Melon's E30 Build.
  • wworm
    • Dec 2016
    • 1719
    #331
    holy fuck
    1984 Delphin 318i 2 door
    • amcp
      • 489
      #332
      Erm? Thats not right.
      • Albie325
        • Jul 2016
        • 515
        #333
        Damn that seems like a lot of trouble, can't believe it took all that to get them out
        '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
        Albie325 Build Thread | Albie325 COTM Jan 2021
        • majdomo
          • Jun 2018
          • 449
          #334
          So...they got it out?
          Current flame: E30 318iS Alpinweiss II slicktop / LSD - Joanne
          The old man: 1970 2002 Polaris(ish) slicktop / rat rod - Wallace
          The ex: E92 335i 6MT M-Sport - Betty
          The heavy: 2001 4Runner SR5 Sport (3rd Gen) - Fred
            • 34839
            #335
            Fuuuuuu...... Man, this is the *one* job I've ever paid a shop to do on my E30. They had a rough ass time, and it wasn't cheap.. but I think they fucked you over. Don't let them replace that with some shitty $100 'Cardone' axle - even a 30 year old, 200k mile Lemforder is way better. Now you need a new axle, bearing, hub.. damnit.
            Also, definitely wet sand and cut that paint with a polisher. It's not hard to DIY with some instruction, and it makes a huge difference.
            • Melon
              • Mar 2018
              • 1311
              #336
              Yup, out it came.
              I have new GKN axles, new bearings, lock clip, the lot. I just needed the arms stripped down, reinforcement tabs welded on, and the axle pressed out.
              He was able to source a used hub locally too, so that's NBD.
              Right on, Once I get the car running and driving I'll look into it further.
              I have all the tools, 6" sanding discs, DA polisher (I know it takes longer, but it's possible) I'm just worried about cutting through the clear.
              I do things.
              • Pootis
                • 636
                #337
                I would have cut the axle shaft and just got a new arm personally.
                1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                • Melon
                  • Mar 2018
                  • 1311
                  #338
                  Right?!
                  I told him that had I known of what was involved, I would have just bought new ones.
                  I do things.
                  • rcarradine
                    • Sep 2012
                    • 31
                    #339
                    Sweet project. Looks great so far. Are you keeping track of your time by chance?
                    • Melon
                      • Mar 2018
                      • 1311
                      #340
                      I did some back of the envelope, I work on it about 25 hours a week, over a nine month period. About 900 man hours so far, will be about a thousand before it's all said and done.
                      I'm billed at $135/hr. by the firm I work at.
                      Dolla dolla bill y'all.
                      I do things.
                      • Jokester
                        • Sep 2016
                        • 1818
                        #341
                        What do you do for work?
                        • Melon
                          • Mar 2018
                          • 1311
                          #342
                          Civil/Structural Designer.
                          I work with engineers to design roadways, earthwork, railways, concrete and steel structures for oil & gas and petrochemical plants. Basically I do CAD stuff all day, 3D modeling, drafting, as well as survey.
                          I do things.
                          • Melon
                            • Mar 2018
                            • 1311
                            #343
                            Rear suspension parts painted!
                            So excited, these have been holding me up.
                            Sent from my Pixel 2 using Tapatalk
                            I do things.
                            • rjmcdermott81
                              • Oct 2014
                              • 565
                              #344
                              Dude...your build is epic. I'm wildly jealous of your orange color. I tried to go for Inka orange on my car but my PPG supplier said it was only available in the high-end basecoat ~1200 for a gallon!
                              I saw someone mention doing a cut/buff on your clearcoat and you said you only put two coats. I'm not a pro, I just painted my first car as well. But, what I did learn is sanding clearcoat is the most stressful part of the entire process and if you mess up it sucks horribly. I had 3 coats of clear and I sanded through on the back pillar, through the clear, and even started to see primer. Boom, had to re-color/clear the entire body because there aren't any breaks.
                              Car looks great and the detail you've put in is awesome.
                              Build Thread: Ryan's Hennarot 318is
                              COTM Aug 2019
                              • Melon
                                • Mar 2018
                                • 1311
                                #345
                                Thanks man!
                                Year that's my biggest fear with the paint.
                                I do things.
