F20C powered 325i
  • Fucatypr
    • Dec 2016
    • 108
    #91
    There is no wiring to be done, just plug in the new engine harness into the c101 plug. The stock cluster works perfect. With the Haltech you can program the ecu to send 6 pulses per revolution to make the 6 cylinder cluster accurate. Nothing like seeing the stock tach sweep past well past 7k. The harness also comes with wiring to use the s2000 cluster if you want.
    The oiling problem will be fixed with the new oil pan.
    1993 BMW 850ci factory 6 speed
    1992 Honda Civic Hatch, built B16, turbo, and nitrous
    1989 BMW 325i, f20c swap
    1989 Honda CRX, built LS/vtec, turbo, and nitrous
    • Sladek
      • May 2016
      • 228
      #92
      that's incredible, I'll be watching closely for updates!
      • Fucatypr
        • Dec 2016
        • 108
        #93
        New sway bars are in from UUC.....these guys ship so fast it's ridiculous.
        • Mike36
          • 1079
          #94
          In for updates.
          • 625incfab
            • Sep 2017
            • 2
            #95
            Ac would be no problem.
            • Fucatypr
              • Dec 2016
              • 108
              #96
              The next project will be this one owner 1993 850ci 6 speed. As of now the car runs great and has full service record from the dealer but it has a ton of mile so if/when it blows up, we won't feel bad about swapping it.
              As for the e30 swap, we are building a prototype kit to see how well it all works and how fast the swap can be done. We are now looking for a car to do the swap in now. We found a real POS slicktop that just might fit the build.
              • Sladek
                • May 2016
                • 228
                #97
                any new progress?
                • Wehudom
                  • 9
                  #98
                  I will literally buy another e30 and build it around the ability to purchase those already-fabricated "swap-kit parts"
                  Always wanted to set up an e30 like this.
                  Good luck with the work fellas!
                  • rturbo 930
                    • Dec 2005
                    • 2629
                    #99
                    Also interested in updates. I'd be curious to know how much of the swap process would be different if swapping a K24 instead of an F20C.
                    • Sladek
                      • May 2016
                      • 228
                      #100
                      I looked into this as I was thinking the same thing. itll take some oil pan/pickup tube work, an adapter plate for the trans, some wiring changes, some misc coolant line running and maybe some different engine mount arms.
                      look up the s2000 k swap procedure and you can kinda get an idea of what it takes. my plan was f20c swap and then start prepping for a kswap once that's up and running
                      • Jaker
                        • Oct 2013
                        • 234
                        #101
                        There's a K20 to BMW transmission adapter package available from KMiata.
                        I bought one for my E36 K20 swap with EFR7163. The quality of the pieces is fantastic. And this will make my swap so much easier than making a bunch of custom stuff. Pretty much all I need to fab are the 2 front motor mounts and the turbo manifold. OK, there's a lot more, but it'll be infinitely easier than trying to swap in the Honda trans too.
                        • vtechnik
                          • Jan 2018
                          • 379
                          #102
                          So glad I found this, sub'd
                          1988 ~ Lacey ~ 325iS
                          • Victell
                            • 1083
                            #103
                            Is there a build thread for your e36?
                            • Jaker
                              • Oct 2013
                              • 234
                              #104
                              Sorry. No. Though I really should start one.
                              • wazzu70
                                • Jan 2005
                                • 1143
                                #105
                                I dont see how this swap is going to suck :) Probably a lighter and more powerful swap than M42 for sure!!
                                -Nick
                                M42 on VEMS
