E30 M52B25tu S/C
  • tubby17s
    • Nov 2007
    • 85
    #136
    after finding out one of the rear calipers was stripped i got another one and bolted it on.
    Put some oil in and wound up the oil pressure to find i had missed covering up one of the holes that provides high pressure oil to the vanos unit. So Had to plug that up and oil pressure was reached.
    Then was next onto wiring.
    This is what it looked like in S50 Wiring style
    mounted the battery back in the boot where it started life origionally
    Then started pulling it down to bare requirements which a mate had helped me with.
    got it to this point
    filled her up with fluids and after a quick fix up with the haltech software this happened
    • Ray Smoodiver
      • Jun 2004
      • 8809
      #137
      Whoa what airbox is that!
      • tubby17s
        • Nov 2007
        • 85
        #138
        Custom made single layer carbon.
        • Iain
          • Oct 2005
          • 2815
          #139
          Get the pedal box sussed, Josh?
          Pork Hunt Motorsport
          eBay is like the summit racing catalog for today's special Olympics crowd
          • tubby17s
            • Nov 2007
            • 85
            #140
            Nope. not fully yet. Still deciding what to do with it. The angle is all wrong.
            so finished up the wiring in the engine bay.
            • Wh33lhop
              • 11705
              #141
              :up:
              paint sucks
              • Ray Smoodiver
                • Jun 2004
                • 8809
                #142
                I think that's the sexiest engine bay I've ever seen.
                • Reap3r
                  • 596
                  #143
                  Just stumbled across this thread. Absolutely perfect mate! Good to see more nice E30's in Australia. There just aren't enough around that are done right.
                  Turbo M42 Build thread:
                  http://www.r3vlimited.com/board/showthread.php?t=169672
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    #144
                    That is beautiful!! Nice work on pairing down the wiring too, I knew there was lots of extra but not that much!
                    • tubby17s
                      • Nov 2007
                      • 85
                      #145
                      Thanks guys.
                      Yeah there are a lot of useless wires when your using an aftermarket ECU. It will make it a lot easier to diagnose problems too (if i have any). Just have to make a aluminium board to mount everything on.
                      • Be30mer
                        • Jan 2010
                        • 1121
                        #146
                        Nice project! carbon airbox + euro s50 + possible turbo/supercharger = subscribed
                        You are lucky your Dad didn't pull out and leave you on the passenger side seat.
                        • e30guydownunder
                          • Jul 2008
                          • 874
                          #147
                          Originally posted by tubby17s
                          The calipers are skyline R32 GTR calipers with Supra MA61 discs
                          What thickness was the mount plate you made up for the rear, those rotors would be cheap as chips around here! And the skyline calipers aren't that exe either!
                          What are you running on the front? Skyline calipers with *insert name* rotors?
                          Must be getting awefully close now!
                          - Chris
                          Project M42 - 255 @ 19 psi
                          • tubby17s
                            • Nov 2007
                            • 85
                            #148
                            unfortunatly be30mer i will not be going turbo or supercharged at this point in time. As i have used up my allocated time frame to build my car. Have to concentrate on other things in life.
                            Chris
                            12mm thick plate milled down to 6mm at the ends. i have the drawing for you in CAD if you wish.
                            one thing i didnt count on with the rotor is that the rotor hat thickness is 3mm thinner than the E30 one. so on the hub it has a locating spigot for the disc and then goes down to another locating spigot for the wheel. currently the wheel when done up stops 3mm short of the disc... so im going to be running a 3mm spacer plate between the disc and the wheel. I have Studs on the front and still have 8 left over so will be putting 70mm long studs on the rear too and bolting the spacer down through the disc and onto the hub.
                            The rotors i got for free. The calipers were $140 for the pair.
                            on the front is Lee's Race big brake kit.
                            getting close. just need to finish off pedal box once i get the accelerator cable
                            • e30guydownunder
                              • Jul 2008
                              • 874
                              #149
                              Nice catch there on the hat thickness! What is the diameter of the Supra rotors?
                              Lee makes very nice kits!
                              - Chris
                              • tg318is
                                • Jun 2008
                                • 2052
                                #150
                                wow great build mate! the engine bay is bloody awesome
                                Tim.
