F20C powered 325i
  • Fucatypr
    • Dec 2016
    • 108
    Originally posted by ForcedFirebird
    Cool swap!
    How is that a "problem"? Anything that fits a 240sx will fit an e30 as far as frame clearance. The 240 swap pans are popular to use in our cars. If you prefer to keep a rear sump, Arc Asylum makes a sub frame to clear rear sump pans.
    Because the s2000 front crossmember is in front of the engine, the oil pan is more of a mid sump.
    1993 BMW 850ci factory 6 speed
    1992 Honda Civic Hatch, built B16, turbo, and nitrous
    1989 BMW 325i, f20c swap
    1989 Honda CRX, built LS/vtec, turbo, and nitrous
    • Fucatypr
      • Dec 2016
      • 108
      New engine harness
      • ForcedFirebird
        • Feb 2007
        • 8300
        Yes, I know. Again, you could follow a 240sx swap, or use a "rear sump" e30 subframe. I guess since there's no "bolt-in" swap kit, some people might be turned off? The s54 swap (or any other s5x rear sump) requires similar dealings, as does the LSx etc.
        Fucatypr, mind sharing your solution?
        john@m20guru.com
        Links:
        • Fucatypr
          • Dec 2016
          • 108
          After getting the harness in, we tried to start the car a few times then......
          Pulled the trans and got the pieces out. We got another starter and.....
          Pulled th trans again and I drove a hour to get a used factory starter
          No more starter problems!!
          • Kershaw
            • 11822
            Vorschlag weighed the m20+g260 at 497lbs. So this swap will save 40lbs. A lot less than I'd think, but it's something. The 240hp will be what's awesome though.
            AWD > RWD
            • Fucatypr
              • Dec 2016
              • 108
              and the balance should be much better because of the distribution of the weight
              • iwantspeed
                • 3164
                awesome thread
                dont forget the amazing shifting of the 6 speed trans of the s2000
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5616
                  Please put vtech dohc stickers on the side, please.
                  • Fucatypr
                    • Dec 2016
                    • 108
                    I'm having a hard time posting youtube videos.
                    Got the harness in and got the car running but it runs like it's out of time and it has a bad misfire. The Haltech gave us a code for a bad crank position sensor, switch the sensor but we still have the same problem.
                    Looks like a problem in the wiring....
                    • rturbo 930
                      • Dec 2005
                      • 2629
                      What's the problem?
                      If you want to embed them, it's pretty simple.
                      [youtube]***[/ youtube]
                      In place of *** you put the video ID, or whatever you'd call it, which in the youtube link would be the numbers and letters at the end after ' watch?v= '. Hope that makes sense.
                      And take out the space between the slash and youtube. Had to put that in to keep it from trying to post a video.
                      • Fucatypr
                        • Dec 2016
                        • 108
                        Originally posted by rturbo 930
                        What's the problem?
                        tried that but it didn't work I'll try it again
                        • Fucatypr
                          • Dec 2016
                          • 108
                          Time to get learned....
                          found one problem
                          • Jaker
                            • Oct 2013
                            • 234
                            What sensor plug is that?
                            • itskingsteelo
                              • Jul 2013
                              • 1340
                              how long have you been at this build?? thread has only been alive since yesterday and it seems youre well into it already.
                              Originally posted by dvck
                              • Fucatypr
                                • Dec 2016
                                • 108
                                Crank position sensor
                                We've been at it for a few months now. I didn't want to start a thread until it was clear we would be able to get it up and running. I hate to into a build thread and the car never gets finished.
