Great work man. Would love to see that thing boosted
86 Delphin m30 Turbo - Now with more turbo!
I've been slacking on both pictures and progress lately. For the most part the turbo is all hooked up and it starts. Now i just need to get it to stay running. The biggest set back right now is my lack of knowledge of megasquirt and tunerstudio.
Here's a pic dump of the last 3 months.
Finally got a wider/stickier wheel setup. XXR 530 16x8 with 245/45/16 Bridgestone Potenza re-11.
That's it for now. Next step is to get it to the exhaust shop then off to the tuner. Can't wait to drive this
Nice progress! It's really coming together.
I'm in the same boat, can't wait to get this MS2 thing running, hit the exhaust shop for some last welds, and then get moving!Comment
Your center section might be to much of an angle to flow probably. I think the max is like 10 degrees or something with journal bearing atleast. Just something to check out but the build looks wicked and clean!Comment
Goodbye headgasket work.Comment
Good wheel choice.
More updates!Comment
Not much in the way of progress in the past couple months but I've got some updates.
I picked up some Kamotor flares to give the 245's some more room to work with but the condor offset bushings practically push the tires into the front valance.
Started driving it for a while and it began to misfire occasionally. Then it just started getting worse and worse and now bogs horribly under load. AFR sat at about 10.8 at idle... I haven't taken much time to diagnose it but I ordered msd coils for wasted spark so hopefully its ignition related. If not I might actually have to work on this car again
In other news, I may be starting another build thread! If everything goes smoothly this will be a comfortable daily driver build.
... this car was supposed to be a comfortable daily driver build
