Melon's E30 Build.
  • jeenyus
    • Aug 2011
    • 2064
    #181
    Originally posted by Melon
    Free literature.
    I love the internet.
    Sent from my Pixel 2 using Tapatalk
    I just saw this. Isn't the internet amazing?! I printed one off for the IX just the other day and it's been a huge help!
      • 34844
      #182
      I had my limiter set to 7500 on my M20 for years. Never had an issue.
      • Melon
        • Mar 2018
        • 1311
        #183
        Good to know, thanks.
        I do things.
        • Melon
          • Mar 2018
          • 1311
          #184
          Work hours are increasing, and had an AutoX Saturday, so I didn't get my full weekend
          Got the front suspension taken apart, getting ready to drop the subframe, and oil pan to finish up the engine.
          Painted the struts, installed the M3 offset bushings, and painted the lollipops. Painted the wheel wells.
          Got the heater pipes on the IHKS, waiting on a temp switch for Germany, which ECS said was I'm stock, sigh.
          I do things.
          • Melon
            • Mar 2018
            • 1311
            #185
            Shocks and springs installed.
            I'll install the new wheel hubs when they're on the car.
            New reinforced subframe from Garagastic, with new 2.7 lock to lock steering rack installed.
            I do things.
            • Melon
              • Mar 2018
              • 1311
              #186
              Subframe dropped and valve cover & spark plugs installed.
              I do things.
              • Melon
                • Mar 2018
                • 1311
                #187
                Orange seat belts from safetyrestore.com
                Painted the motor mounts, and the seat belt rails.
                I do things.
                • Jokester
                  • Sep 2016
                  • 1818
                  #188
                  What service did you choose from safetyrestore? How much did it cost you? Keep up the good work, loving the updates
                  • Melon
                    • Mar 2018
                    • 1311
                    #189
                    I emailed them and they told me to order (5) $75.00 services, and the fifth one covers the lap belts for the rear.
                    I do things.
                    • Melon
                      • Mar 2018
                      • 1311
                      #190
                      Installed the M3 cable tray, had to modify it a bit to work with the factory harness. Installed the IHKS. Found a great deal on a complete tool kit, so that went in.
                      I didn't order the two stoppers that go on the oil pump shaft, like a derp, so I got the windage tray installed, waiting on those to come in to finish up the bottom end.
                      I do things.
                      • Melon
                        • Mar 2018
                        • 1311
                        #191
                        Custom color labels.
                        I do things.
                        • 2mAn
                          SeƱior Mod
                          • 21017
                          #192
                          That is so cool
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • jeenyus
                            • Aug 2011
                            • 2064
                            #193
                            Right below the 17mm/19mm there is a plastic doohiky. My tray never had that. What is it and what is it used for?
                            • Melon
                              • Mar 2018
                              • 1311
                              #194
                              It's a tool that allow you use to crank the windows up and down if the motor fails.
                              It's one of the less-common items that I mad sure to find.
                              I do things.
                              • jeenyus
                                • Aug 2011
                                • 2064
                                #195
                                Interesting. I've honestly never seen that slot filled! Thanks mate
