What did you do to your E30 today?
This is a sticky topic.
  • coldweatherblue
    • 393
    #5641
    Originally posted by Anthead
    Attempted to change the oil..after draining old oil I couldn't get the filter off so I had to buy filter pliers..
    Yesterday I also failed on the brakes and rotors replacement project... I couldn't get passed the first lug nut.....
    hey man, don't despair.
    The torque for E30 wheel-bolts (lugnuts) is like 90ft/lbs.
    Most road-side tire shops will torque it to 120+ risking stripping your wheel-bolts and also making it impossible to get your wheels off without a ***breaker bar*** which is what you need.
    Unfortunately this is a slippery slope and the next job may require a ton of more tools but that's what the E30 is about on a budget.
    • coldweatherblue
      • 393
      #5642
      Originally posted by Mazdayasna
      Damn that is a handsome car. Wheel specs?
      Thanks man.
      I like to think my car is classy but it started super cheap. Wheel specs are: Vogtland springs, ESM RS reps; 15x7 fronts, 15x8 rear, Yoko S-drive 205/55r15.
      Surprisingly I've never seen another car with the same specs although I'm sure they're out there as this is bare-bones e30 aftermarket.
      • Anthead
        • Sep 2018
        • 70
        #5643
        Originally posted by TeXJ
        find some local people to help mentor you. Ask questions here, and also check out youtube, tons of information there.
        We all started out as newbies. Don't feel bad, just chunk it up to growing pains. You'll get there.
        Thanks!
        • Anthead
          • Sep 2018
          • 70
          #5644
          Thanks for words and advice... I went out yesterday and got a breaker bar but it left everything on hold... I also had to get a new floor jack bc the one I originally bought (on stupid clearance for $3) was basically a little toy and didn't even lift the car high enough for the stands I had [emoji53]
          I def bought it to get back into stick driving and tinkering around, and I knew it was going to be more expensive bc it's an older BMW.. but it feels like things are just falling apart haha.. the other day my glovebox wouldn't stay shut, I got frustrated and slammed it closed and there it stayed.i had to unscrew it from the back and break off the latch which was on its last leg. I guess me slamming it either broke off something or loosened it up.
          One thing that got me real excited was when I successfully replaced the odometer gears.. except when I popped everything back in I noticed how the odometer is the ONLY thing that works on the cluster. I'm hoping it's just the SI batteries. And of course, from tapping on the cluster for the gas gauge the stupid needle for the tach fell off..
          At what point should I cut my losses and start over? Maybe just sell this one and buy another, cheaper E30? Lol
          • coldweatherblue
            • 393
            #5645
            Those are classic E30 issues that probably everyone on this forum has dealt with at some point.
            If you paid a lot for the car as you said, I would assume that the body/mechanicals are at least in decent shape?
            Sounds like maybe your car looks nice but wasn't properly maintained and was sold by someone to capitalize on E30s becoming classic. (just speculation).
            My car was the same way when I got it. Keeping these cars nice requires someone who is willing to get into fixing the little things that break on E30s over 30 years of use. I'm not talking a to the frame restoration, just things like replacing all the hoses, belts (timing belt especially) electrical components, bushings, suspension wear parts, etc.
            Your cluster probably needs to completely rebuilt by bavrest.com. Or you could roll the dice on an Ebay cluster and save $150 but probably end up with another broken cluster.
            Also you should start a thread for your car in this forum, post pics and people will help you fix specific issues as this is a separate thread. :)
            • moatilliatta
              • 6152
              #5646
              Cheaper E30
              That’s a good one!
              So about E46 and older... you should have to expect to replace anything that is common to fail. AND if replaced, expect to do it again.
              Most people just neglect them. “the cost of repair is more than the car”
              What? If they bought a $100000 car the expenses would be ok? :)
              But you got to enjoy and have fun with it. If not, it’s not for you and will just add the the stress of everything else!
              @Zakspeed_US
              • Staszek
                • 2533
                #5647
                Originally posted by moatilliatta
                Cheaper E30
                That’s a good one!
                Agreed, anything that is 10 years old or older needs pretty much every bushing changed as well as a host of other little things.
