1990 325is restomod project aka "Klaus"
  • prisonerofdoom83
    • May 2013
    • 529
    #676
    Do you know if the wires that are running to the front door tweeters are hooked up to the front kick panel speakers already? I see waiting there but not too sure . Mine has blanks at the moment
    • Staszek
      • 2533
      #677
      If the wires are there they should be good to go I believe. I forget what year the started prewiring.
      • prisonerofdoom83
        • May 2013
        • 529
        #678
        Let me know when you are going to sell your headlights! That is if you are still going back to sealed beams
        • Staszek
          • 2533
          #679
          I will be selling soon, not going to sealed beam, I have Euro Hella Smileys.
          • prisonerofdoom83
            • May 2013
            • 529
            #680
            Even better for you!! Keep me posted . I finally put the springs on you sold me and the little suspension stuff .
            • Albie325
              • Jul 2016
              • 515
              #681
              Was gonna say, what in the world would make you go back to sealed beams. This sounds more like it
              '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
              Albie325 Build Thread | Albie325 COTM Jan 2021
              • Staszek
                • 2533
                #682
                So a few things happened. I finished my OE stereo install, waiting on my Bluetooth board to really complete it.
                Bad pic I will have to take a few more after the board is in.
                Also bought these, I like the Depo's but decided to go OE, I will get pics of them installed with LED bulbs.
                Last but not least I did a flooring project in the garage. I couldnt stand the crappy concrete. Went with flexible interlocking vinyl, its nice and quiet unlike the plastic and its easy to clean.
                • jeenyus
                  • Aug 2011
                  • 2064
                  #683
                  Dang I like that! Do you have a link to the flooring you used? What happens if fluid gets under it? We get a good amount of snow here.
                  • quasi mofo
                    • Dec 2016
                    • 107
                    #684
                    I like that floor. Are those tiles peel and stick or floating?
                    • Albie325
                      • Jul 2016
                      • 515
                      #685
                      Crazy how the floor makes such a difference to the garage, looks great man
                      • Staszek
                        • 2533
                        #686
                        it’s a floating floor, interlocking, it’s a pretty tight seal so fluid shouldn’t get under, if it does it will be very minimal and should evaporate. I read through testimonials and people in so pretty heavy winter areas have no issues.
                        Here is the link! They have lots of options.
                        Our Smooth Flex Tiles offer a fast and easy way to cover your garage or room in your home. These interlocking tiles come in several great colors and
                        • Staszek
                          • 2533
                          #687
                          So not sure if i mentioned this on this thread. I sold the wheels and have something new on the horizon.
                          Stay tuned!
                          • R3Z3N
                            • Jan 2011
                            • 3056
                            #688
                            Hey Staszek, I don't remember if you added cruise control, but I updated the DIY Here so that you can use the correct TE MQS AMP plugs and pins for the cruise control module as well as adding the Cruise Control Clutch cutout switch with correct wiring/housings so that now cruise control will not only work, but cancel on speed differential, brake AND clutch disengagement!
                            • Staszek
                              • 2533
                              #689
                              I havent, but I will once the AC is working right. Something is still not right, it kicks on sometimes and not others.
                              • R3Z3N
                                • Jan 2011
                                • 3056
                                #690
                                ^Ugh. Sorry to hear. I wonder if the airventdisplay.no gentleman prototyped his solution yet?
