A 50 year old Japanesse lady: SRL311 01228
  • IRON-E
    • 16548
    #391
    Hopefully the new tech can help you sort out all the small gremlins keeping you from driving this thing till now. Your car looks really good in person too Simon.
    @IRON-E30 aka Edwin:D
    • 2mAn
      Señior Mod
      • 20973
      #392
      Thanks Ed, she definitely looks good sitting there, but its much sexier cruising around... need to drive ASAP
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • IronJoe
        • 2275
        #393
        Great progress Simon! I bet you're excited to get behind the wheel again.
        '89 Schwarz E30 M3 Cabriolet Build
        • 2mAn
          Señior Mod
          • 20973
          #394
          Thanks Aaron, cant wait to drive it. I think it will be driving this week, but theres also rain in the forecast later this week
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • 2mAn
            Señior Mod
            • 20973
            #395
            Well... the car is home, but it didnt come home the way I hoped. Im overall a bit disappointed with M's Factory. Miki did a decent job on the car, but ignoring the fact that the car wasnt driveable were the minor things he simply overlooked. On the other hand he did a decent job with some of the wiring I requested of him. The kill switch and the electric fuel pump are wired up nicely and function perfectly. so there's the positive side...
            Let me give you some pics to look at and then I will give you the bad news.
            The car is misfiring.
            He diagnosed it as a carb-related issue isolated to cylinder #2 and tonight I spent some time confirming that it is in fact cylinder #2, and that its NOT ignition related. That leaves the problem to be either air or fuel related. Being that I don't have a compression tester with me, I basically stopped there and dealt with the other minor things that he missed/ didn't do. I'm happy to hear her running again, but bummed that I still have work ahead of me, and I definitely didn't like the bill I was handed even though nothing really appeared outrageous other than the soft brakes. He replaced a leaky rear brake cylinder and then bled the system, so why the soft brakes still?.. Rest assured I will discuss that with him once I figure out this misfire... at the end of the month. Im going on vacation later this week and will be gone until the end of the month.
            Another month with no Roadster driving= sad Simon.
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • djjerme
              • 5082
              #396
              What’s the plug look like in two? It’ll give you a basic idea of what’s going on.. c’mon man, 50 year old cars require 50 year old diagnostics... Remember this old picture from Chiltons past: Could be a valve? Check the tail pipe when it’s running and warmed up - moisture? Does it smell like unburnt fuel.. Sent from my iPhone using Tapatalk
              2016 Ford Flex
              • 2mAn
                Señior Mod
                • 20973
                #397
                Well, had a nice little vacation and upon returning I jumped right back into it. Got myself a compression tester and ran the numbers. Glad to see they still look good.
                These are cold numbers with a dash of oil added in the spark plug hole
                #2 (This is the cylinder we are having the issues with)
                So with that looking good, theres a few theories running around but basically I discovered that over about 2500rpms it seems to really smooth out, so I said **** it, I want to drive it. But I had to deal with one issue that the car came home with, a super soft pedal. Rigged up something to hold the brake pedal down, and cracked the bleeder on the master cylinder and a bit of air came out followed by fluid so I closed her up and immediately had the brake pedal feel Im used to. OK lets do this!..
                It's far from 100% but man of man did I enjoy driving it around. I put about 10 miles on it, though likely less as the speedo is being turned by a 4.38 diff and the original 3.7 speedo gear. Regardless, when I had some open spots and could lay into it, all madness ensued ... in a good way. Felt good to drive it, but Im extremely excited for what 100% will feel like. Sadly, that means more money and more time parked as I am going to wait for the recommended man for the job, a gent by the name of Taka Soto whos about 60 miles away in Rancho Cucamonga. He's also booked into November, so unless I can find a way to tinker with it and solve what appears to be a pig rich mixture, and possibly a twisted throttle shaft, shes back in the garage. Maybe its time to put the hood back on now haha
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • rturbo 930
                  • Dec 2005
                  • 2625
                  #398
                  Kyusha House Taka?
                  • 2mAn
                    Señior Mod
                    • 20973
                    #399
                    Originally posted by rturbo 930
                    Kyusha House Taka?
                    Yup Edit: just spent the last hour checking out the dude and shop more. Whoa, finally seems like I’m getting the car in the right hands.
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • 2mAn
                      Señior Mod
                      • 20973
                      #400
                      I cant catch a break... car was supposed to go to Kyusha House Taka today after waiting a few weeks for an opening but then AAA screwed the pooch...
                      maybe I will get to drive it comfortably in December... for now she can move under her own power, but very unhappily. She got out of the garage waiting for her "uber" but the uber would never come... so she went back into the garage... ugh
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • MrBurgundy
                        R3V Degenerate
                        • Mar 2012
                        • 5597
                        #401
                        Car is looking good, Simon!
                        I thought you would be whipping this around by now.. Bummer.
                        I haven't read back too far, because I'm lazy, but you're just dealing with a misfire and soft brakes?
                        • 2mAn
                          Señior Mod
                          • 20973
                          #402
                          Thanks, I spent a few minutes cleaning the dust off and cleaning her while waiting for the tow truck, speaking to her nicely, but it wasnt meant to be...
                          I took care of the brakes, but the car is running super rich. The guy Im taking it to is an expert on Mikuni carbs so he will be correcting the tune. Car was supposed to be there by ~10am, but when it was nearly 2pm and they still hadnt picked up the car before its trek from Inglewood to Rancho Cucamonga the guy made me reschedule to Monday.
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • jeenyus
                            • Aug 2011
                            • 2064
                            #403
                            That's frustrating. Logistics can take anyone's sanity.
                            • Lenwood
                              • Mar 2012
                              • 100
                              #404
                              simon, i you are running dual solexes have you checked what type of jets you have? there are several different sizes. i had a 2000 roadster with that set up. running the b cam too? fun car when dialed in.
                              1989 325ix(sold)
                              1989 325i sedan s52 powa (current)
                              • MrBurgundy
                                R3V Degenerate
                                • Mar 2012
                                • 5597
                                #405
                                and finding a solid guy to tune carbs.
