325IX restore and build continued(turbo, e34ix diff, DCT)
  • nomansland92
    • 1657
    #331
    ^ finally fixed it, thanks 2mAn for showing me lol [emoji14]
    Unfortunately I couldn't finish the trans mounts because I decided to wait till I get the driveshafts back since they will determine the final height of everything. So I spend a little time on the suspension which was long over due.
    Got some race inserts and cut the tubes down
    Used the old shock to keep it straight while I tacked it up.
    Finally done with the mig and can back to the tig so much more fun!
    I wasnt thinking and bought these m3 sway bar links cause they would be easy to shorten but then realized I could have just bought some heim joints and used the round stock I already have and built my own for probably less then 20 bucks but all well to late now.
    All done and ready to have some suspension travel!
    Sent from my SM-G892A using Tapatalk
    IX being restored here
    Ix turbo build here
    • 2002tiiguy
      • Jul 2013
      • 467
      #332
      I like how the abs sensors are still hanging out of the knuckles
      • nomansland92
        • 1657
        #333
        Lol better then a hole and that's the only parts of the abs left besides the one sensor I used for my speed sensor :)
        Ix turbo build here
        • jeenyus
          • Aug 2011
          • 2064
          #334
          looks great. very interested to see those settled and see how the geometry of the CV axles line up with that amount of a drop.
          • driftxsequence
            • Apr 2015
            • 203
            #335
            i really want to buy those ground control top hats but i'm worried about NVH for a daily.
            love this build!
            325IX Build Thread
            RX7 Build Thread
            • kronus
              • Apr 2008
              • 13029
              #336
              ^^ they make some that have rubbery isolators for the springs. I've just bolted them up to one of my cars, will see how they do eventually.
              I realized that other than the title shenanigans, I haven't actually commented. You've done a shitload of work here, dude. Keep it up! Excited to see all the fabrication.
              cars beep boop
                • 34839
                #337
                I've had mine for years - it's not bad. The coilovers themselves and other mods are worse, lol.
                • Nisse Järnet
                  • Aug 2013
                  • 1221
                  #338
                  You'll love it :)
                  E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                  E30 M50 6 spd 764whp @ 24psi.
                  E30 M20 6 spd 675whp.
                  • nomansland92
                    • 1657
                    #339
                    Originally posted by Nisse Järnet
                    You'll love it :)
                    Should go real nice with that getrag 240 swap right [emoji23]
                    Ix turbo build here
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      #340
                      Haha yes! Those crisp shifts and high torque capacity 😆
                      • nomansland92
                        • 1657
                        #341
                        Suspension... check
                        Driveshafts.... check
                        Transmission mounts.... check
                        So much left to be done but its getting there!
                        Ix turbo build here
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          #342
                          Nice man!!
                          • CorvallisBMW
                            Long Schlong Longhammer
                            • 13039
                            #343
                            Do you have any kind of bushings in that trans mount? If not, your NVH is going to be horrific. Even low-durometer urethane is bad with trans mounts.
                            • nomansland92
                              • 1657
                              #344
                              I used some common a-arm bushings, and I can get them in different grades if needed, but i think it will be fine since lots of people run near solid bushings in track cars.
                              Ix turbo build here
                              • jeenyus
                                • Aug 2011
                                • 2064
                                #345
                                Did you have to create a new Transfer Case brace then? I would recommend getting the garagistic transfer case mount too. I have it and I think it's a great product. I only have good things to say about it. Mine is in 80a.
                                Did this cross mount attach to the stock location of the transmission? I can't tell where those two bolts are holding on.
