1970 2002 Factory Restoration
  • F34R
    sLaughter
    • 12376
    #46
    How much of the gallon did you use to paint the car?
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • knuklehead92
      • Aug 2011
      • 732
      #47
      About half, I still have a bunch left. If you are going to use it, make sure the surface is very clean if not you will get rust forming underneath.
      Trust me it stock :yawn:
      • knuklehead92
        • Aug 2011
        • 732
        #48
        updatezzzzzz
        I made a 3.5 inch intake with a vibrant 6 inch velocity stack and filter. It was grabbing way to much hot air from the fan.
        Finally made that leap and bought an AEM infinity 6 and got it tuned!
        Pretty good number for stock engine.
        stay tuned more coming
        • IronFreak
          • Dec 2012
          • 3702
          #49
          I love this thing
          Instagram @rebellionforge
          • rzerob
            • Jun 2013
            • 2315
            #50
            Originally posted by IronFreak
            I love this thing
            Ditto.
            • knuklehead92
              • Aug 2011
              • 732
              #51
              updatezzz
              Added some fancy gold jamz
              15inch BBS RS faces came in...
              test fit is very tight fit but i think i can make it work, still debating of stepping it up to a 16 or 17.... ill sleep on it..........
              Valve Adjustment
              Repainted the valve cover
              Drilled some holes in the valve cover baffle, to prevent oil getting into the pcv that blows into the intake manifold. So during left hand sweepers and elevation changes oil would get sucked up there and burn it into white smoke. At the new track near me Dominion Raceway, I was smoking screening everyone behind. Very common for S2000 engines.
              pic from s2ki forum
              New Mr.sideways Radiator w/ 3 inch core, different design than my previous radiator. Rather than flowing top to bottom on the hot and cold side. It flows across then down then back across.
              I also started on duct work to force the air through the radiator.
              pic of it done and I also added a Peterson Catch Can
              GF bought me new badges!!! COT dam she is pretty cool...
              First test was Road Atlanta @ Gridlife, I must say it was a bad ass event! Def go again
              Supercharged frs and K swapped miata
              One of the scariest track I've been to so far, there were 11 wrecks that weekend. I went off about 4 times and spun out at Turn 7. I did let my buddy drive my car and he also spun out at turn 7 and almost caused an accident. Lesson 1 never let anyone drive your own car unless its a pro-driver.
              I didn't get to lay down a fast time which was sad but I will be back.
              Next steps are shaving more weight and adding aero with some dtm styling.
              • JeLani
                • Aug 2015
                • 1552
                #52
                that hood badge is actuallly pretty sick
                1986 LTW M52 (First project 2015- )
                1998 e36 328ic/5 -
                Roundie alpina pig cheek’d (1969)
                1967 2002 parts car
                1994 318iS junked.
                • AWDBOB
                  hooptie connoisseur
                  • Aug 2013
                  • 4512
                  #53
                  Originally posted by knuklehead92
                  Next steps are shaving more weight and adding turbo things
                  fixed
                  • rzerob
                    • Jun 2013
                    • 2315
                    #54
                    Great job as always. I like the new title as well.
                    • s14brent
                      • Mar 2014
                      • 573
                      #55
                      goddamn this car is cool!
                      89 325i 4dr s52
                      02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
                      21' Toyota Tacoma TRD OR 4x4 6 speed Manual
                      • rwh11385
                        lance_entities
                        • 18403
                        #56
                        Wow that's an amazing piece of work
                        • Fucatypr
                          • Dec 2016
                          • 108
                          #57
                          I love your car!
                          Btw, why AEM and not Haltech??
                          1993 BMW 850ci factory 6 speed
                          1992 Honda Civic Hatch, built B16, turbo, and nitrous
                          1989 BMW 325i, f20c swap
                          1989 Honda CRX, built LS/vtec, turbo, and nitrous
                          • knuklehead92
                            • Aug 2011
                            • 732
                            #58
                            Originally posted by Fucatypr
                            I love your car!
                            The infinity hardware is pretty nice and faster processing speed if i recall correctly. Software is pretty good too. I would of gotten the haltech elite but it was actually more expensive. I managed to get the infinity and patch harness for a lot less than the haltech elite cost by itself. My tuner also really liked the tuner software. The car feels super smooth and almost like oem.
                            • rturbo 930
                              • Dec 2005
                              • 2629
                              #59
                              Any idea what this thing weighs with all the changes you've done? I would think it would be pretty light.
                              • knuklehead92
                                • Aug 2011
                                • 732
                                #60
                                Happy new year y'all.
                                2016 pics.
                                Whats in the works...
