325IX restore and build continued(turbo, e34ix diff, DCT)
  • rzerob
    • Jun 2013
    • 2315
    #301
    Very nicely done.
    • jeenyus
      • Aug 2011
      • 2064
      #302
      Great work and thanks for the response.
      I really want to go the M52 route in my IX down the road. Just trying to get an idea.
      • downforce22
        • Aug 2009
        • 3191
        #303
        Just taking it to the next level, nice work!
        • jeenyus
          • Aug 2011
          • 2064
          #304
          I recently acquired an oil leak at the oil pan on my 325ix. Since the IX is different, i'm curious if dropping the frame subframe vs jacking up the engine is easier to remove the oil pan on the ix. I cannot find much information on either the front subframe or the oil pan on the ix, which are both different than the RWD.
          • nomansland92
            • 1657
            #305
            I've never just removed the pan so im not sure on the best method but if it were me I'd support the motor from the top and remove the crossmember. Probably easiest way would be to pull the axles then drop the entire front suspension assembly(crossmember, struts, sway bar, rack, etc) all at once. You would need to disconnect the power steering lines though. But if you did it like that you would have perfect access to the entire pan, although you might beable to get the pan out but just lowering the crossmember a few inches, and leaving the power steering hooked up.
            Hope that helps
            Sent from my SM-G892A using Tapatalk
            IX being restored here
            Ix turbo build here
            • jeenyus
              • Aug 2011
              • 2064
              #306
              Hope that helps
              that helps a lot! thank you. I don't have PS in the IX, so there's that. Sounds like it's gonna be a process. Thanks again for your response.
                • 34827
                #307
                Man, that looks great! How much do you want to do the reverse on mine, lol? I still haven't made my ix/N52 oil pan... I'd probably have the engine in there by now otherwise. :(
                  • 34827
                  #308
                  OT, but you have to remove all the axles/suspension anyway to drop the oil pan, since the axles and front diff are attached to it. So as suggested, the best way is to support the engine from above (they make braces just for this purpose) and drop the subframe out from below.
                  • nomansland92
                    • 1657
                    #309
                    Haven't had any updates in awhile but I've been hard at work. Something very awesome lies beneath that cardboard. A few more weeks(hopefully 🤞) and it will be done and ready to enjoy!
                    Ix turbo build here
                    • 2002tiiguy
                      • Jul 2013
                      • 467
                      #310
                      Lol i wonder what it is, and whats all the numbers are about
                      • nomansland92
                        • 1657
                        #311
                        Lol what numbers, or do you mean the little lines on the cardboard?
                        Ix turbo build here
                        • 2002tiiguy
                          • Jul 2013
                          • 467
                          #312
                          &#129310
                          • nomansland92
                            • 1657
                            #313
                            &#129310
                            Oh lol I guess the emoji didn't work, weird it shows up on my phone though.
                            Ix turbo build here
                            • 2002tiiguy
                              • Jul 2013
                              • 467
                              #314
                              Lol ok
                              • Nisse Järnet
                                • Aug 2013
                                • 1221
                                #315
                                That Getrag 240 swap will be awesome ��
                                E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                                E30 M50 6 spd 764whp @ 24psi.
                                E30 M20 6 spd 675whp.
