Intellectual engine questionnnnn...
  • Jorgen
    • Aug 2011
    • 320
    #61
    Originally posted by Wh33lhop
    If you are defining "stopping" to have zero vertical velocity then it stops. Just not for any period of time.
    boom
    2011 JGC daily, 1985 944
    • Wergen7
      • Jun 2012
      • 255
      #62
      i'm saying theoretically it stops at the top and bottom for an infinitely small amount of time. basically immeasurable amount of time. but in practice, i would guess there is slight side to side motion in the cylinder because of the way a crank is and the rod being connected to that. so it is probably always in motion in some direction whether it be vertical or horizontal. its tough because a crank is circular and the piston is vertical. but the rod is like both depending on which side of it you're looking at
      http://www.r3vlimited.com/board/showthread.php?t=267166
      http://www.r3vlimited.com/board/showthread.php?t=380488
      • kronus
        • Apr 2008
        • 13032
        #63
        Originally posted by TwoJ's
        Guys... come on guys.
        Thank you for reminding us of Newton's second law. So in a sine-like wave form, TDC and BDC still have a derivitave of zero, yes? So what's the acceleration of an object with zero velocity? Mr. Newton's second law makes it pretty clear what the net force is when something isn't accelerating.
        well, no. if position = sin(t), velocity is δposition/δt = δ/δt sin(t) = cos(t). acceleration is δvelocity/δt = δ/δt cos(t) = -sin(t).
        if position is
        acceleration will be that wave flipped, with maxima and minima exactly where TDC and BDC occur in the position plot.
        cars beep boop
        • quickervicar
          • 1197
          #64
          Originally posted by LEANE30
          I fail to see anything in this thread yet that would constitute an "intellectual engine question". I am thoroughly disappointed, this thread fails.
          Does the piston actually exist? Or are we just imagining it existing because that is all we know of internal combustion? Can that same piston exist in two different cylinders at the same moment in time?
          • Wh33lhop
            • 11705
            #65
            Originally posted by frankenbeemer
            Seems like by F=ma, the force must be zero at some point. Not that it matters. :twisted:
            Acceleration is NOT velocity. You are confusing the two.
            You too.
            paint sucks
            • slammin.e28
              שמע ישראל
              • 12054
              #66
              Don't be close minded ya'll.
              I think I'm going to set myself to proving it doesn't stop....
              ....in my next life.
              • Wh33lhop
                • 11705
                #67
                I fail to see anything in this thread yet that would constitute an "intellectual engine question". I am thoroughly disappointed, this thread fails. I had hopes for a topic like harmonic resonance tuning for ideal peak placements or something.
                Sounds like you're way too smart for the rest of us.
                Rod ratio has nothing to do with the vertical loads placed on the piston at the wrist pin.
                Well, actually it does a little bit, since it will alter the piston's stroke pattern (smaller rod ratio will make the piston dwell more at tdc/bdc); however, that's not what I said.
                :rofl:
                paint sucks
                • ak-
                  • 12422
                  #68
                  Well Newton's laws are still technically considered theories.
                  So yeah, fuck everything!
                  1991 325iS turbo
                  • TwoJ's
                    • Oct 2005
                    • 4908
                    #69
                    You too.
                    Not confusing anything (ACTUALLY CONFUSING SIMPLE MATH). Did you take calc and/or physics in high school? Or 101 stuff in college? dv/dt= Acceleration. The slope of a tangent line of a velocity curve (dv/dt) is acceleration. So tell me, what is the slope of a line that is horizontal (TDC and BDC).
                    Again... not confusing anything. If V=0 (even just for an instant), then maths and physics tells us that acceleration is zero. And what is the net force of something that isn't accelerating? Zero.
                    So... when V=0 it follows that a=0. When A=0, it follows that F=0. Simple as that.
                    • kronus
                      • Apr 2008
                      • 13032
                      #70
                      Not confusing anything. Did you take calc and/or physics in high school? Or 101 stuff in college? dv/dt= Acceleration. The slope of a tangent line of a velocity curve (dv/dt) is acceleration. So tell me, what is the slope of a line that is horizontal (TDC and BDC).
                      velocity isn't horizontal at TDC and BDC, it's at the zero point, with a nonzero slope. read my post again, then read his post again.
                      cars beep boop
                      • TwoJ's
                        • Oct 2005
                        • 4908
                        #71
                        Easy there Descartes.
                        • TwoJ's
                          • Oct 2005
                          • 4908
                          #72
                          DERP, I'm retarded. All previous statements retracted.
                          • kronus
                            • Apr 2008
                            • 13032
                            #73
                            glad it clicked :)
                            cars beep boop
                            • ak-
                              • 12422
                              #74
                              Originally posted by twoj's
                              easy there descartes.
                              8)
                              1991 325iS turbo
                              • TwoJ's
                                • Oct 2005
                                • 4908
                                #75
                                My former teachers/professors would be embarrassed/disappointed.
