E34 550iT....The Gristle Hammer
  • 2mAn
    SeƱior Mod
    • 21017
    I'm convinced that you don't know how to do a burnout
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • F34R
      sLaughter
      • 12376
      You're the king of slamming an engine in and making an event! You did that for Gfest 13 with the B35.
      E34T is the sex, e34 550T is better than any sleeper I have seen! Love it
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • lambo
        Captain Scene Points
        • 10953
        The drive by....had a wayyyy better one but it got lost.
        ty bby
        • Dj Buttchug
          • Jun 2010
          • 7688
          brb. removing m50 to v12 my setup.
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • slammin.e28
            שמע ישראל
            • 12054
            Originally posted by delamaize
            Hey Slammin, Can you talk a little more about the wiring?
            Sure. I didn't use an adapter for the x20. Two reasons. 1) I like the wiring to be clean and to the point. 2) It already ended up where I need it, I just needed to change the connector. SO, I cut the connector off and pinned the new connector to match the e34 stuff. As for the electronic throttles (EML), they're exclusively handled thru the X21 connector....and cruise is handled thru the EML. It's was virtually plug-n'-play. There's even a spot on the e34 pedal box to install the accelerator position sensor (remember, some M30 e34s had EML). The EML light is needed for it to work properly, otherwise it will go into a limp mode....BUT WAIT! ALL THE WIRING IS THERE! All I had to do was populate a connector under the dash with two wires from the X21. The light and wiring into the cluster is all there. The weird things were the oil level and pressure sensors. They go into the body harness. Fun fact: The oil pressure light runs on the same circuit as the E-box fan. SO, if the ebox gets too hot and the fan comes on...the oil pressure light will come on the dash. I spliced the oil pressure sensor into the harness. Works like a charm. I actually didn't bother with the oil level sensor since I was in a hurry, but imagine it's the same general concept.
            I'll level with you....I don't.
            Hehe, I slammed the B35 in there for Vintage that year....then wrecked the car the beginning of June. Slammed it together to get to GFest which was on June 21st that year.
            It's not a good habit.....lol.
            ty bby
            <3 <3 <3 <3
            • EyExR
              • Jan 2011
              • 959
              Killer setup man. Awesome work.
              My 325iX DIY Threads:
              Front Wheel Bearing Replacement
              325iX Rear Subframe Bushings and MUCH more w/pics!
              325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
              • delamaize
                • Nov 2013
                • 1463
                God man, I'm working a deal on a 1991 750i right now, It's a rust bucket, and has not run since 2001, but at the price I'm trying to get it for, It will be worth it....
                Now just to find a E34, and finish the E30 M60 swap....
                Dumpster Fire Pilot
                • stonea
                  • 2892
                  I really need to find a v12 project
                  My Garage
                  Feedback
                  Instagram: Stone.Hopkins
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    I made it squeak the tires last night.
                    I don't think this thing will do a burnout. It just likes to mooooove.
                    • LJ851
                      • 7919
                      Roll the back back wheels into one the puddles of coolant your rovers have left and dump the clutch at 4k rpm
                      Lorin
                      The M30 is God's engine.
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        I've got to get the M5 clutch in there....the 528i clutch, obviously, isn't cutting the mustard that well....but I kinda wanna wear it out since it's in there....
                        • delamaize
                          • Nov 2013
                          • 1463
                          Goddamn you Slammin.....Look what you made me do...
                          Dumpster Fire Pilot
                          • BobombETA
                            • Apr 2008
                            • 1575
                            wtf how am i just seeing this. this is amazing!
                            Instagram
                            Current: 99 M3
                            Past: 84 325e, 84 528e
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              So haven't touched The Hammer in a couple weeks because got a real parts hauler:
                              1995, 5sp, v6, 255k miles.
                              It's AMAZING. I had one back in 2007-8 that was exactly this but 4wd. Loved it. Then I had the z31s....so I'm kinda partial to the vg30e. This thing SCOOTS!
                              First things first, I removed the dumb camper top. Then I wound down the torsion bars and dropped the rear with 2" blocks.
                              It's always working.
                              Picked up a 4.6 for the Disco....
                              ....and a bike for a friend of mine....
                              If you don't have a small Japanese "chicken tax" truck....GET ONE. They are the best thing ever.
                              • bostonvert
                                • Oct 2015
                                • 233
                                Parts hauler is awesome, I love older trucks
                                v12 e34 is insane, good luck with it!
                                ps if I was to daily drive a v12 7 series it would cost me about 5k a year just in taxes in Belgium..
                                Instagram : makeitsnap
                                1985 e28 520i
