1990 325is restomod project aka "Klaus"
  • rzerob
    • Jun 2013
    • 2315
    #511
    What is the toggle switch for next to the two usb's. And are you not doing a short shifter? That is one thing you will probably regret not doing right now. I am sure I have said it before but I love your interior.
    • Staszek
      • 2533
      #512
      Originally posted by R3VM3UP
      Looks nice. What did you do for wiring? Is it all just stuffed in the glove box?
      What do you mean? I have the OE s54 plug going to the ECU in the glove box. I have Andrew’s harness connections into it on the engine bay, mostly hidden behind the M3 wiring panel in the engine bay.
      • Staszek
        • 2533
        #513
        The switch is for the M3 sport button, that’s the one that came with Andrew’s harness. I’m replacing that with an E30 for light switch with SPORT stenciled on it in the BMW font.
        As for the shifter it’s the M3 Performance SSK from the factor. It’s about 30% shorter then the stock E46 M3 shifter. I also have the UUC DSSR.
        • R3VM3UP
          • Jan 2017
          • 170
          #514
          I mostly meant the part of the harness with the relays and fuse holder. It's kind of a mess and doesn't really fit nicely anywhere.
          Also, did you use a Z3M harness to reach the glovebox?
          • Staszek
            • 2533
            #515
            Got ya, I will try to take pics of it.
            Yes bought a brand new Z3M harness.
            • 968Reckless
              • May 2013
              • 1095
              #516
              So you cut the back corner off the intake and plastic welded a panel over it? Similar to what Kassel offers?
              /// MTech Belts ///
              S52 BUILD
              M3 VERT BUILD
              • Staszek
                • 2533
                #517
                Similar, I need to get pics from the guy who did that for me. I’m horrible with that stuff. His version looks much cleaner then Kassel and we didn’t cut as much.
                • R3VM3UP
                  • Jan 2017
                  • 170
                  #518
                  Cool, thanks. I have an E46 M3 harness on mine. I'm not happy with the mess of wires so I'm in the middle of completely rewiring everything to pass through the firewall with a couple of mil spec connectors and a new fuse/relay box in the space above the glovebox.
                  • Staszek
                    • 2533
                    #519
                    Sorry for the small pic I didnt take this one.
                    It was riveted and then sealed as well, that thing shouldn't come off :)
                    • masterofnone
                      • Oct 2018
                      • 99
                      #520
                      Dude, yes! Have you turned him over yet!?
                      • Staszek
                        • 2533
                        #521
                        Not yet, ECU is not tuned to turn off EWS etc. The programmer is off but should be soon.
                        • bradnic
                          • Jul 2012
                          • 3552
                          #522
                          Hey if you want some company give me a shout when you're ready to crank her up..
                          HOWTOs:
                          DB vert plastic bumpers
                          OEM Keys
                          MTech1 docs
                          88 ix Lach/Card
                          91 ic Calypso 3.1
                          86 Cosmo 2.7
                          OEM+ or bust!
                          • masterofnone
                            • Oct 2018
                            • 99
                            #523
                            Fuel pressure regulator in the stockish spot for the S54
                            Did you make this bracket by hand or machine? And if it was laser cut or something would you mind making another one for me? Looks like a great solution after looking for space under the car tonight!
                            • Staszek
                              • 2533
                              #524
                              I can't weld, unfortunately, so I am having a shop help me with things like that. They made it by hand. I can find out more details on that from them. I told them where I wanted to put it and they built the bracket.
                              • Staszek
                                • 2533
                                #525
                                Here is the mount, its not done yet, it needs to be cleaned up, but we are trying to keep it all up high to cover it with the original cover.
