Nonsense Thread
  • The Dark Side of Will
    • Jun 2010
    • 2796
    #12166
    Originally posted by ForcedFirebird
    W210/S210 E - from 1996-2002: E 200/K/CDI to E 320/CDI, 350/CGI, 400 CDI, 420 CDI - e430 Endurance Racecar build - Hello, My name is John and a friend of mine decided he wanted for my small performance shop to turn his e430 into an endurance race car. We plan on competing in Chumpcar Daytona, FL in May 2015. This will...
    Snazzy.
    I've discovered BenzWorld, which seems to be reasonably technical. I just "repaired" (cleaned with scotch brite and reassembled with anti-seize) the VNT linkage on my '05 CDI... That stopped the P0299 code and went from 23psi max MAP to >30psi max MAP... now it really feels like it puts me back in my seat as I would expect 370 ftlbs at 1800 RPM to do.
    • Northern
      I like cupcakes & sh!tboxes
      • 5284
      #12167
      well I threw a spare cluster in my car as I wait for SI batteries and an apsx naked wideband gauge. Somehow despite the SI batteries being even more dead, the tach on this one works fine, wtf.
      Coolant temp seems to stick at full cold and needs a dash smack even with the pins/ground cleaned so that's great.
      Also found out my heater valve is slowly leaking and soaking my carpet.
      Otherwise it runs well, I think I'm in the neighborhood of 400-440hp at ~9.5psi on stock CR M52 (which sounds high/not really possible) but I'm fighting a lot of knock that I really need to figure out. Might need to dial the boost back, but want to try new gas and verify ign timing first.
      Originally posted by priapism
      Originally posted by shameson
      • Melon
        • Mar 2018
        • 1311
        #12168
        I had mine re-done by Bav-Restoration, and the coolant temp does the same. Usually somewhere along any drive I hit a bump and that does the trick.
        Also, my tach needle is loose, has been since about a month after I got it back. I tried resetting it based on another cluster, but it's still off. I'll get it fixed one of these days.
        I do things.
        • ForcedFirebird
          • Feb 2007
          • 8300
          #12169
          Check the c191 under the intake manifold. ECU and gauge temp sensor run through it.
          john@m20guru.com
          Links:
          • Melon
            • Mar 2018
            • 1311
            #12170
            I don't have a connector there.
            I do things.
              • Jun 2010
              • 2796
              #12171
              I think this is where mine was:
              After (Note that I had not shrunk the shrink tube at this point):
              The dregs that I removed:
              • Melon
                • Mar 2018
                • 1311
                #12172
                Oh that's nasty.
                Mine appeared to be wrapped in the factory rubber sleeve, and was all the same girth.
                I'll double check it though, It always came up as a source of electrical problems.
                I do things.
                • 2mAn
                  SeƱior Mod
                  • 21085
                  #12173
                  I had a crazy starting issue thats source was that damn c191...
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • MrBurgundy
                    R3V Degenerate
                    • Mar 2012
                    • 5616
                    #12174
                    Dear god
                    Looks like a 16 yo kid tried to install a pioneer stereo underneath your intake.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #12175
                      People in Spec e30 love me in the starting grid. Can't tell you how many times a car wouldn't start, 10sec before we have to do the out lap. I pop the hood and wiggle the c191, run back to my car, strap in and go try to pass the dude.....
                      john@m20guru.com
                      Links:
                      • Northern
                        • 5284
                        #12176
                        Will that C191 butchery is heinous lol
                        No C191 here, just the cluster being weird I guess because a smack always does the trick.
                        I received my replacement SI batteries today, so I need to figure out how to attach the tabs to them, I'm guessing scuff/flux/solder extremely quickly with a very hot iron... maybe cooling the batteries in the fridge before...
                        Also I think my weird knock issue is from either my IAT sensor (placement or broken), or the stock IAT/CLT Compensation tables. Seem to run between 22-32degC IAT whenever part throttle cruising/bouts of throttle, which adds 6.4~9deg of timing to the base timing table.
                        Guess I'm sticking an M50 2-port intake boot on the car tomorrow to run two IAT sensors and compare logs, then likely redoing the two comp tables completely...
                        Click image for larger version  Name:	Stock IAT Comp.PNG Views:	0 Size:	36.4 KB ID:	9932377
                        I could zero out the 262 load column so it just doesn't add timing while in boost, but that effectively removes all functionality of the IAT at WOT, which would be nice to retain really.
                        • 2mAn
                          SeƱior Mod
                          • 21085
                          #12177
                          Wheres the build thread for this monster?
                          So, I havent gotten a haircut since this Covid lockdown started back in March. My hair is pretty damn long now... Each day it seems like Im getting closer and closer to my idols hairstyle. None other than Ace Ventura.
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • flyboyx
                            • 8371
                            #12178
                            ^lol.
                            the c191 is perhaps the culprit of about 70% of an e30's electrical problems. the throttle body coolant lines leak on that connector causing havoc.
                            Gigitty Gigitty!!!!
                            • LowR3V'in
                              • 4209
                              #12179
                              ya i was going to say the connector was the problem for when on no starts or cutting out at a red light
                              replacing vr sensor check grounds. couldn't figure it for a long time because the connector is so hidden
                              • E30 Wagen
                                • Jul 2005
                                • 3434
                                #12180
                                I just had the realization the term "baller" as applied to rich guys is a reference to professional basketball, baseball, etc, pros who make insane money.
                                My Feedback
