Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    #1651
    Originally posted by Albie325
    The more I see from builds like yours and guys that can weld, the more I know I need to just buy a house so I can get a good welding setup and learn to do this type of work. Looks great man
    welding really enables bad ideas and projects to come to life which otherwise wouldn't... if you couldn't tell :p
    Originally posted by rzerob
    Wow Sh3rpak!ng, what a creative idea. Great job.
    thanks!
    Shadetree30
    • Digitalwave
      is a poseur
      • 6299
      #1652
      Once you work out the kinks, you can go ahead and build me a set of these TA's
      RISING EDGE
      • Sh3rpak!ng
        • Jan 2014
        • 2667
        #1653
        Ha! Now that I've figured out the recipe I'd consider making another set sometime in the future
        Shadetree30
        • Sh3rpak!ng
          • Jan 2014
          • 2667
          #1654
          Trailing arm mods done! Just need paint now. Was considering additional reinforcement along the side of the arm that got cut into, but now I think its unnecessary. The tube itself is 1/8" which is heavier than the original stamped steel.
          New springs are on order, same rates but a 6" length vs original 5" length. I've got more adjustment range now too and loads of travel. The actual articulating perch assemblies bolt in just in case I ever needed to replace/service any portion.
          Almossssst done with fab work. Just need to do the cross reinforcement on the passenger side trailing arm since the first piece I made interferes with the fuel fill hose. God it's going to be great to sweep out the garage and dust everything off. The steel dust is god awful and has gotten EVERYWHERE.
          Half done with assembly of a HF standing blast cabinet too :D
          Sent from my SM-G960U using Tapatalk
          Shadetree30
          • Digitalwave
            is a poseur
            • 6299
            #1655
            This is awesome. It looks like you'd probably still be able to run a 5" spring with how much adjustment there is. I have my adjusters all the way down (touching the trailing arm) with 5" springs. I suppose though that part of the goal with this is to have more bump travel, which a 6" spring in the same rate would.
            RISING EDGE
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              #1656
              thanks! yea, probably could still run the 5" spring. Eyeballing it, max height adjustment is actually taller than where I was at with the old adjuster. But as you noted, half the reason I did this whole thing was to gain more travel. I misspoke a few posts ago when i mentioned coil bind... I do not have coil bind, but I do/did have contact between upper and power perches.
              Shadetree30
              • ZekeTheSneak
                • 1562
                #1657
                Originally posted by Sh3rpak!ng
                More progress. Some steps forward and backward. Got the massive m50x1.5 tap from China to chase threads in the front coilover housings. Did that and everything threads nice and smoothly again.
                Did welding the strut tube damage the threads? I want to do the same thing with my bcs. My front swaybar is in a bad position.
                • Sh3rpak!ng
                  • Jan 2014
                  • 2667
                  #1658
                  No I don't think so. One tube had rust in the threads and the insert was very difficult to remove. After removal I noticed a couple of threads were fairly torn up. The other insert threaded back in nicely without issues. I chased them both anyway and sprayed them with copper anti-seize.
                  Shadetree30
                  • Digitalwave
                    is a poseur
                    • 6299
                    #1659
                    What spring rate do you run in the rear?
                    RISING EDGE
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      #1660
                      8k (448 lbs) front
                      10k (560 lbs) rear
                      Shadetree30
                      • Sh3rpak!ng
                        • Jan 2014
                        • 2667
                        #1661
                        New toy in da haus.... works spectacularly in conjunction with the monster compressor. Just need to improve lighting inside and dust collection/seal Sent from my SM-G960U using Tapatalk
                        Shadetree30
                        • rzerob
                          • Jun 2013
                          • 2315
                          #1662
                          This is awesome but I have a question. Does the threaded adjuster have a locking collar to keep it from moving out of adjustment?
                          • Albie325
                            • Jul 2016
                            • 515
                            #1663
                            Damn I want a media blaster so bad. AND a beer fridge in the garage. Coin toss as to which takes precedence tho
                            '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
                            Albie325 Build Thread | Albie325 COTM Jan 2021
                            • 2mAn
                              SeƱior Mod
                              • 21035
                              #1664
                              OHHHH MANNNNN... I need to media blast this oil pan Im trying to sell... lemme come by one of these days. Tomorrow and Saturday are "car days" for me. Text me when you're home
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #1665
                                No it doesn't and doesn't look like any of the GC kits include one. I was thinking about this as well. There shouldn't be any reason for the perch to rotate, but I'll mark it and check over time anyway to be sure. If it does rotate I'll figure something out.
                                Shadetree30
