1990 325is restomod project aka "Klaus"
  • parkerbink
    • Jun 2004
    • 10138
    #346
    Really nice work!
    • bradnic
      • Jul 2012
      • 3550
      #347
      Think I’m gonna try those Polks in my vert and IX for rear speakers..
      If you have the premium sound package with tweeters in front you prob don’t need the coaxials... folks canupgrade the kick panel speakers with an OEM 5 series speaker that comes with larger magnets.. still available from BMW
      HOWTOs:
      DB vert plastic bumpers
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • Staszek
        • 2533
        #348
        Yea I bought 2 sets before I looked at the 5 speakers. My front premium tweeters were shot so I reused the OE tweeter sail and put the Polk inside it so it still looks like it’s stock.
        • Staszek
          • 2533
          #349
          Old tank and exhaust out to the recyclers. I thought about selling the exhaust, but for how cheap it is it wasnt worth my effort.
          Here she will sit for the winter, really need to build that second garage.
          Noah custom fit car cover, supposed to breath so that the moisture doesn't stay in there.
          • Staszek
            • 2533
            #350
            BTW I want to repaint the original black coating that was on the car before the PO painted it over in some kind of white that didnt match the car.
            Two questions. What should I use to sand down the paint that he put on, and what coating should I use to make it look OEM again.
            Its a short term solution until I can get the whole car repainted and the MTech II kit painted and put on.
            • 2mAn
              Señior Mod
              • 20342
              #351
              SEM Trim paint! hahaha
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              -2006 Volkswagen Jetta TDI
              Make R3V Great Again -2020
              • bradnic
                • Jul 2012
                • 3550
                #352
                exactly
                you talking about the rockers right?
                Are you keeping the rock guard coating? Wurth, 3M or Permatex make spray for that.
                Use SEM 39043 Trim Black for color.
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • Staszek
                  • 2533
                  #353
                  exactly
                  So the PO sprayed over the rock guard coating with some random white paint. If I try to remove that white will that end up removing the rock guard, or can I lightly sand and just paint over what they did?
                  I am the worst at painting!
                  • bradnic
                    • Jul 2012
                    • 3550
                    #354
                    you can sand it off but the rubber coating will be a PITA. you can reapply the coating and paint.
                    or just clean and paint over the white :-)
                    HOWTOs:
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • MR E30 325is
                      • Dec 2008
                      • 3300
                      #355
                      I would second a good cleaning and then a repaint.
                      My previous build (currently E30-less)
                      http://www.r3vlimited.com/board/showthread.php?t=170390
                      A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                      • Staszek
                        • 2533
                        #356
                        Sounds much easier to me! What should I clean with?
                        • mjweimer
                          • Dec 2015
                          • 648
                          #357
                          Use some sort of automotive paint prep solvent (wax/grease remover) with heavy towels to remove anything on the surface. For example I used this on my last engine bay project:
                          http://excelproducts.net/product-fin...6.aspx?cid=565
                          You want to use a prep solvent that does not leave a residue. Once cleaned, scuff with a scotchbrite pad, repeat the cleaning step, tape and shoot.
                          The rockers can take a beating from road debris so it is a good area to shoot with a 2K automotive urethane paint. I am planning to use this product on my car:
                          Hot Rod Black Satin is a high quality professional 2K component auto paint with smooth flow and leveling. Delivers greater scratch resistance and durability. Satin-finish black 2K aerosol.
                          You might be able to find a local paint shop that sells the SprayMax 2k product line.
                          MJ
                          • Staszek
                            • 2533
                            #358
                            MJ
                            Thanks! I will look into that. Its only temporary and will get covered up by the Mtech II just depends If I have the money for a full repaint this year.
                            • Codym42
                              • Mar 2013
                              • 611
                              #359
                              Just skimmed through this entire thread last night. Great job on this build so far! I really like the interior.
                              I can't believe all the headaches you had with the wiring. Did the previous owner's stereo actually sound good? Also wondering how you like the alarm system? I'm thinking about adding an alarm to mine.
                              '90 325i - 5 speed coupe
                              '05 330ci 6MT ZHP
                              • Staszek
                                • 2533
                                #360
                                Thanks!
                                I have no idea lol! He left the head unit and the speakers, but there were no amps in the car so I never actually heard the system. I cant imagine it did, it may have been loud but the way he had the speakers mounted in the door it probably didnt sound great.
                                As for the alarm, I like it, mostly because it was super cheap, the keyfob looks pretty nice and it unlocks and locks the doors. Its not fancy, I just wanted something that could remotely unlock the doors. The car wont be a daily.