                I bit the bullet and just did it all on the E30, even new bolts on most of ths stuff.
                • jgilber0
                  • Nov 2016
                  • 457
                  #5648
                  Originally posted by Schnitzer318is
                  I only drive the vert once a week usually and put <1000 miles on it last year, but it was due for some love. ...Installed H&R springs,...
                  How do you like the ride with the new springs? Still comfortable over bumps? How about body roll improvement?
                  Thanks!
                  Jon (OO=[][]=OO)
                  1992 325ic white, stock with a 5-speed swap
                  Palm Beach County
                  • moatilliatta
                    • 6152
                    #5649
                    I love fresh hardware! Feels so complete.
                    @Zakspeed_US
                    • Anthead
                      • Sep 2018
                      • 70
                      #5650
                      Finally got the right tools in!! Finished changing the oil and got a new jack to lift the car up higher for my stands. With the time I had, I was able to change the rotor and brakes for my front driver side tire. When I have a chance I'll take a crack at the other 3.. with the experience from the first hopefully it won't take me as long.
                      I also removed that rotor/brake cover that goes behind the wheel.. it just looked terrible IMO.
                      • moatilliatta
                        • 6152
                        #5651
                        I Just snagged an E36 mirror, going to fit it to the E30.
                        @Zakspeed_US
                        • Schnitzer318is
                          • Jan 2008
                          • 2057
                          #5652
                          Thanks!
                          Honestly... it's hard to pin-point what changed what as I changed so much. It's probably very much a cumulative result. I can say it is WAY stiffer on the H&R sports w/ Billy HD's than the stock springs with the same struts.
                          ^That said, it's not uncomfortable by any means. Just very sport oriented. It handles incredibly now. I'm willing to sacrifice the soft ride for the handling it has now. Feels much more akin to my 318is coupe that was on billy sports and H&R sports. I do feel highway transitions and road turtles very obviously now though. My same setup with some 15" wheels and decent sidewall on the tires might be a more ideal setup if this was being daily (or even weekly) driven. But for what I use this car for... I am extremely pleased with the end result.
                          Complete suspension list for point of reference:
                          - Meyle CABs
                          - Lemforder CAs
                          - Meyle tie rods
                          - Lemforder sway bar end links
                          - OE sway bar bushings
                          - Meyle engine mounts
                          - Febi strut tower mounts
                          - E90 15mm drop hats
                          - ESM 002 16x8 wheels
                          - Maxxis 215/40/16 tires
                          - Garagistic sub frame X-brace
                          Let me know if you have any other questions.
                          "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                          91 318is Turbo Sold
                          87 325 Daily driver Sold
                          06 4.8is X5
                          06 Mtec X3
                          05 4.4i X5 Sold
                          92 325ic Sold & Re-purchased
                          90 325i Sold
                          97 328is Sold
                          01 323ci Sold
                          92 325i Sold
                          83 528e Totaled
                          98 328i Sold
                          93 325i Sold
                          • goldenE30
                            • May 2014
                            • 48
                            #5653
                            Finally got around to installing my apex arc 8’s 17x8 et 25
                            Michelin Pilot Sport A/S 3+ 215/45
                            Suspension spec:
                            H&R race
                            Bilstein sport shocks
                            E90 drop hats
                            Before 14in IS basketweaves
                            • TeXJ
                              • 1914
                              #5654
                              - Meyle CABs
                              - Lemforder CAs
                              - Meyle tie rods
                              Where in Texas are you?
                              1990 325is
                              m52b28
                              3.73lsd
                              g260 (1987 325is 5spd tranny)
                              • Schnitzer318is
                                • Jan 2008
                                • 2057
                                #5655
                                San Antonio, but I make it up to McKinney every so often. That's fairly close to Allen according to Google maps.
                                91 318is Turbo Sold
                                06 4.8is X5
                                06 Mtec X3
                                05 4.4i X5 Sold
                                90 325i Sold
                                97 328is Sold
                                01 323ci Sold
                                92 325i Sold
                                83 528e Totaled
                                98 328i Sold
                                93 325i Sold
