Video Series: E30 as fast as a modern G80 M3 CS?
  • 2mAn
    Señior Mod
    • 21065
    Just thought I would share this and see what they end up with...
    https://youtu.be/orJalvgERX0?si=BVLQFw2sIWI7nbXM​​​
    What do you guys think they will use for the engine?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • patrick88m3
    • Nov 2025
    • 54
    Gonna guess S54
    • varg
      Florida Turbo Man
      • May 2014
      • 3436
      I'm curious what he means by sticking to a budget, because if you're asking what drivetrain budget has a huge effect on what you'd use to do this because you could do it with a turbo M20 or an S65 and spend wildly different amounts of money. If I was just setting out to beat [insert new car] it I'd probably go for the E30's strength which is light weight and use a turbo K20 and a DCT.
      Hard to watch these over-produced and sound effect laden high dollar youtube videos though.
      IG @turbovarg
      '91 318is, M20 turbo
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5611
        Remember when Jason Cammisa's e30 325i with a eta bottom and some decent tires was one second behind a 2016 340i with a track package?
        The e30s greatest strength is the weight. It doesn't take a lot of tire or power to slingshot it around a track.
        The 4000lb g80 needs all the power to move it but the catch 22 is now it needs AWD to keep the rear tires from burning up.
        Anyways I think an e30 w an s54 swap and sticky tires will be on a bumper of a G80.
        They will basically have the same power to weight ratio. If you add a DCT to the e30 I think its going to take it for sure. Also with the NA s54 its going to be more forgiving than a turbo setup when you're getting out of a corner vs a turbo m20
        • FredK
          • 14763
          Well, in the comments they say the final curb weight of the finished product is 2950 lb. That is pretty heavy lol, unless they kept the stock interior and did no other mods to lighten the car up, OR, it speaks to a fairly heavy drivetrain, like an S65 and a DCT, which would be mega heavy and not even be altogether that powerful. That said, it's nice they're giving the E30 its due, but it is definitely an antique at this point, so it is light years behind in chassis stiffness, suspension design, track width, wheelbase, ABS system, ability to take on extremely meaty tires like 305s, etc. that would make it a modern track weapon.
          • DesertBMW
            • Aug 2011
            • 1043
            just another youtube guy making content just for the show, and I can see the guy is full of it
            • varg
              Florida Turbo Man
              • May 2014
              • 3436
              2950lb. A stock 4 door 325i is what, 2850? Probably an S54 then, those things are heavy. I wouldn't do an S54 because it would make the car more front heavy and they barely fit, but it's pretty obvious that I wouldn't do things the way a youtuber would.
              IG @turbovarg
              • 2mAn
                Señior Mod
                • 21065
                I agree with the consensus that the S54 is the choice, but also hate the imbalance they bring to the table...
                I recall when my 2350# Aluminum Monster with its 225whp regularly surprised many cars that weighed significantly more but felt their horsepower would embarass my car... and didnt.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5611
                  Cant this just be done in forza
                  • 2mAn
                    Señior Mod
                    • 21065
                    Whats forza?
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • FredK
                      • 14763
                      I think it's cool that this guy is doing a project like this to get his channel off the ground. The proof will be in the pudding with the lap times, and it's not going to happen without a big slug of power, tires, and probably aero. I don't think a 2950 lb E30 is a great place to be weight-wise, and I think it'd be tough to hang with a G80 M3 even with a 350whp S54. It is pretty easy to get an M20 car down to 2500 lbs with a cage and sunroof delete. It is an interesting conversation though, when you ask the question, "how can an E30 be built to compete with a G80 M3". I look forward to a tast of his skills.
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3436
                        I just looked at the power to weight ratio and yeah, 2950lbs is not a good place to be for an S54 car since
                        G80 M3 CS 3890lb/543hp = 7.16lb/hp
                        E30 2950lb/7.16lb/hp = 412hp
                        >400hp with an S54, forced induction required. At that point why use an S54? An S65 like you originally said FredK sounds more like a recipe for success there since it already makes over 400hp and is lighter than an S54. Of course I suppose it's possible to beat the M3's lap time without matching its power to weight ratio, but everything else would have to be on point to not lose too much ground on the straights.
                        I wonder what kind of lap time that driver would have achieved with a pretty basic build like mine, turbo M20, suspension, 200tw tires, which beats that M3 on power to weight with the boost turned up, but is traction limited and who am I kidding, would probably blow up on an all-out lap and run off due to brake fade if it didn't. And youtube doesn't like rusty almost stock looking E30s with shot black paint on cheap wheels.
                        IG @turbovarg
                        • FredK
                          • 14763
                          Well, the videos showed a 1:41.58 for the G80 and a 2:04.69 for the E30 at Utah Motorsports East. The E30 looked like it had junk tires on the bottlecaps it was rolling on, there was basically no turn-in at all. Given that I saw a video of a NASA TT3 E46 M3 lapping with a 1:38.16 at Utah Motorsports East not even using all of the track, I think an E30 could 100% do a 1:40 with an S54 and Hoosiers, nothing particularly special about the setup. I'm also pretty sure that the G80 with some suspension and tires could turn a mid 1:30 or better.
                          • FredK
                            • 14763
                            Well, project changed to start with an E30 M3 as a base, and at the end of the 2nd video, Chris Castro is seen explaining why the S54 core engine on a stand was no good. Could that just be a smokescreen where they then pivot to an N55? I don't know.
                            • MrBurgundy
                              R3V Degenerate
                              • Mar 2012
                              • 5611
                              Well, after the second episode it seems like they’re just going to go balls to the wall.
                              With moving to the M3, reinforced frame, widening the rear for phat tires and planning to do some moderate areo. I have no doubt they’re going to beat this G80 time lol.
                              I really wanted to see the 87 is get built in a way a like advanced DIYer could do at home and see how close it would get.
                              I mean sending a car to Castro and giving him a shitload of money is not as exciting
                              but yeah n54 or n55 would pretty much seal the deal lol
