The m10 Turbo thread!
  • Dj Buttchug
    • Jun 2010
    • 7688
    #76
    this gonn be good
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Graebmw95
      • Mar 2014
      • 362
      #77
      Originally posted by tschultz
      Finally an update :devil:
      Still a decent amount of work to be done, but it looks like that was easy to drop in with the size of the E30 engine bay!
      Make sure you are 100% sure your distributor is installed properly and TDC (not BDC)!
      Also since you are starting with the turbo on the car, and not NA, it may be a good idea to try a first start with the timing retarded slightly.
      Do you know how you are going to control/add fuel with the new setup? Once that turbo gets spooling, you are going to need a high rate of fuel to match the air flow...
      After running some numbers, I am quite worried that the turbo is too big and you won't get much spool. You mention they upgraded you to a 'much better turbo' but it isn't a better turbo if the engine is too small to spin it up. If you don't get spool until 3rd gear at 4000rpm, that won't exactly be usable on the street...
      Yes! Updates! They're few and far between! So I'm pretty sure i have the distributer on correctly if not its an easy fix. I just need a cap and rotor to find out. In terms of the turbo a 2867 is pretty small so it'll spool almost immediately. Imm using 800cc injectors and a Holly system for management. Spending $4500 on tuning and fuel management so it'll be good. Upgraded my fuel pump and regulator as well.
      • Good & Tight
        • Apr 2004
        • 2057
        #78
        Nice update..!! Engine bay looks sweet, ballin with a/c also.
        Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
        ____________________________
        E-mail Panayiotisx2@gmail.com
        Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
        • Graebmw95
          • Mar 2014
          • 362
          #79
          Thank you sir! It's a tight fit but i gotta keep that AC! Love my cool air. 😜 I have to wrap my ac lines though to prevent bad things from happening.
          • ZomBAR15
            • Aug 2014
            • 103
            #80
            What size fitting did you use?
            • varg
              Florida Turbo Man
              • May 2014
              • 3429
              #81
              Nice! Going with the big bucks in engine management I see.
              IG @turbovarg
              '91 318is, M20 turbo
              • Graebmw95
                • Mar 2014
                • 362
                #82
                I drilled it using a 7/16 drill bit and tapped it using a 1/4in pipe and threaded in the nipple. I used thread sealant and red lock tight and torqued it down to 20ft lbs.
                • Graebmw95
                  • Mar 2014
                  • 362
                  #83
                  Yeah! I have to in order to tun smoothly and proficiently.
                  • tschultz
                    • Jun 2013
                    • 332
                    #84
                    When's this thing hittin' the road??
                    http://www.Drive4Corners.com
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3429
                      #85
                      Are you tuning it yourself?
                      IG @turbovarg
                      • mk3f.t.w.
                        • Apr 2014
                        • 106
                        #86
                        nice build!
                        • E30budget
                          • Mar 2015
                          • 519
                          #87
                          sub'd :) I also have an M10 car
                          • Dj Buttchug
                            • Jun 2010
                            • 7688
                            #88
                            update
                            Ig:ryno_pzk
                            • mk3f.t.w.
                              • Apr 2014
                              • 106
                              #89
                              Update
                              • Graebmw95
                                • Mar 2014
                                • 362
                                #90
                                Hey guys! I know I haven't posted anything recently. I've been working my shitty job and making next to nothing, so I haven't really had the money to continued my build unfortunately. However, I just got a new job and will be starting up the build again! So I'm excited. Look forward to new posts in the coming months.
