Ultimate budget build.
  • Danny
    • 14217
    #226
    Cool.
    I keep having trouble with the first charge pipe popping off that 90 deg silicone house.
    Bypass valve is holding up well though.
    • E30nate
      • Oct 2007
      • 1050
      #227
      i knew you would have trouble with those pipes. you need some with beads around the edges. you can try getting some t-bolt clamps, they usually hold better
      • Danny
        • 14217
        #228
        I put on a new clamp and put a layer of electrical tape on the outside of the pipe, so it grabs a little better, no problems now.
        • E30nate
          • Oct 2007
          • 1050
          #229
          cool. did you get those fittings ordered? im gonna put that seat in my car tomorrow, and then if i have time i will drill and tap that oil housing. or i will do it friday.
          • Danny
            • 14217
            #230
            Yeah I ordered them earlier this evening.
            Hopefully they are down here by saturday.
            And damn you and your junkyard treasures.
            • E30nate
              • Oct 2007
              • 1050
              #231
              lol. i know. that was a fucking score!
              • e30nub
                • Jun 2008
                • 1741
                #232
                So is this going to be reliable? If it's relatively reliable, I'm down to do this next!
                -Pierre
                1987 535is
                1988 325is
                • norwood e30
                  • Mar 2007
                  • 442
                  #233
                  nice job... sounds like a plan for the 318s.
                  • Danny
                    • 14217
                    #234
                    Well I've been blowing off charge pipes left and right because of the shitty ebay clamps, I have to get some better ones.
                    Once thats done though, should be plenty reliable.
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      #235
                      Originally posted by Danny
                      Oh and Sam/Nando, we took your advice and tapped into the oil pan, so don't be worried about the drain.
                      I don't get any credit for talking shit on your original oil drain plans?
                      • Danny
                        • 14217
                        #236
                        Sorry Farbin.
                        You too. ;)
                        • Danny
                          • 14217
                          #237
                          So, question.
                          After I boost for a while and then sit at a red light or a stop light or whatever, I get a check engine light. I'm assuming this is because my Ecu is freaking out because there was just a whole bunch of fuel in there and now there isn't.
                          Any insight?
                          • atomic
                            • Jun 2007
                            • 5691
                            #238
                            What are you running for engine management (sorry didn't read entire thread to see)?
                            • Danny
                              • 14217
                              #239
                              Stock Ecu
                              • SamE30e
                                • Sep 2007
                                • 4319
                                #240
                                Stock Ecu
                                That would do it.
                                It's probably an angry O2 sensor.
                                1985 325e 2.8 Turbo VEMS
