1990 325is restomod project aka "Klaus"
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4496
    #466
    Originally posted by wworm
    Why not right after the headers? Not entirely sure why you're adding a merge, but if its for sound reasons the closest to the headers is where I've read/heard its most effective at numbing the rasp. Totally only limited to keyboard wisdom here, so feel free to tell me otherwise.
    Stoked to see so much progress being made on this build too
    Merging right behind the headers leaves torque on the table due to exhaust harmonics. Also, I'm pretty sure the stock s54 mid section merged fairly far back as well if I'm not mistaken.
    • wworm
      • Dec 2016
      • 1719
      #467
      interesting. Makes sense
      1984 Delphin 318i 2 door
      • Staszek
        • 2533
        #468
        You are correct on both counts. There are a few people that merged to early with adverse effects.
        • Staszek
          • 2533
          #469
          Spoke to the guys today they are adding the xpipe in behind the cats :)
          • R3Z3N
            • Jan 2011
            • 3056
            #470
            Originally posted by KIRIEIW;4928791Question
            , did you buy a new firewall grommet or did you rob the one off your original M20 harness? Were you able to stretch it over the ECU harness plug? I'll need to do mine this weekend.
            Check my thread out too if you want, but I was able to fit all the wiring, and 2 additional sets of relay wiring I added along with wideband O2 wiring in my grommet. Just soap it up!
            Here's my pic of the wiring which is going back in.....
            • Staszek
              • 2533
              #471
              Thanks, I have been following your thread, its awesome.
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4496
                #472
                Nice!! Are they going to tune/dyno the car for you as well?
                • Staszek
                  • 2533
                  #473
                  Yep, we will do a baseline of the car as is once it's running. Then tune than a dyno after the tune as well.
                  I will post both. He was in agreement that the merge should be behind the cats, he has seen a few S54s with merge right after the headers and the power loss was pretty great.
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4496
                    #474
                    Awesome, I can't wait! I'm watching with heavy anticipation (as I'm sure many of us are). If I found a good deal on an S54 out here I wouldn't hesitate to start refreshing it for a swap someday. If you hear of anything around let me know.
                    • bradnic
                      • Jul 2012
                      • 3554
                      #475
                      total drool fest. such a clean swap... some crazy cool swap parts too. love that you're keeping ac.
                      pass side header is really close to the steering rack boot though. are you adding any heat shielding?
                      can't wait to see this beast in person.
                      HOWTOs:
                      DB vert plastic bumpers
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                      • Staszek
                        • 2533
                        #476
                        Looks closer then it is. It's about the same distance as the stock ones. I will take some measurements.
                        • TrentW
                          • 2815
                          #477
                          Curious what your ground clearance is at the collector flanges?
                          • Staszek
                            • 2533
                            #478
                            They are slightly lower than the oil pan on one side by a few MM. I will measure it, but I dont think it will be a problem because its higher then the original E30 Oil Pan was.
                            If I scrape that then I am pretty close to scrapping the oil pan as well which would be bad.
                            I am lowered but not slammed. See if I can get some pics with the car on the ground underneath.
                            • masterofnone
                              • Oct 2018
                              • 99
                              #479
                              Subed!
                              Very sweet build. Are you going to use the stock E30 fan with the E46 PWM controller for the A/C?
                              • Staszek
                                • 2533
                                #480
                                Originally posted by masterofnone
                                Subed!
                                I was but my stock fan was busted up a little, so I am going to use a spal fan as an aux with the E46 PWM.
