F20C powered 325i
  • agent
    Vice Grand Pubaa
    • 7960
    #61
    Originally posted by 2mAn
    Did you grab the side trim on the white cab? Can you? I need it
    If it's for your white car, be advised one or more of the pieces of door trim are different sizes between verts and non-verts. Ask me how I know...
    Originally posted by kronus
    • BraveUlysses
      • Jun 2007
      • 3781
      #62
      do you mind taking some pics of your crossmember, engine mounts and oil pan and posting them here? thanks!
      • Fucatypr
        • Dec 2016
        • 108
        #63
        I can not but there is an old saying, good things come to those who wait.
        1993 BMW 850ci factory 6 speed
        1992 Honda Civic Hatch, built B16, turbo, and nitrous
        1989 BMW 325i, f20c swap
        1989 Honda CRX, built LS/vtec, turbo, and nitrous
        • darvo
          • Dec 2010
          • 407
          #64
          Hope to see more vids soon!
          • knuklehead92
            • Aug 2011
            • 732
            #65
            Thanks! I love your car.
            With the summer setup, 225/50r15 Pirelli Trofeo Rs, we will need a 4.10 rear.
            Thanks man! Let me know how the trofeo rs are. I will be downsizing tire from 17s to 16s. and pirelli makes some nice 16 sizes. Also def get a baffle for the pan. the car looks great!
            Trust me it stock :yawn:
            • varg
              Florida Turbo Man
              • May 2014
              • 3405
              #66
              That caged and mini-tubbed early Volvo 242 though
              IG @turbovarg
              '91 318is, M20 turbo
              • accident
                • 7303
                #67
                this is AWESOME
                Moral of this story?
                • Fucatypr
                  • Dec 2016
                  • 108
                  #68
                  Yep, it's a 1978 242 with an old Red Bull Nationwide chassis. It got 4th in Montreal with Steve Wallace at the wheel.
                  Tires for the Volvo
                  I did say we like hondas...motor and trans., j35 with an Andrews trans
                  • Jaker
                    • Oct 2013
                    • 234
                    #69
                    Whoa! Who made that bellhousing?
                    Oh, and how old are those Countach tires?
                    *** Edit: NVM. I see they're still available from Tire Rack, at $790 PER TIRE!
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3405
                      #70
                      Your E30 is cool but that Volvo is friggin sweet. Those are some huge tires. After reading about it being swapped into a Miata I wondered why that J-series V6 isn't a more common swap, with how light it is. But I imagine RWD transmission options are tricky.
                      IG @turbovarg
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #71
                        Not to mention there must be a lot of those motors seeing they came in the Odyssey, which were known to have transmission problems.
                        EDIT: Holy cow! There's literally dozens of them at wreckers in our area for $500-ish for 2000-05 and $700-ish for 05+. Sounds like a good engine for chump/lemons.
                        john@m20guru.com
                        Links:
                        • Fucatypr
                          • Dec 2016
                          • 108
                          #72
                          Well that trans is worth more than my entire e30 build but you can get cheaper transmissions that will work but the whole setup won't be cheap.
                          Got a small update on the e30 that I will post tonight.
                          • Jaker
                            • Oct 2013
                            • 234
                            #73
                            All this talk about crazy tires and that 345/35-15 and guess what I saw the other day behind a dumpster at the local Chevron station: a discarded very worn 345/35-15 Pirelli!!
                            • darvo
                              • Dec 2010
                              • 407
                              #74
                              Its already tonight
                              • Fucatypr
                                • Dec 2016
                                • 108
                                #75
                                Originally posted by darvo
                                Its already tonight
                                I know, I know
                                Well the problem with the the lack of power to the window and blower motor relays is because of the wiring harness. I jumped the power in the the fuse box and found only one of my window switches worked correctly. I guess I'll being learning to rebuild window switches this weekend.
                                I'm also not happy that the front is sitting so high even with the e90 drophats. We want to put some miles on the car first but we may be getting custom springs made in the next few weeks.
                                and for the people that need pics, three turbos, an Andrews transmission, and a Honda F1 header.....
