'89 318i 6 speed m50b32tu turbo swap build
Was getting some issues with starting and a persistent DTC 83 (crankshaft sensor) error. The wiring on the ms43 sensor patch harness was good/new, however i'd leveraged the original harness for connecting to the sensor.
No pics, but the cable was not in great shape.
Decided to just run the e36 MS41.0 EURO obd2 front mounted crank sensor. In the e36 this is fed 5v from the DME, however i was informed that it would also accept 12v feed. So i wired up an adapter harness so i could wire it into the ms43 harness. Started first go! no more errors and a VERY strong start.
How did they come up with 12V feed would work on that sensor?
Yes it will also work in an ms41.1 car, however i dont understand why you would need to know? If you are ms41.1 you have the rear mounted CPS (same part number as the ms43 sensor) and should already have a patch lead to feed it 12v from the vanos connector.RHD OBD2 M50b25 turbo build thread:
http://www.r3vlimited.com/board/showthread.php?t=384800Comment
I have no current issues. But its something that has been in back of my mind, But no MS41.0 Euro car looks to have the 703 retrofit harness.
I have the euro M52 crank sensor on my OBDI timing cover and crank wheel. Running MS41.2
The rev limiter is set to 8K but kicks in at 7800, Something we haven't got sorted yet.
Gotcha. Basically what i was doing when i was using MS41.
The euro ms41.0 never had the retrofit harness because it uses a different sensor. At anyrate, it works perfectly fine with a 12v feed.RHD OBD2 M50b25 turbo build thread:
This is what i am getting:
https://adamat.com.pl/n54-n55-turbo-...2x-kevlar.html
They are making a custom version of this with a starter ring gear position to suit the m50 starter motor. You could use any 8 bolt N54 clutch setup, as long as you use the n54 starter with a 10mm spacer.
It's becoming hard to source a GS6-37BZ locally, but there are GS6-53BZ aplenty.Comment
