What did you do to your E30 today?
This is a sticky topic.
  • goldenE30
    • May 2014
    • 48
    #5596
    R134a conversion finished yesterday
    Replaced compressor and both lines, evaporator, expansion valve, condenser and receiver drier with new pressure switch!
    • TeXJ
      • 1914
      #5597
      Got this done last sat. Ebay long tubes, ebay 2.75" inlet dual 3" outlet exhaust, no cat
      1990 325is
      m52b28
      3.73lsd
      g260 (1987 325is 5spd tranny)
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5602
        #5598
        Front brakes and wanted to address a slight coolant leak at the TB. Turned out to be a project, of course.
        Two of the three screws broke off
        A little sandblasting
        Tried to torch it and use some vice grips to break it free, but that didn’t work out.
        Then, I ghetto welded a nut to the rest of the screw with brass
        Oh em geee, Yay!
        • 88BlackS-ETA
          • Mar 2013
          • 322
          #5599
          Passed state safety inspection and was emissions exempt again, only put on 1,064 miles over the last year sadly, so Im now at 108,613 miles. I plan on driving it like crazy this year but stay under 5,000 miles so Im emissions exempt.
          Feedback Thread
          • htseng
            • Sep 2009
            • 158
            #5600
            New shifter and ebrake leather boots. Oil and filter change
            • jgilber0
              • Nov 2016
              • 457
              #5601
              Changed fuel feed, return, and canister vent lines in the engine compartment. Lots of stuck hose clamps; took forever.
              Oil change with Castrol 20W50 and a Mann filter.
              Changed the oil level sender; stupid red LED still on in the overhead check panel after.
              Adjusted alternator belt tension.
              Somewhat frustrating day.
              Jon (OO=[][]=OO)
              1992 325ic white, stock with a 5-speed swap
              Palm Beach County
              • jgilber0
                • Nov 2016
                • 457
                #5602
                Even more annoying- tension on alternator belt is now too tight. Was too loose before.
                Jon (OO=[][]=OO)
                Palm Beach County
                • IRON-E
                  • 16548
                  #5603
                  Stared at it.
                  @IRON-E30 aka Edwin:D
                  • jgilber0
                    • Nov 2016
                    • 457
                    #5604
                    Progress!
                    Finally got the alternator belt tensioned properly.
                    Replaced the valve cover vent line - completely brittle. Broke on removal.
                    Replaced most of the vacuum line for the brake booster, resolving a leak at the check valve/intake boot junction. Ran out of good hose clamps – used some crappy old clamps lying around. Will replace later with nice OEM parts.
                    Idle is finally settling down into a nice cadence again as I eliminate the vacuum leaks.
                    Put my son in the front seat, drove to the gas station and filled up with a tank of 90 octane no-ethanol Shell.
                    On the way my low oil light finally went out in the indicator panel! Took about 5 miles for the new oil level sender to start working. Weird.
                    Jon (OO=[][]=OO)
                    Palm Beach County
                    • jeenyus
                      • Aug 2011
                      • 2064
                      #5605
                      That sounds normal to me. Generally take a few miles for the ECU to recheck some of that stuff. Glad you got it sorted.
                      • Staszek
                        • 2533
                        #5606
                        Disconnected almost all the last wires and hoses to prepare to pull the M20. Also removed the headers.
                        • jgilber0
                          • Nov 2016
                          • 457
                          #5607
                          Great - thank you - that is reassuring!
                          Jon (OO=[][]=OO)
                          Palm Beach County
                          • jgilber0
                            • Nov 2016
                            • 457
                            #5608
                            Stupid low oil LED on again. So annoying
                            Jon (OO=[][]=OO)
                            Palm Beach County
                            • Jparkr
                              HR Admin
                              • Jan 2006
                              • 3494
                              #5609
                              Downgraded the 325i to a 4 banger, Fired it up today.
                              1987 PRO-3 car /1990 325is (2.7i Concours)
                              • d_elson0
                                • Feb 2011
                                • 242
                                #5610
                                big downgrade....
