 m42 swapped 2002
        1985 LS1/T56 Swapped e28 (557e)
        www.blunttech.com - For all your parts needs
        Follow me on Instagram for constant build updates @classicdaily
        https://www.facebook.com/ClassicDailyLLC
        • 328ijunkie
          • May 2007
          • 3961
          #109
          Excellent!
          • jakeb
            • 1909
            #110
            The car is back to it's owner now. This will be the last post... Well might have some video to upload.
            In the video posted eariler in this thread the engine sounded a bit noisy. Ended up finding 3 of the little adjustment pucks had came out of the cups. Found them sitting under the valve cover. Went through and did a full valve adjustment and it was MUCH quieter.
            During valve adjustment
            First time outside in a while...
            The master cylinder we were using provided for a VERY hard pedal with not much travel at all. That was a porsche 944 unit which I thought was 19mm/19mm but in fact it was 23mm/19mm. Anyway we swapped to a 5/8" dual bore wilwood master and another custom bracket. Pedal feels MUCH better. You can still tell they are manual brakes but the effort isn't bad at all.
            Pictures before it went back to the owner.
            We swapped from tan to black sport interior, aftermarket seat heaters, new dash, dyed carpet, 1 series winter mats, fixed sunroof, etc etc.
            instagram fun @classicdaily
            Getting ready
            Due to scheduling and time constraints I trailered the car down to the customer. I like a nice road trip here and there as well.
            I must say this thing is a BLAST to drive. It just goes...pulling from all 4 wheels. FUN FUN FUN
            • jink0619
              • 808
              #111
              Wow amazing job!
              E30love
              • litu
                • 848
                #112
                AWesome, that would be epic ride, that engine and 4wd drive :)
                  • 37833
                  #113
                  Amazing work as always!
                  Grover Beach, California
                  BimmerHeads.com
                  • rzerob
                    • Jun 2013
                    • 2315
                    #114
                    I think it look 10 times better with the stock IX weaves. Great job. I definitely want you to make a pan and pick up tube for my swap.
                    • Bimmer_man
                      • Jan 2013
                      • 1478
                      #115
                      I have one thing to say... POWAAAAAAAAAAAAAAAAAAAAAAAAA
                      Float like a cadillac sting like a Bimmer!:)
                      • The Dark Side of Will
                        • Jun 2010
                        • 2796
                        #116
                        Where's the 4 wheel burnout vid?
                        • AWDBOB
                          hooptie connoisseur
                          • Aug 2013
                          • 4504
                          #117
                          Me thinks you should sell a kit with that booster delete, frankenpan, and pickup tube :o
                          • nomansland92
                            • 1657
                            #118
                            If I didn't just spend so much money on my turbo build I would have definitely been interested in a kit, on the other hand the only thing better then a s54 is a boosted s54 ;)
                            IX being restored here
                            Ix turbo build here
                              • Jun 2010
                              • 2796
                              #119
                              On BaT: http://bringatrailer.com/listing/199...-s54-swap-awd/
                              • 2mAn
                                SeƱior Mod
                                • 21024
                                #120
                                yea I saw that... I wonder why after going through all that work they would put it up for sale 6 months later.
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
                                Make R3V Great Again -2020
