Classic Daily E30 325iX S54 Swap
  • jakeb
    • 1909
    #76
    Originally posted by AWDBOB
    If you sold these oil pans, I would <3 you forever, and buy another iX.
    I can do that. Also need modifed m50 oil pump pickup. Will also need a booster solution. That will be figured out this week. More than likely it will be hydroboost.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • kid325e
      • Sep 2007
      • 6422
      #77
      In for a group buy of one of these pans. I have a spare ix pan!
      Sent from my Nexus 4 using Tapatalk
      clutchCTRL!
      Move with a purpose.
      - 1991 325iX 4dr/5spd
      - 2000 323i AT
      2016 Mazda CX3 Sport AWD
      • jakeb
        • 1909
        #78
        Not a huge update but pics are fun right?
        Suspension is all back on the car now. Test fitting the wheels so we set it on the ground.
        I'm happy with the fitment.
        So with any swap it seems like there are some things that are road blocks...oil pans, brake booster, exhaust manifolds, and wiring/dme.
        So with this one the next thing to get around is the brake booster.
        Fitting the stock air box first required some trimming of the heater pipes to the interior. They will need some more yet.
        Plenum on..
        As you can see there is NO room for a booster.
        At this point we are planning to go with a booster delete and change the ratio off the brake pedal. Maybe a slightly smaller master cylinder as well to give a better pedal feel.
        • AWDBOB
          hooptie connoisseur
          • Aug 2013
          • 4501
          #79
          Right on- I'd also be in for a group by for an oil pan and modified pickup.
            • 34844
            #80
            I'm probably going to do the same thing even though my engine wont be rotated, likely with a Massive kit. It should be fine, realistically the whole brake setup should be upgraded anyway.
            • The Dark Side of Will
              • Jun 2010
              • 2796
              #81
              What is the fitment (Diameter, width, offset, tire size)?
              They do look really good.
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4501
                #82
                x2!!!!!
                • alloydix
                  • 106
                  #83
                  I have 2 spare ix pans. Could I send them both and get a built one for an s54?
                  • jakeb
                    • 1909
                    #84
                    Would only need one and also need an m50 oil pan. shoot me an email. jake@classicdaily.net
                    • Bimmer_man
                      • Jan 2013
                      • 1478
                      #85
                      I feel like the swap into te ix is easier than a normal e30. Apart from the oil pan mod. Am I right in assimg this ?
                      Float like a cadillac sting like a Bimmer!:)
                      • jakeb
                        • 1909
                        #86
                        Not really... easier on normal e30. This has the pan...plus everything a normal e30 requires.
                        • Lof8
                          • Oct 2006
                          • 2827
                          #87
                          Why on earth would this be easier than a regular e30?
                          S50'd
                          Originally posted by TDE30
                          What is this faggy shit I have happened upon?
                          I can always live in a M3. Can't M3 a house.
                          • rzerob
                            • Jun 2013
                            • 2315
                            #88
                            Jake just makes it look easy.
                            • Bimmer_man
                              • Jan 2013
                              • 1478
                              #89
                              ^^^^^ That's why Haha
                              • alloydix
                                • 106
                                #90
                                Just curious, would this fit?
                                http://store.vacmotorsports.com/vac-...ons-p2437.aspx
