The Malaga Bomber (no rust this time)
    So I stopped by John's shop(WOT-TECH) earlier this week to get an exhaust made for the car. He did a great job! I'll post up some pics of it later, but for now here's a sound bite :devil:
    Originally posted by phreshkid View Post
    What about 72 brackets? 72 should be correct as the bumpers are close to the body. It wasn't until 73 that the bumpers were pushed out another two inches to meet DOT requirements. I'd think that 72 brackets will work as well.
    I suppose 72 could work as well
    Originally posted by AdOz View Post
    I may have a set of euro bumper brackets dude they are 77 but I think they should work as we never saw the extended bumpers. Not sure what the postage would be though
    Thanks for the offer bud! I'm going to attempt to modify the ones I currently have and see how that works out. I'll get in touch if I need to scoop up those brackets :D
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
      Sounds tits!
      1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
      1984 316 Coupe - The Base Model - Pain in the Ass
      1988 750iL - The Daily Driver
      ...And a couple others...
        Sounds nice
          Sounds great
          •• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
          •• Rear Subframe Bushings • RTABs • Facebook ••
            Thanks guys, I really like how it came out!
              Trust me it stock :yawn:
                Sent from my SAMSUNG-SGH-I747 using Tapatalk
                  So here's the run down on the exhaust that John @ Wot-tech put together..........
                  • Mandrel Bent
                  • TIG'd
                  • Single Resonator
                  • 3'" Downpipe
                  • V-bandz
                  • 2.5" once the exhaust turns underneath the car
                  • Single Resonator
                  The collection of parts
                  Close up of a v-band
                  First turn down for the downpipe done
                  Tacked together
                  Action shot
                  Downpipe completed with the bung for the wideband installed
                  Next we started on the piece after the downpipe
                  Added a resonator
                  Then we pulled it out after tacking everything in place and John finished it
                  We ended up adding a shield underneath the flex pipe so that it wouldn't get a hole dragged into it :p
                  You can see the shield if yu look in the top right corner of this picture
                  Then we finished the "axle-back" part of the exhaust
                  Close up of the tips. Very similar to 5th Gen Camaro SS exhaust. Someone else also said it looked like a Vetter exhaust. But it's neither
                  Here's a pic of everything but the downpipe. We snugged it up against the bottom of the car to try to retain as much ground clearance as possible
                  And if you're wondering about hangers, John had a great idea to mimic the stock hangers on the car
                  Here's a little throwback pic of the car I never posted. I can't really see going any more agressive on stock body if you want to keep meaty tires. I can only fit a credit card between the rear arches and sidewall of the tire. Guess I'll need to chop it up for flares once I pick my new wheels up form my friend ;)
                  -edit- I have some heat wrap I've been waiting to install. So this weekend's project will be wrapping the downpipe!
                    Originally posted by knuklehead92 View Post
                    Originally posted by Mac_86ES View Post
                    HA HA HA
                      That sounds mean!! Nice work
                        Thank you sir
                          Awesome job, I can only imagine how potent a m20 turbo is in a 2002.
                          Cant wait to see the flares..
                            Well with finals wrapping up I'll finally get some more time to start working on this car. I've collected all the parts I needed, now I just need to get around to installing them. That includes a medium case 3.73S diff, upgraded axles, rear disk brake conversion, along with a couple of apperance modifications. Stay tuned.....or don't ;)
                            It's quite a riot to drive. Even though it's still a small turbo and motronic, it moves ;D I can't wait till I get the e30 diff in so I can really start abusing it!
                              I just went through your entire build... and wow this is impressive work. That exhaust set up is nuts, sounds amazing. This 02 must be crazy fast, good stuff!
                              -Ryan
                              05/87 Henna M3
                              04/71 Baikal 2002tii
                                Thank you sir :D It's definitely a blast to drive
