Jerkin with my Jensen #19998 (11/6)
  • slammin.e28
    שמע ישראל
    • 12054
  • ELVA164
    • 4861
    I'll be praying for you.
    Enjoy it though, you madman! :)
    • delamaize
      • Nov 2013
      • 1463
      V12 swap it.
      Dumpster Fire Pilot
      • cleanasse30
        • Jan 2014
        • 436
        Looks like quite the project, good luck!
        2.7i Stroker Turbo Build Thread
        90 325i | 95 Miata
        • 2mAn
          Señior Mod
          • 20982
          What is wrong with you! haha
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • Northern
            I like cupcakes & sh!tboxes
            • 5277
            That Slammin boy...
            Originally posted by priapism
            Originally posted by shameson
            • slammin.e28
              שמע ישראל
              • 12054
              On to more pics....
              The engine bay. I cleaned it a bit, of course after the pics.
              ...and here's the bad part(s)
              Under the brake booster. I suspect there was a brake fluid leak and that ate the paint away. There was a pile of leaves in this area, and when I vacuumed them out the hole appeared.
              Driver's side hood hinge mount. The passenger isn't bad, but will prob need some patching for longevity.
              .....annnnnd under the fuel tank. Some plate steel and seam sealer will take care of this easily enough.
              The tank itself was empty of fuel, but it's toast inside. Looks like they sell alloy tanks online for these cars. The driver's door is toast, so it'll get replaced. The passenger door is still salvageable. The floor pans are still good.
              Ordered the timing belt and rollers last night. In the meantime I'll check and adjust the valves. Apparently these engines are prone to burning exhaust valves if they're not adjusted properly.
              • ST1G
                • Oct 2012
                • 6689
                Lol
                • E30SPDFRK
                  • 5714
                  Good luck getting the valve covers sealed again
                  Byron
                  Leichtbau
                  • Mr. Burns
                    • Aug 2011
                    • 3516
                    I enjoyed your taste in troubled vehicles.
                    Sent from my SM-G920W8 using Tapatalk
                    Originally posted by flyboyx
                    i have watched my dog lick himself off a few times
                    • LateFan
                      • May 2013
                      • 4414
                      Yeah, even if they looked good, there's all this chaos under the sheet metal! They tried to tell us it were the next Austin-Healey 3000, but it wurnt.
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        Already have the rubber gaskets installed. We'll see, lol.
                        Bet you can't wait to see what I get next month!
                        Yeah, I'm thinking I'm going to strip 'er down and start over. Was hoping I'd have the thing driving by Spring, but nooooope. Luckily the rust is pretty localized to the entire driver's side bulkhead area. I'll persevere. I've wanted a cheap English roadster that isn't a TR6 or MGB forever. The obscurity of this thing makes me want to save it even more.
                        Pooshed it into the garage since there is a hurricane coming up. Took off the left front wing to assess damage. I wasn't unhappy with the results. I didn't know these had fibreglass wings up front. ^_^
                        It's all manageable in there. I'll pull the windscreen and dash next and see what that reveals. Got the hood to shut and latch. Had to adjust the seized bonnet cable. I guess I'll order a new one eventually. Add it to the list.
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          Now for a defining moment of what would you do?
                          This was under the windscreen finishing trim. I've shot an email to a company in England who bought all the Jensen tooling when they folded up, but that's probably going to be crazyyyy expensive. I'm thinking, and discussing with Paul, that I can make this entire thing up of several smaller bits, formed with a metal brake and stretcher....or I can try to make use of a parts e28 I have to get the bends/angles I need. It's all going to be hidden under the windscreen trim, so as long as it's there to support everything it'll be fine.
                          Thoughts?
                          • delamaize
                            • Nov 2013
                            • 1463
                            Thoughts?
                            Honestly, I'd see how much Reproduction metal will be, if it's available at all. If not, This might just be a death nail. That is a lot of cancer, and who knows what it looks like in other places.
                            Dumpster Fire Pilot
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              I know, lol, I've gone rust hunting and am confident I've found it all. There's not a lot of places for it to hide.
                              I'm waiting on a reply from a place that bought all Jensen's tooling back in the 80s to see if they make this piece. If not, I'll be making it by hand. Someone put the car together by hand....why shouldn't I be able to fix it?
