Intellectual engine questionnnnn...
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    #46
    You have to stop going forward before you can go backwards.
    • evandael
      • Oct 2009
      • 2881
      #47
      i would figure that, in theory (no main/rod bearing/wrist pin slop), the piston will instantaneously stop as it reverses direction. it's velocity changes so it must, at one point, experience a velocity of 0.
      • fannman
        • Aug 2009
        • 231
        #48
        ^this. I believe people are putting more thought into this than is necessary. It is impossible for something to be in a upward or any direction, then without stopping even for a billionth of a second go into the opposite direction it was traveling. I understand the argument is there is some potential "side to side" play with the oil between the piston and the block, but that is such a small amount of travel it will still have to stop for and incredibly short time to change direction. Thats my t
        • TwoJ's
          • Oct 2005
          • 4908
          #49
          There are no forces acting on the rod/piston (from the crank) at bottom and top dead center.
          • pandaboo911
            • 2070
            #50
            if you're asking whether is stops moving in 1 dimension (parallel relative to the cylinder walls) then yes it does, even if only for an infinitely small duration of time
            • kronus
              • Apr 2008
              • 13031
              #51
              actually TDC and BDC are where the piston experiences the most force during crank rotation. F = ma, etc.
              cars beep boop
              • travish325
                • Jun 2012
                • 1151
                #52
                How many people saying the same thing does it take to get an answer. Holy crap
                • Wh33lhop
                  • 11705
                  #53
                  Pistons don't move in a perfect sine function due to rod angle variation so this may not be true depending on the rod ratio of the motor, but net force at tdc/bdc is definitely not zero.
                  The issue has been gone over a few times in the thread already, people just get hung up over the definition of "stopped.". Pick your definition and you have an answer.
                  paint sucks
                  • Holland
                    • Nov 2008
                    • 7178
                    #54
                    Why I walked away.
                    /thread
                    Originally posted by DEV0 E30
                    • Pac1373
                      • 1746
                      #55
                      I feel like this thread is only missing a picture of an aircraft on a treadmill at this point.
                      Originally Posted by ACMF74
                      i clicked on this cuz i saw p3nis
                      • E-Thirty
                        • 1331
                        #56
                        Even on a "roller based moving belt exercise apparatus"?
                        Exactly
                        Do you feel like something is trying to penetrate your butthole?
                        • Xat1cZ
                          • 2020
                          #57
                          Why do you guys always have to go and make EVERYTHING so fucking complicated!?
                          Does it stop? is that what you're saying? or does it only stop for 1 millisecond? or does it stop as in seize to move? or does it stop as in "fuck this I'm going this way" *brake* *goes other way*? or does it stop because the aliens push it in opposite direction? or is the stopping only an illusion?
                          look how fucking confused I am!!!
                          • frankenbeemer
                            • Sep 2009
                            • 2260
                            #58
                            Seems like by F=ma, the force must be zero at some point. Not that it matters. :twisted:
                            Don't buy an e30
                            They're stupid
                            1989 325is Raged on then sold.
                            1988 325 SETA 2DR Beaten to death, then parted.
                            1988 325 SETA 4DR Parted.
                            1990 325i Cabrio Daily'd, then stored 2 yrs ago.
                            • TwoJ's
                              • Oct 2005
                              • 4908
                              #59
                              Guys... come on guys.
                              Thank you for reminding us of Newton's second law. So in a sine-like wave form, TDC and BDC still have a derivitave of zero, yes? So what's the acceleration of an object with zero velocity? Mr. Newton's second law makes it pretty clear what the net force is when something isn't accelerating.
                              • LEANE30
                                • Apr 2006
                                • 838
                                #60
                                I fail to see anything in this thread yet that would constitute an "intellectual engine question". I am thoroughly disappointed, this thread fails. I had hopes for a topic like harmonic resonance tuning for ideal peak placements or something.
                                Rod ratio has nothing to do with the vertical loads placed on the piston at the wrist pin.
                                ...what hasn’t been done to an m20 yet?
                                m20 Oil Stencil
