1990 325is oem+ Now turbo (Video)
  • Vincenze
    • Apr 2019
    • 1028
    #136
    Do you know the part number for the dust shield for the flanges?
    Is it
    02 Dustcover plate 60X84X5 2 33131208006
    • mjweimer
      • Dec 2015
      • 648
      #137
      I know I'm not the OP....but 33 13 1 208 006 is the correct p/n for the dust shields. Unfortunately a bit spendy for some stamped metal.
      • Iloveboost
        • Sep 2019
        • 136
        #138
        Can’t remember the part number .. it sure is an easy find on realoem!
        as MJ said , kind of pricey for what it is ..!
        • Vincenze
          • Apr 2019
          • 1028
          #139
          It's very helpful to read topics like yours to find actual photos of parts and how to replace them using simple tools.
          • Iloveboost
            • Sep 2019
            • 136
            #140
            Engine rebuild going good . I am at a standpoint since the next step require the intake in place . But I don’t have any injector at the moment so I will wait to put back on the intake manifold . As you can see , the alternator didn’t receive any attention . I was not confident to take it apart .!
            • Iloveboost
              • Sep 2019
              • 136
              #141
              Little update , nothing much interesting but surely Some foward things! Take it apart the intake manifold I will need to modified the throttle body : -Built a block off plate for the coolant holes and the pcv tube -JB weld or real weld the elbow that are always loose on our TB -add another vaccum port for the vaccum distributor box I want to make. As every time , all this will be refresh ! I also start to pull the engine . Car on jack stand Pretty much is disconnected (electrical and mechanical) Maybe an hour of work Again and I will (try) to pull the engine off. First time for me , finger crossed haha !
              • Iloveboost
                • Sep 2019
                • 136
                #142
                Today I pull my first engine ever Everything has been pretty good. It is straightforward . Unconect things that is attached to the engine , then pull. Seriously , you don’t need spécial tool , except the engine hoist and engine leveler. Took me 5h hours from the time I stop the car in it’s place to the engine on the ground . I am happy , this is a big step for a man who never done this haha! Look what 30 years can do to an engine Now I have plenty of work ahead !
                • Iloveboost
                  • Sep 2019
                  • 136
                  #143
                  Today I start to cleaning parts I took off the old engine that I will need on the new ! Next, the dirty tranny -deep clean -fresh seal all around -fresh oil -fresh misc part
                  • McGyver
                    • 4634
                    #144
                    If you're going standalone, TREperformance has Siemens Deka IV 60lb injectors for ~$270 shipped for a set of 6:
                    https://treperformance.com/i-2061903...jectors-6.html
                    • Iloveboost
                      • Sep 2019
                      • 136
                      #145
                      I definitely go standalone !
                      already have in hand megasquirt pnp 2!
                      thanks for the input for the injector , but I already baught a set of Deka 60’ from ZZPerformance ( gm performance website) for 249$ For 6 !
                      pretty good deal too !
                      • McGyver
                        • 4634
                        #146
                        Damn, I shoulda shopped around more to save that extra $10.
                        Keep up the good work, I love the build!
                        • Iloveboost
                          • Sep 2019
                          • 136
                          #147
                          Damn, I shoulda shopped around more to save that extra $10. Keep up the good work, I love the build!
                          I already receive it , took less than a week. I am very pleased with the ZZPerformance website ! At first I was scared of buying fake one , but after further look and search they are genuine so , good deal from them !
                          • Iloveboost
                            • Sep 2019
                            • 136
                            #148
                            Little update for today ! I receive the new part for the ignition système -Bpr7es spark plug -bremi distributor cap -bosch rotor -bbt spark plus wire - the 2 coolant sensor I don’t wait any second and install them on the engine , and install to , temporary , the manifold and the turbo So good looking but .. I got an issue with the turbo and the spark plug wire . They touch the turbo housing and blanket + they will be very close to the downpipe .. At first I taught I can modify the manifold . To see how much I can play with it , I install the engine on the engine bay Then I realize i have 0 space to modify the manifold . It is close to the frame rail and will be at 1/2“ from the hood .. So , at the moment I’m working on a solution to push the spark plug wire toward the intake manifold . To be continued .. About the throttle body . I have delete the coolant pass in the throttle . For those who ever think about how the coolant pass in the TB . In fact , it doesn’t pass inside the TB , the coolant only touch it via little Chanel . I also remove the pcv return and weld the hole . Since I will run an catch can , I no longer need this port. I also make an block off Plate for the coolant pass . I also add a second port for extra vacuum source . Then the IAC elbow and the 2 vacuum elbow were loose and it is impossible to weld it to throttle since it’s not compatible . So I « cold weld » it with permatex stuff. Way way better than JB weld . To make it strong AF , I « cold weld » it in 2 step , first step was before push them into place , and second step was at the outside to make an « sandwich » with the glue . It is so strong . The only concern I have will be the longevity since the aluminium could expand/retract with all the heat .. time will tell ..! Little coat of paint to make look fresh Next will be the tranny cleaning ..!
                            • Glaede
                              • Oct 2007
                              • 138
                              #149
                              Looks really good! Enjoy following your project.
                              • Iloveboost
                                • Sep 2019
                                • 136
                                #150
                                Thanks ! I keep posting because I know there are peolple who like my build without commenting . Things have advance a little bit . Nothing big for an update but everything is so time consuming !... Finished to wash the tranny I wanted a better result but , I have give enough time to this transmission , it’s way better than before anyway ! All the seal were do 2 years ago so , except an oil change , no more work on it ! I also work on the engine bay . -remove the abs pump and line (will redo the brake line ) -remove all unnecessary braket -start to clean before the body work
