E34 550iT....The Gristle Hammer
  • slammin.e28
    שמע ישראל
    • 12054
    #31
    Originally posted by bostonvert
    Parts hauler is awesome, I love older trucks
    v12 e34 is insane, good luck with it!
    ps if I was to daily drive a v12 7 series it would cost me about 5k a year just in taxes in Belgium..
    Jesus! That's insane.
    I have $0 in taxes on the cars..they're all old enough now that they fall under some older vehicle tax relief thing.
    • bostonvert
      • Oct 2015
      • 233
      #32
      I know, if older then 25 it falls back to 35 a year but they are raising the minimum age to 30 so a lot of people are fucked pretty soon. Engine swaps are illegal to
      Instagram : makeitsnap
      1985 e28 520i
      • Walter
        • Feb 2016
        • 28
        #33
        Because I had this car in my garage for a detailing to pay back Jeff for his help with my E28, I took some pictures and video of this thing.
        First: Exhaust video
        https://youtu.be/C3LyP92QzoM
        • slammin.e28
          שמע ישראל
          • 12054
          #34
          So, got the shifter all fixed, now I have access to all 6 gears.
          Before it was flat and about 3/4 an inch shorter. When shifted into 5 or 6 it was rubbing on the guibo. Also lowered the trans another 3-4mm.....long story. Also re-bled the clutch, it's a lot better now. Must have had a minuscule amount of air in it.
          Then I decided to put the spare tire back in. The car had gotten REALLY smelly, like BAD. I couldn't figure out where....but I found out...
          8 or so dead baby mice in the spare tire well.....removed them and cleaned the well. Smell is gone now.
          Decided to take the car to C&C on Sat morning. Started up just fine and drove 40 miles to C&C. Went to leave and the injectors wouldn't pulse, also the fuel pump would cut off when cranking. Tried jumping it, but still nothing. So had to tow it to the shop and properly diag.
          Turned out the 3 year old battery was marginal, and the power junction for the aux relay box (which houses the fuel pump/injector relays) was bad. Corrected that and started driving it home.
          THEN I was like 5 miles from home and decided to show off to the panhandler at the interstate exit....
          I launched the car and immediatly there was a pop and the engine reved....but car would barely move. So got it out of the road and had dad call AAA.
          Tow driver was super cool, and talented with that roll back.
          Got the car home and on the lift and diaged.
          Did that with a used, stock, e39 528i clutch...
          Then....since there was a drive down Skyline Drive the next day (Sunday)....I went to the shop (40 miles each way) to grab a replacement axle. This is where I learned that 535i axle are larger than the 525i ones....so I had to crawl under a parts car and harvest the axle.
          Done and done...did the drive and it was awesome.
          I think after getting the car cleaned up, I'm more into it now. It's a blast since I got the shifter BS and clutch bled all proper.
          Now I've got some fueling issue going on, I think. I'm going to swap in the brand new dual fuel pump setup from the 750 and all that jazz. The stock 525i pump seems to not be able to keep up when the tank gets low, so I get all kindsa misfiring etc....plus it's loud, and has been loud since I bought the car.
          Also going to swap in the rear trailing arms from the 750 and larger axles from the 535.
          Then I'm gearing up to swap in the other M70, since this one uses a ton of oil and smoked on decel, and install the new M5 clutch and have VAC put a new gall plate on the flywheel.
          • delamaize
            • Nov 2013
            • 1465
            #35
            You're not helping me....
            I still have that 750iL I bought, and with the bad gas tank and fuel lines, I'm even more tempted to find a 5 touring....
            Dumpster Fire Pilot
            • Anthony B
              • Nov 2012
              • 308
              #36
              I honestly love this thing, looking forward to the updates
              • Walter
                • Feb 2016
                • 28
                #37
                In this video we see the elusive V12 E34 quickly scurrying through a tunnel to catch its prey
                • elcoy
                  • Jan 2011
                  • 569
                  #38
                  I'll have you know I am going to look at a cheap 750il today just because of this thread...
                  I might shelf the dream of a S38 touring if I can pick it up cheap.
                  The Lineup in order of appearance:
                  91 535i
                  91 318is 5 Lug/E46M3 Brakes
                  91 325is w/ S52
                  88 Vert Plastic Bumper Swap
                  88 M3 ;D
                  91 325ix 5 speed
                  89 Vert Royalblau Metallic
                  73 2002
                  1986 325es --> is swap Rallycross Car!!
                  1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
                  1993 525i Granitsilber Metallic Touring
                  Need a 91 M5 bad but wife would shoot me...twice
                  *UPDATE: got a 93 M5 and still alive
                  1972 Jeep Wagoneer
                  1975 2002 five speed
                  Check out:
                  Elhartspeedshop.com
                  • docleary
                    • Sep 2009
                    • 102
                    #39
                    wow, this touring is wicked.
                    Originally posted by stevie30
                    The e30 is the '57 Chevy of the European imports. Quote me on this.
                    1986 325eS - cosmosblau, sold
                    1990 325i - bronzit sedan, sold
                    1984 318i - delphin coupe, sold
                    1987 325iS - zinnoberrot, sold
                    1988 325iS - zinnoberrot, sold
                    1989 325iX - zinnoberrot sedan, current project/daily
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      #40
                      I went ahead and got my euro hitch installed. Just have to get the cover for the hole in the rear bumper before I get that wrapped up.
                      Also did an aesthetic thing:
                      Gearing up to pull the engine from the other 750 to put into this thing. Going to tow the Jensen home from Vintage this year.
                      • MrBurgundy
                        R3V Degenerate
                        • Mar 2012
                        • 5616
                        #41
                        The best part about this car is the "Where's your v12, Peasant?" sticker
                        • Northern
                          I like cupcakes & sh!tboxes
                          • 5284
                          #42
                          Is that the famous "Horse Cock" hitch?
                          Originally posted by priapism
                          Originally posted by shameson
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            #43
                            Yessir!
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              #44
                              New engine tear down.
                              ....annnnd when the head didn't wanna come off I went about tapping it with a rubber mallet....tapped just right in the just wrong spot...dumbass.
                              Oh well....two more heads at home w/~90k miles or so....so no biggy.
                              This weekend I'll go through the heads, lap the valves, do guide seals, etc, then it'll be really close to going back together....should be one more weekend to get it assembled...then I'll bring the Hammer in and do the switcheroo...
                              I sold the 318Ti too, so I've got more capital to dump into the Hammer, so I'm going to get a new flywheel and clutch. May even address some other issues with the chassis. Going to swap in the rear from the 750iL. 7mm wider (at the hubs) and I can run the larger axles. Also need to do the hatch wiring. It's started to short and kill fuse 1, which controls, among other things, the cluster and brake lights.
                              • slammin.e28
                                שמע ישראל
                                • 12054
                                #45
                                E34 550iT....The Gristle Hammer (3/8 update)
                                Heads all done up two weekends ago. Valves lapped, new guide seals.....fresh.
                                Block is 100% torn down, but I've started bolting bits back onto it. Waiting for my bearings to come back from coating and for main bearing bolts to come in from Germany. The tensioner guide is wild...that little gear is kinda cool. Pricey little bugger.
                                Pistons all cleaned, rings are all free and the lands are free of debris, etc.
                                I totally disassembled the oil pump and cleaned it. Good thing to, as the pressure relief was stuck shut. Got that all freed up and perfect, lubed everything and reassembled.
                                I have had every nut/bolt out of this engine. Every. Single. One.
                                ....and there are a lot.
