F20C powered 325i
  • Jaker
    • Oct 2013
    • 234
    #31
    Originally posted by Fucatypr
    Crank position sensor
    Well that'll certainly make things difficult! The harness looks very nicely made. Not sure I understand how that big an error could have been made. Who's the maker?
    • Fucatypr
      • Dec 2016
      • 108
      #32
      Fixed the wiring on the crank position sensor and the Haltech still gave the same code. We got to looking around more and we found one of the cam position sensors was wired backward.
      We got that all done and gave it another start
      1993 BMW 850ci factory 6 speed
      1992 Honda Civic Hatch, built B16, turbo, and nitrous
      1989 BMW 325i, f20c swap
      1989 Honda CRX, built LS/vtec, turbo, and nitrous
      • Fucatypr
        • Dec 2016
        • 108
        #33
        I'm not sure either but the builder sent patch pieces to try and fix the problem and they stayed in constant communication with us to try and help fix the problems. I would rather not say who built the harness just yet.
        • Fucatypr
          • Dec 2016
          • 108
          #34
          First drive around the parking lot....yes I know it needs suspension.
          Found more problems, no tach, no temperature gauge, no brakes, and the Haltech can't see a speed signal.
          • ForcedFirebird
            • Feb 2007
            • 8300
            #35
            It's alive!
            Still curious about the oil pan.
            john@m20guru.com
            Links:
            • Fucatypr
              • Dec 2016
              • 108
              #36
              Originally posted by ForcedFirebird
              It's alive!
              We modified the stock oil pan......not the best solution but I'll work for now.
              • Fucatypr
                • Dec 2016
                • 108
                #37
                After double checking all of the wiring for the dash, it looks like the si board is dead. We are thinking we should send the cluster out to get it rebuilt with a custom tach. Still no speed signal so no vtec just yet but we need to test the lsd.
                I told my buddy I needed him to do a small pull so I could datalog the speed sensor. I didn't tell him I turn the rally antilag on, lol.
                • 2mAn
                  Señior Mod
                  • 21085
                  #38
                  Send the cluster to Gregs///M he's a forum member and does totally solid work. 9k rpm tach? no problem!
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • darvo
                    • Dec 2010
                    • 407
                    #39
                    Will you guys be running an Accusump as a precaution of the lowered oil capacity?
                    • Fucatypr
                      • Dec 2016
                      • 108
                      #40
                      No because it has the same capacity and the stock s2000 oil pan wasn't designed correctly from the factory. Once you start driving s2000 hard at the track, you quickly figure that out
                      • z28
                        • Oct 2014
                        • 362
                        #41
                        This thing is great, you should post some pictures of the oil pan.
                        First e30 - 1991 318i 4 door
                        • Fucatypr
                          • Dec 2016
                          • 108
                          #42
                          Nothing really to see, just a cut up oil pan. We are getting a new flange made to build a new oil pan that will give us more clearance.
                          Suspension is in, we are also installing e90 drop hats to get the front a little lower.
                          • Fucatypr
                            • Dec 2016
                            • 108
                            #43
                            I took the Falken rt-615k tires off of my Mugen wheels and put them on the bottle caps.
                            Suspension installed
                            • Fucatypr
                              • Dec 2016
                              • 108
                              #44
                              Ran into a new problem, none of the windows are working. I tested the circuit breaker and it's good but after checking further I found no power to fuse 17. I need an e30 shop manual, lol.
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #45
                                Are you grounding the k7 relay? With the stock engine the wire is open when starting and grounded when running to divert all power to the starter. There's an extra pole on the starter solenoid for it. Common with swaps.
                                john@m20guru.com
                                Links:
