AWDBOB's Newest AWD- Heidi
love it! yes the rear springs are blue....I have some extra spring pads (7.5mm) I can donate if the new rear springs still sit too low for your tastes. You can double up the pads.www.instagram.com/snwmble
#snwmble
Current:
'05 BMW M3 - Silver Grey/Imola Red
'90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
'15 Mini Countryman - Blazing Red/Carbon Black
Past:
'01 Audi Allroad - Light Silver/Platinum Saber Black
'88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
'01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
'90 BMW 325i - Schwarz/Tan sport *Sold*
'89 BMW 325ix - Diamond Schwarz/Black sport *Sold*Comment
ride height looks fine to me. only difference I can think of is the ix springs would be stiffer. does it still have the 50lbs of trunk tar?
the binding coils are "dead" coils. they don't hold any weight, just basically hold the spring to the car.Comment
-Christian
Originally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list.Comment
its getting there, Almost thought you switched out for late bumpers in till I noticed it was sedan. lolComment
That's what I thought- my brother's iX has 19.03s in the rear and 50404.55s up front. I was sent 50404.55s front and rear, so the fronts are correct, but the rears are a totally different design and feel much softer than his.
And I appreciate that. Once I get the right spring in there I'll see how she sits. I think it may be almost level once I tear out the trunk tar.
Still has the trunk tar, guess I'll take that out before I go buying spring pads. And yeah, our driveway slants a bit, I'll have to get a picture on flat. It does look pretty dead on even in the above picture, though, you're right about that.
And good to know about the binding coils. These rears are definitely less stiff than the 19.03s.
Bahah, you're right about that correction, that's for sure. And thanks, man!
Thanks, man. I don't really get too much time to wrench on it, so progress will be slow for now.Comment
My rear H&R springs are blue. Did you replace the shifter bushing yet? I just recently finished my 5 speed swap and the shifter felt off. I couldn't figure out what was wrong. Come to find out it was 180 degrees the wrong way.
No big deal I say, I will just pop it off and switch it around, WRONG. There is no room to just reach up and do that. I had to drop the exhaust and both drive shafts and lower the transmission and transfer case to get enough room to reach up there to pull the clips. A much bigger pain than what I thought it would be.
Be prepared for that unless you know an easier way. If you do know an easier way feel free to share.How to remove, install or convert to pop out windows
Could be better, could be worse.Comment
^^ I need to replace my shifter bushings, and dreading this.www.instagram.com/snwmble
#snwmble
Current:
Past:
It most definitely feels like far more hassle than it's worth, that's for damn sure. Thankfully lifts and air tools are things that I have at my disposal, so it's not a terrible job. I think I would cut the trans tunnel out if I had to do it on my back, though :hitler:My rear H&R springs are blue. Did you replace the shifter bushing yet? I just recently finished my 5 speed swap and the shifter felt off. I couldn't figure out what was wrong. Come to find out it was 180 degrees the wrong way.
Be prepared for that unless you know an easier way. If you do know an easier way feel free to share.Comment
