E30 #2: 1990 Delphin: RHD ITB M20
  • 318aye
    • Jun 2010
    • 895
    #406
    Update from the graveeee. Still struggling with photobucket, if anyone has questions about the kit, tune, setup, etc don't hesitate to ask. I'm pretty good about responding to PM's or posts here but photobucket makes me want to jump off a bridge every time I go to work on the remaining photos in here.
    Interior: Stock seats didn't work out, upon arrival they were poorly recovered so I returned them. Eyeing a set of Recaro Specialists for xmas. Still enjoying the stock Tech 1 wheel. I think that rewrapped, a final leather seat solution and condor knob should close it out. Pro Tip: Pay attention to the wattage rating on your cluster bulbs. 3W max means 3W max. I had one pop on me from getting too hot.
    Engine: Got the new backing plate, trumpets and spacers from Rama. Spoiler alert: all the parts helped the rubbing issue, but didn't solve it (sad emoji). Ultimate solution: I spaced the hood another 1/8" (still not that noticeable) and pulled the factory liner. No paint issues or anything so far. Kinda frustrated with that issue overall but I feel that this is the least invasive solution. I've been driving the car a lot recently and haven't seen any further rubbing. The car is coming due for a timing belt, and I'm still not financially ready to break off a 3.0 for this car. I'd like to pull the motor, get the maintenance / a reseal done next year. Adding factory idle control back into the mix is also on the list.
    Rear End / Suspension: Pre-CMP, the car got all new rear end bushings (minus differential) along with new offset CABs and an alignment. Went to Eurowise here in CLT for it, was left with kind of mixed impressions. They had lots of complaints about the garagistic adjusters, and when I talked to them about a right hand pull (on fresh tires and alignment), they didn't seem to be jumping at the chance to work on the car again and asked me to add front camber/castor adjustment to correct the issue. I have since murdered the G-Forces (which are really not up to task on track) so I need tires before revisiting the issue. The IE 25/22 bar set also went on, and would be perfect for autocross. However, the rear stiffness really made the car too unstable for me on track and I ended up sideways for most of the day, especially once the tires were fully killed. This is with the bar on full soft too, although I think the tires contributed to my issues. The end links also rub my Eibach's in the rear, so in addition to front castor/camber adjustability, I think a 2.5" spring conversion might be on the horizon.
    Originally posted by ForcedFirebird
    Typed out a huge response as far as MS/M1.3 tuning....got lost in the upload.
    Sorry.
    In basic, 230whp is easy talk with a good engine builder on a 2.8/280 cam, no sweat on a 3.0/284.
    Waiting on a 3.1 Peerless-built m20 to trip the dyno with a WOT tune. Then I will really see what a 3.1 vs 2.8 vs 272 vs 284 will do in a real chassis on a real dyno with replicating results on the same dynojet machine I have been beating up for 8yr.
    Getting closer (lots left to go) to the limit in this car at 180 whp, 230 feels like a good practical target. More would be fun on the street, but honestly wouldn't be much use for me on the track. Interested to see what you squeeze out of a properly equipped 2.8!
    Originally posted by digger
    You'll want a 288 or more if you want to push past 230 with itb there isn't much downside the throttles tame the cam and power gains keep increasing (not like a standard intake where it doesn't drive as nice and you hit a wall power wise)
    Alpha n works fine on the street if the ecu is half decent, you use a good tps and you get it tuned properly.
    Per your earlier comments, I'm looking into a contactless TPS as well. Gonna try and find a direct fit before I go and modify the RHD parts.
    Giant stream of consciousness picture update:
    • ZodGilla
      • Dec 2015
      • 14
      #407
      FYI, none of the images are showing up for me.
      • ThatM20Guy
        • Aug 2014
        • 600
        #408
        Same here
        89' 325ix Diamantschwarz/Black rattle can...
        Insta: r_moose_w
        Originally posted by flyboyx
        I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
        • rzerob
          • Jun 2013
          • 2315
          #409
          Ditto.
          • AwakenNoMore
            • Dec 2010
            • 1291
            #410
            Originally posted by rzerob
            Ditto.
            R.I.P. Images
            1991 325i - "Scambles" The Daily Driven lightly modded.
            1988 Mazda RX-7 TII "Mako" The Free Dorito
            bacon by Jared Laabs, on Flickr
            • ZodGilla
              • Dec 2015
              • 14
              #411
              I inspected the images, they're getting this error:
              Failed to load resource: the server responded with a status of 403
              Looks like you need to change permissions on the pictures. You may be able to see them but nobody else will.
              You could just upload them to a image sharing site if you don't want to deal with permissions. I prefer Imgur for its simplicity since you dont need an account.
              • 318aye
                • Jun 2010
                • 895
                #412
                Imgur ftw. Sorry, pics are still huge. But they're there. When did it become hard to post pictures on the internet?
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5616
                  #413
                  when photobucket decided to Futt Buck every thread.
                  • Vic
                    • Apr 2016
                    • 34
                    #414
                    Two of my favorite cars! Mk2 Supra and an e30! I've owned a total of 9 mk2's and finding oem parts for that is definitely not as easy getting oem parts for e30's.
                    Ex. Rocker moldings, door belt moldings... everything is nla! finding one with a non rusty hatch lol. Great pics man!
                    • rturbo 930
                      • Dec 2005
                      • 2629
                      #415
                      To resize using imgur, add an H to the end of the img name. Example: imgur. com/tBlMNqZh.jpg
                      • AWDBOB
                        hooptie connoisseur
                        • Aug 2013
                        • 4516
                        #416
                        1) I love this build.
                        2) I highly prefer flickr to imgur.
                        3) I just reread this and didn't realize that you made 180whp on a stock cam/bottom end. That's incredible.
                        • 318aye
                          • Jun 2010
                          • 895
                          #417
                          Thanks! Love the mk2's as well, the one pictured has an aluminum 5.3 in it, lots of fun.
                          You're the real MVP. Never thought I'd get this fixed.
                          Thanks! Does flickr cap you in any way? Seeing what an otherwise off the shelf M20 can do has been the goal for a while. It's enough fun that I think I'll focus on other areas of the car for a while before adding more power.
                          • 318aye
                            • Jun 2010
                            • 895
                            #418
                            Got out to the mountains a little while ago, thought I'd share.
                            Leaving the bar setup alone for now. I've gotten used to it now on the street, and tire should help on the track. Would like to get the car a little lower with a little more camber next time. Meanwhile, a new addition has taken up some of my garage time.
                            • bradnic
                              • Jul 2012
                              • 3554
                              #419
                              where did you find the block / manifold part for the rear brake hard lines? been looking for that piece myself for the IX.. or is it just your car is totally rust free lol
                              HOWTOs:
                              DB vert plastic bumpers
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • wworm
                                • Dec 2016
                                • 1719
                                #420
                                New toys are always good. Looks like you have quite a cool collection growing there. 911 or 912? Is that a celica in the back?
                                1984 Delphin 318i 2 door
