1990 325is restomod project aka "Klaus"
  • Staszek
    • 2533
    #316
    Originally posted by bradnic
    Nice choice with Nogaro faces
    What’s custom in the style 5s?
    Just the Nogaro face lol :)
    • bradnic
      • Jul 2012
      • 3550
      #317
      Fill n drill though right? 1 piece style 5s with 4 to 5 lug adapters and standard brakes won't work in front on a non M3 e30 without heavy poke. ask me how I know :-).
      you have a wilwood BBK so not sure if the offset is different.
      HOWTOs:
      DB vert plastic bumpers
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • 0-60 freak
        • Jun 2015
        • 511
        #318
        My fill and drill 2p style 5 et25 should work nice
        Sent from my SM-N950U using Tapatalk
        Current Cars:
        2016 PORSCHE GT3 RS
        2017 FERRARI 488GTB
        2018 RAPTOR CREW CAB
        1991 318is SLICKTOP H&R SPRING SEMA CAR
        1991 318IS SLICKTOP STERLING SILVER
        1990 325ic BRONZIT/AUTO :)
        1989 E30 M3 (SOLD AWAITING SHIPPING)
        On Order:
        2018 DODGE DEMON
        Searching for:
        CLEAN E30'S
        S54 DRIVETRAIN
        E30 DASH
        E30 PARTS
        • bradnic
          • Jul 2012
          • 3550
          #319
          dayum.
          HOWTOs:
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • Staszek
            • 2533
            #320
            Fill and drill. They clear at the standard et23 since while my bbk is bigger in diameter they are slimmer on the front then the standard e30 brakes. I’m leaving them at Et23
            • 0-60 freak
              • Jun 2015
              • 511
              #321
              Originally posted by 0-60 freak
              My fill and drill 2p style 5 et20 should work nice
              Current Cars:
              2016 PORSCHE GT3 RS
              2017 FERRARI 488GTB
              On Order:
              2018 DODGE DEMON
              Searching for:
              CLEAN E30'S
              S54 DRIVETRAIN
              E30 DASH
              E30 PARTS
              • AWDBOB
                • Aug 2013
                • 4396
                #322
                What BBK do you have? I'm also running filled/drilled style 5s and really don't want to run the 10mm spacer I have up front so I can fit a 225.
                • Staszek
                  • 2533
                  #323
                  I have IE’s 310x20 kit for 16” wheels.
                  • AWDBOB
                    • Aug 2013
                    • 4396
                    #324
                    http://www.iemotorsport.com/bmw/item/e30bbk310w.html
                    Thanks! Gotta add another thing to the list now haha.
                    • Staszek
                      • 2533
                      #325
                      Im following your thread, it never ends lol!
                      • wworm
                        • Dec 2016
                        • 1719
                        #326
                        lol ahh jeez
                        list forever grows, never shrinks.
                        How much does the BBK protrude off the rotor? Trying to gauge what can fit over my rx7 calipers and I really like 16" weaves for that oem+ steeze
                        1984 Delphin 318i 2 door
                        • Staszek
                          • 2533
                          #327
                          The end is near!! Well not the end, but at least the rear end :)
                          Buttoned up the diff, new gasket, filled with Redline and finally got the subframe up tonight. It wasnt to bad, had to do some loosening and tightening to get the bushings to line up perfectly. All new screws and bolts.
                          Reconnected the rear brake lines, pushed through the new ebrake cables, connected the new M3 rear sway bar.
                          Then the fun stuff, the Ebrakes, I am still not 100% sure I put them on right, it seems correct we will see when I get a chance to test. They are not really hard but just a pain in the ass to get lined up right. It is nice to see nice and fresh new parts and not all rusty.
                          Last but not least put on the new rotors, didnt realize how big the rears are now, only slightly smaller then the fronts. Interesting is the rears do not have a rotor set screw opening, the fronts do.
                          It was getting late so I didn't put on the calipers yet, I will do that tomorrow. I have the wheels sitting in the back of the X5 ready to get the tires mounted. I should hopefully have this on the ground tomorrow night.
                          • Staszek
                            • 2533
                            #328
                            Originally posted by wworm
                            lol ahh jeez
                            Directly from IE's site.
                            "For the 318/325. This 310mm front big brake kit is intended for cars with 16" or larger wheels. It uses a Wilwood forged aluminum 6 piston Dynapro caliper. Rotors are 2 piece with aluminum center (hat) measuring 310mm (12.2") x 20mm (.81"). Kit includes calipers, rotors, pads, brackets, hardware and stainless steel braided hoses. These are very effective and reduce unsprung weight. This caliper is 1/2" narrower on the out board side than most calipers so it is much less likely to cause wheel fit problems (you need only 1.75" from the rotor to the back side of the spokes to clear this caliper)."
                            • Staszek
                              • 2533
                              #329
                              Felt some what accomplished today. First I finished the rear brakes, brand new Wilwood calipers to go along with the front ones.
                              Did one more check all the way around the car to make sure rotors turned freely and everything was tightened up, then I put the wheels on for the first time!!!
                              I lowered the car off the jack stands for the first time in a very long time, it felt amazing. Sure the car has no driveshaft and I cant move it, but at least its on its own feet. I cant remember the last time there were not just tools and boxes everywhere around the thing.
                              I put the rest of the trim on and I am basically done for the winter because its moving outside (covered but outside) for the winter. The idea is either build another 2.5 car garage next year or sell this house for a bigger one with 4 car garage.
                              The next steps in the spring (or nice days in the winter maybe) is pull the engine then get the whole front suspension, subframe and steering rack complete. Then finally drop in the S54 wire it up and hopefully it runs!
                              Then get the Mtech II kit on and get this thing painted. It doesnt look too bad from car away, and if I cut the paint I am sure it will look much better, its just rougher then I would want it.
                              Enjoy the photos, and the awesome reverse rake since the fronts are still on the stock springs.
                              Its so tiny next to the E38.
                              • bradnic
                                • Jul 2012
                                • 3550
                                #330
                                That’s just perfect. def getting Wilwoods for my Alpina wheels
                                Doesn’t it feel terrific having that rear end all refreshed?! Nothing like it
                                HOWTOs:
                                OEM Keys
                                MTech1 docs
                                88 ix Lach/Card
                                91 ic Calypso 3.1
                                86 Cosmo 2.7
                                OEM+ or bust!
