Japandrew73's OEM Euro Restore
This topic is closed.
  • Japandrew73
    • 2164
    #421
    Originally posted by e30edward
    You could try hot glue for the trunk lid liner. That's what i've used when i do some interior stuff. Always sticks no problem.
    also not a bad idea... I'll see what I can do
    • Japandrew73
      • 2164
      #422
      This is a bit of a boring update but it's progress. Took on the silicon gluing project, it was my first time working with silicon. I always heard to "bead it on" Well, I thought this meant make little beads like little balls and then spread it evenly. So I did that...
      Used the clips to hold it in place overnight with tape on each end of the clip so it wouldn't scratch the glass or freshly painted trim
      On the top it came out nicely, but I started to see it wasn't really glued properly. There was a gap between the trim and the side of the glass that isn't supposed to be there.
      So I took it all off and took on the project with the help of my Dad since laying silicon all the way around was hard to work quickly so as not to let it dry. Here's a hint to working with silicon, if you spray it with rubbing alcohol, it somewhat "runs back the timer" of how fast the silicon dries, not all the way, but it delays it a bit. So with spraying it with the rubbing alcohol and having my Dad's help on Father's Day we took off my crappy silicon job and did it the right way. I didn't realize bead meant a thick line.
      Then we wrapped twine around parts to be sure the trim adheres to the side of the glass
      Looking underneath it, you can see it's much tighter around the glass and has silicon seeping out. This may seem messy and unorganized, but it's better for it to be seeping and clean the excess off later, than to have it not adhere properly.
      That is sitting overnight to cure and a couple of days ago I took to stripping the top trim. It was twice as hard as stripping the bottom trim since it was bigger and had more difficult grooves to get into.
      Then I painted it, looks nice
      Tomorrow when the silicon from the bottom trim has cured I will silicon glue the top trim on and once that's done all I have to do is wait for my newly fabricated rails to come and I can epoxy them on!
      I did some experimenting with the sunroof today and understood how it works. All you do is unclip the headliner grommets and slide it back into the roof excess
      In this next pic you can see the rail just above the headliner panel. See how it stops half way through the sunroof edge? The moonroof rails don't stop, they go all the way back so the slider is secured down.
      Right now the slider will flop all over the place when far back
      But when further forward and under the rail, it stays secured down
      Then the sunroof is only held into place with 3 torx screws on each side
      Then it comes right out
      I carefully set the moonroof into place for a preview. It's going to look awesome
      You can see in this pic all that's missing is the brackets to attach and it will drop right into the car. Although it still needs the provisions for the slider panel. One thing at a time though
      Looking at the top of the headliner panel, it's old, the glue has stopped sticking and it's a bit worn with a small hole in it
      You can also see the rail's lip and where it stops but needs to go on for the moonroof. I should be able to find someone to fabricate a new one.
      At this point I had some good news and some bad news. The good news is I will be able to re-use me sunroof gaskets on the moonroof. I don't know why I didn't think of that before. It will save me a lot of money. The bad news is, being the idiot I am, I tore my headliner panel.
      BUT I need to take it out to integrate a handle for the slider, and it had a hole and was worn and slightly stained anyways. The entire headliner unit for the sunroof is cheaper than the gaskets were. So I'll be getting a new headliner unit for the moonroof, but I need to source some sort of handle for the slider...
      • etta325
        • 985
        #423
        very intersting man. I have to say this isthe most intersting thread i am subscribed to. I love the detail you put into it.
        keep up the good work.
        Check out my stuff for salehttp://www.r3vlimited.com/board/show...=1#post1600997
        anything you need I can find just shoot a PM
        • cepa318is
          • Mar 2008
          • 228
          #424
          time for a factory black headliner?
          • Japandrew73
            • 2164
            #425
            Nope, most people do this, but if I go black headliner, my car will be unbelievably hot, and it's too much black for me. I like the tan roof, it has class to it in my opinion. Almost everyone else will disagree though
            • eld4au6
              • Apr 2009
              • 99
              #426
              I agree, something about a nice gray vinyl headliner.
              BMWs: 73 2002 sold, 83 320is totaled, 90 325ic sold, 04 X3 2.5i sold, 00 323it
              Sveed: 82 Volvo 242 Turbo
              Jap: 01 Honda S2000, 95 Toyota Land Cruiser, 05 Subaru WRX STi
              • Japandrew73
                • 2164
                #427
                stupid photobucket fails me again. the pics will be back up again on the 3rd of july
                • Jparkr
                  HR Admin
                  • Jan 2006
                  • 3494
                  #428
                  1987 PRO-3 car /1990 325is (2.7i Concours)
                    • 37833
                    #429
                    pbucketpwnd
                    Grover Beach, California
                    BimmerHeads.com
                    • Mtriple
                      • 3139
                      #430
                      photobucket phail.
                      Originally posted by Simon S
                      • ikkitousen
                        • 386
                        #431
                        photo bucketed!
                        DAMN FREE SPACE COSTS TOO MUCH!!!
                        • TDE30
                          • 7042
                          #432
                          What the bucket?
                          - Trey
                          E90 325i/6 (ZSP, ZPP, ZCW)
                          E36 325i sedan
                          E30 325i sedan
                          Volvo 945T
                          • Jparkr
                            HR Admin
                            • Jan 2006
                            • 3494
                            #433
                            kicked the bucket...
                            • gazellebeigem3
                              • Jun 2005
                              • 3712
                              #434
                              my world literally stopped spinning. im not sure if ill make it till the third.
                              • ikkitousen
                                • 386
                                #435
                                OCD-dissorder withdrawls? Only cure for that is a Detail brush, mequires spray bottle and 15 strait hours in your car with a screwdriver a lint collector.
                                And if you find a golf pencil and couple of dust bunnies you can McGyver your way into a leathal weapon build thread...
                                :loco:
                                DAMN I HAVE NO IDEA WHERE THAT CAME FROM!!!
