Intellectual engine questionnnnn...
  • slammin.e28
    שמע ישראל
    • 12054
    So, piston driven internal combustion engine.
    The question:
    The piston, at TDC or BDC, we can all agree it reverses direction, from up to down, or from down to up, right?
    Now, in the reversing of that direction, does the piston STOP, then go the opposite direction.
    Or by some black magic does it continue in motion in some uncanny oblong circle?
    Or, aliens?
    83
    Stop, then goes up.
    61.45%
    51
    Continues around and around.
    13.25%
    11
    Aliens.
    15.66%
    13
    Rob.
    9.64%
    8
  • travish325
    • Jun 2012
    • 1151
    Yes it stops, if only for a millionth of a second, But other pistons are at different points so you wont notice it.
    Can you go in reverse in your car while driving foward without stopping first?
    • slammin.e28
      שמע ישראל
      • 12054
      I have heard arguments for it continuing in motion, from engine builders, etc.
      I'm like whuut?
      • Wh33lhop
        • 11705
        Theoretically it stops, in practice it will tilt a little bit at the top/bottom of the stroke. It "remains in motion" because it's connected to the crank that remains in motion and it can only be stopped for an instant. But the piston itself stops.
        paint sucks
        • AndrewBird
          The Mad Scientist
          • 11898
          Well, it doesn't pause if that is what you are asking. It is at the top (or bottom) of the stroke the same amount of time it is in every other position throughout its stroke. While it might seem like it is stopping, it is still technically moving, just to a very small degree.
          Edit: To add further, it stops going one direction then instantly moves in the opposite, with no gap in time, No pause like I referred to earlier.
          • LJ851
            • 7919
            I've built a lot of engines and i think it stops. When you are finding absolute TDC when degreeing cams you can watch it stall momentarily, the crank turns and the dial indicator (on the piston) remains fixed. This is one of advantages of long rods, it increases the dwell time at TDC.
            Lorin
            The M30 is God's engine.
            • Wh33lhop
              • 11705
              If you are defining "stopping" to have zero vertical velocity then it stops. Just not for any period of time.
              paint sucks
              • F34R
                sLaughter
                • 12376
                I always believed the piston came to a hanging point that was cycled by the other pistons in motion.
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • LJ851
                  • 7919
                  How does that apply to single cylinder engines?
                  Lorin
                  • gtdragon980
                    • Jun 2008
                    • 1808
                    Shit, I got confused by the way you meant reverses direction. Now I get it. In that case, I voted wrong, I would say it stops for a fraction of a second, since the rod has to move from one side to the other, which then it pivots underneath before the crank begins to pull it back down.
                    FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                    Originally posted by scabzzzz
                    I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                    1989 325i - Project/weekend driver
                    2002 325i - DD
                    2005 Suzuki SV650 - Toy
                    • reelizmpro
                      • 9534
                      Well if you run in a given direction, you don't just reverse in the opposite direction without stopping momentarily. In the case of the piston, they may be including the circular swing of the force on the piston but the piston is kept pretty straight by the cylinder walls/rings with only a very very small gap in between but it still has to "stop" momentarily.
                      88 M3 - LACHSSILBER
                      89 M3 - ALPINEWEISS II
                      • ADlBOO
                        • 335
                        Single cylinder engines have counter weighted crank shafts that provide the momentum.
                        I have friends who are EOD bro.
                        That's awesome. I have friends who make coffee for a living, but you don't see me rocking out a bunch of lattes
                        • F34R
                          sLaughter
                          • 12376
                          Momentum created from combustion continues rotation is my best guess. So with the other pistons in multi cylinder engines it allows more hp generated from more pistons forcing rotation?
                          My best thought out logical response...
                          Current cars:
                          ~ '87 535
                          ~ '06 X5 4.8is
                          • LJ851
                            • 7919
                            Thats what flywheels are for.
                            The counter weighted cranks (on all engines that need them) is to achieve a balance factor for smooth running in a given rpm range.
                            Lorin
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              Okay, for clarification, let's say it's an M30 (tee hee). Multiple cylinders.
