My e30 Project... Mtech II sedan, Jlines, Vaders, M50 and much more...
  • motorsports_3
    • Mar 2007
    • 1058
    #226
    I put the guide coat on the first coat of primer, and it seemed to have been smooth. I hope I did everything right.
    Ill do both of them. That makes sense.
    Thank you.
    Originally posted by Sha1234
    BOTH!!!!!!!!!!!
    first block it... cause with that much primer you are going to be wavey.....
    THEN wetsand to get a nice smooth even surface....
    you should prob also throw on a thin layer of primer guide... or whatever you americans call it... my painters just call it primer or sanding guide... (thin layer of black paint from far away).... it will show you highs and lows... its the same as charcoal
    Tim
    • Sha1234
      • Jun 2006
      • 171
      #227
      you want to put the guide as the last step before base coat color... because even a single layer of primer can be too thick in ertain spots and you will end up with wavey panels... and that would be a big waste of time and money... cause you cant wet sand waves out
      • motorsports_3
        • Mar 2007
        • 1058
        #228
        Thank you. That makes perfect sense.
        • 240zs30
          • 583
          #229
          If you can, get the booth. You won't regret it. I know a couple of people that have done it in their garage and it gets pretty intense. The paint gets everywhere. The fumes will drive you insane. Your garage, tools and contents will be red until you paint it some other color. Keep up the good work! We need more e30's driving in FL.
          • motorsports_3
            • Mar 2007
            • 1058
            #230
            So today is quite a big update...
            I towed the car somewhere....
            Where do you think....
            Good enough answer?
            Wait... Is that paint?
            You bet...
            Paint before primer (base coat)
            Now I didnt take these pics, as I was painting, so I dont know where they fall into place. Some were the first, second and third coat of clear.
            Now I think these are pics of the completed car.
            • 240zs30
              • 583
              #231
              Great progress.
              • Sha1234
                • Jun 2006
                • 171
                #232
                ineed good progress... it looks like he sprayed dry... but dont sweat, thats better than to heavy... orange peel is MUCH easier to fix than a big ol Run is. but really it looks pretty sweet
                • motorsports_3
                  • Mar 2007
                  • 1058
                  #233
                  Thank you
                  Originally posted by 240zs30
                  Great progress.
                  • motorsports_3
                    • Mar 2007
                    • 1058
                    #234
                    It may be the pics. I think I sprayed to heavy. I ran in a few spots, and at the start I didnt plan to use a booth so I bought quick hardener. Because of that I kept putting on coats to try to make it shiney. The owner of the shop after seeing it, told me what I did wrong and we sanded the car down and repainted it today. It came out wa better when I bought the slow hardener.
                    • motorsports_3
                      • Mar 2007
                      • 1058
                      #235
                      So the hood had a lot of fisheye. I have spent the ladt two days trying to fix it. I tried numerous things
                      I tired to sand it smooth
                      Then wetsand it
                      So I used paint stripper
                      All stripped
                      Primer sealer
                      Filler applied
                      Removed the tape
                      In the sunlight
                      Look how smooth it is
                      • e30this
                        • 3580
                        #236
                        lookd great. Why you got super gap in your rear bumper?
                        • motorsports_3
                          • Mar 2007
                          • 1058
                          #237
                          Thanks, the gap is because I didnt mount the bumper. just put it in place to have more room in the garage.
                          • VAPORBLADE
                            • Sep 2006
                            • 1771
                            #238
                            How are you going to get the paint off your wheels/tires! lol. kidding.
                            '89 "is" = M technic II build mode.
                            • motorsports_3
                              • Mar 2007
                              • 1058
                              #239
                              I am planning on painting the tires black again ;)
                              • motorsports_3
                                • Mar 2007
                                • 1058
                                #240
                                Sorry for the lack of updates. I have been really busy lately with test after test.
                                I have a small update picture wise today.
                                I got the headliner put in
                                Mounted the m tech kit, and the finished pics of the hood.
                                The rear lip looks a bit odd on the sides. Its okay an OEM one is coming soon enough
                                Repainted the front bumpers, I have to add another coat tomorow.
                                Rear window in
                                Windsheild in
                                Going to sleep
