This makes me happy. The armrest is rather flaccid, so I think once I add some velcro and figure out a center mount rear seatbelt receptacle mounting location I will achieve the bliss I'm after
I've been laying low in hoopty land, but the behind the scenes escapades have been on brand.
I'm still mainly pretending OG hooptie doesn't exist because the exhaust hits everything and is way too loud. I aborted mission standalone and bought a MarkD chip for it along side some fresh 19.9lb @3bar rebuilt injectors from a volvo. Turns out Mark had a custom tune he made for a 10:1 hartge 2.7, close enough for me. Oddly enough, I found a 2.7 super eta squid chip for sale a couple days later at a nice price and secured that as well.
While pretending I don't own the car, however, the winter e30 daily itch re-inflamed. I still have the '87 325i sedan from the last couple pages, but it needed too much to get me stoked on fixing it.
Thankfully FB marketplace solved that problem, and revealed to me that an acquaintance a state over was downsizing his shop and selling off his shitboxes. An orange rust free early '85 coupe, which I'm a real sucker for, was on the chopping block, so I made the arrangements and it appeared before me, in all its glory.
The car was a supposed rust free, rough interior, mostly redone mechanically, m20b25 swapped, just needed some final engine stuff finished off before it would run/drive type of buy.
I apparently didn't learn from texas holdem and had the car delivered, and needless to say, the car is a pile.
I'm looking at it once it shows up. EVERYthing is spray painted. Under side of hood. Dash. Floor. Full exterior was treated to a glass out spray bomb. "bilsteins" are leaky Monroes. Whole arm fits thru rust hole in passenger rear wheel well. Drivers door ratchet strapped closed because door mech failed. Sadness. (Edit: I'd like to note here that I do not associate any fault with the seller. I had the car delivered, so it is my responsibility. Most of the description was passed on from the PO before him, so there were quite a few unknowns that weren't uncovered until I started poking around, unlike texas holdem, which was grossly misdescribed/untruthful, maybe we'll say, optimistic). Moving on.
Reality starts to set in. Start looking for silver lining. None found. Panic follows.
Turned to google sheets to neutralize the noise, and it informed me that I can make my money back with low sale price expectations.
All the sudden that '87 sedan wasn't looking so bad with a rolling parts pile parked behind it, so I got to work.
Hit the brake pedal in the '87 and the rear lines exploded everywhere. Lines so rusted I couldn't even get the fittings off above the gas tank because they went from 11mm to half 4mm and half 7.3mm wrench size. So I did the ole rust belt trick, and cut the rust off, flared the factory steel line (super fun on the car), bought a new ATE brake T, followed by a caliper side soft line to the hard drivers trailing arm line (which I also had to replace), and 10.5" of parts store NickelCopper hard line to the passenger side trailing arm line (which I also had to replace). Good enough for who its for
Untitled by bimmer
ugh
'87 sedan got the calipers/rotors/pads from the rotten orange. First round of lowering springs was a set of iX H&Rs. Found out the fronts are OE sports (50404.55), and the rears are slightly shorter iX springs with more spring rate. Around this time, a wire wheel plus mastercoat prolonged my spring perches and trailing arms, and I threw on some fresh rear endlinks. B8s on the rear.
Taxihoopty didn't like the rear iX springs, so I swapped on spray painted assumed normal H&R sports from the ole HIV30 with some iX spring pads I had handy. Still tall, but I'll play with spring pads later.
iX H&R after bouncing on the bumper for a while
Untitled by bimmertown, on Flickr
Some other H&R w/ iX thick lower spring pad
Front OE sport/ iX H&R Crossover discovery. Installed them with KYBs up front with some genuine USMs off of my buddies perfect 37k mile MT2 car. I had a 60k mile front sway/links/bush setup from the zionsville haul that I tossed on out of laziness around this time. Also installed new control arms with E36 centered rubber CABs.
In taking this picture I noticed several new leaks I'll have to get acquainted with. Also, the new control arms don't match. Tie rods had no play so they'll stay for now.
In all its glory (still at the old shop, landlord decided not to sell the building, so even though I have nothing over there, I'll keep my lift there until it's time to go)
Test fit some Equip 03 reps before I listed them on marketplace
And we'll finish it out with a local $250 sport seat score! '87 4dr has torn black leather comforts in it, so these were a half point buzzer shot
M3 is still in PA awaiting some sunroof headliner repair before it comes out so I saw the opportunity to fully default in the meantime.
That's all for now, folks.
Untitled by bimmerugh
Untitled by bimmertown, on FlickrSome other H&R w/ iX thick lower spring pad
Untitled by bimmertown, on FlickrFront OE sport/ iX H&R Crossover discovery. Installed them with KYBs up front with some genuine USMs off of my buddies perfect 37k mile MT2 car. I had a 60k mile front sway/links/bush setup from the zionsville haul that I tossed on out of laziness around this time. Also installed new control arms with E36 centered rubber CABs.
Untitled by bimmertown, on FlickrIn taking this picture I noticed several new leaks I'll have to get acquainted with. Also, the new control arms don't match. Tie rods had no play so they'll stay for now.
Untitled by bimmertown, on FlickrIn all its glory (still at the old shop, landlord decided not to sell the building, so even though I have nothing over there, I'll keep my lift there until it's time to go)
Untitled by bimmertown, on FlickrTest fit some Equip 03 reps before I listed them on marketplace
Untitled by bimmertown, on FlickrAnd we'll finish it out with a local $250 sport seat score! '87 4dr has torn black leather comforts in it, so these were a half point buzzer shot
Untitled by bimmertown, on FlickrM3 is still in PA awaiting some sunroof headliner repair before it comes out so I saw the opportunity to fully default in the meantime.
