Who Sells the Best Brake Duct Plates/Kits?
  • tinkerputzer
    • Jun 2008
    • 508
    I did some research awile back and found a lot of se30 guys saying bimmerworld's are the best.
    • djjerme
      • 5082
      Originally posted by redrocket328
      I have had great experiences with my brake cooling ducts when it comes to stopping power on track but havent noticed it to help with the cracking of my rotors.
      I run a SpecE30 and end up changing rotors every few weekends.
      This..
      If you track an E30, you're going to eat up rotors. Luckily, they are cheap. The stock brake setup is damn good at slowing down close to 3000 pounds of German steel from triple digit speeds, but it comes at a price, and that is chewing up rotors.
      Don't bother with more expensive rotors, you're just pissin' money away. Most racers just buy the cheap ones, and carry an extra set (at less than $100 for a front pair, it's one of the cheaper spares you probably have for an E30.)
      2016 Ford Flex
      • FLG
        • Sep 2011
        • 3165
        Last rotors i bought were like 15$ a piece, dont bother with the expensive stuff. Also Bimmerworld backing plates.
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • Lof8
          • Oct 2006
          • 2827
          I'll just reiterate that these aren't the stock e30 rotors I'm dealing with. These are 2-piece Wilwood rotors. The process to switch rotors on the hat isn't quite as simple as pulling a 1 piece rotor off the hub and chucking it in the trash.
          I think the HD Wilwood rotor has a better chance of being worth the investment than something in stock e30 fitment.
          S50'd
          Originally posted by TDE30
          What is this faggy shit I have happened upon?
          I can always live in a M3. Can't M3 a house.
          • Lof8
            • Oct 2006
            • 2827
            Originally posted by dsm2002
            Are these the Wilwood 11.75 x 1.25" 8x7" BCD rotors? Just to let you know there are possible alternatives. PFC, Hawk and AP racing all have rotors in this size. AP racing may not be suitable as the spigot diameter is 6.42" compared to Wilwood's 6.38". I am not sure about the PFCs or, Hawks.
            Wilwood's have a reputation for cracking. Some of their pre-bedded versions are better.
            I will look into this.
            S50'd
            • Northern
              I like cupcakes & sh!tboxes
              • 5237
              Not sure how Massive Sport Kit gets read as stock brakes.
              Originally posted by priapism
              Originally posted by shameson
              • tinkerputzer
                • Jun 2008
                • 508
                Getting 10-12 hours track time out of a $60 set of rotors seems pretty good to me. You could always try the HD's and if you find they aren't worth the extra money just switch back.
                • Lof8
                  • Oct 2006
                  • 2827
                  ^you're probably right. I would just prefer they last even longer. :)
                  S50'd
                  • Wanganstyle
                    • 2828
                    How much weight/power and how large speed differential corners do you have to deal with?
                    Perhaps just upgrading the rears would be enough? How long are your races? Or is this a hpde car
                    Sent from my iPhone using Tapatalk - now Free
                    • tytypetersen
                      • Mar 2012
                      • 347
                      PO had put these on my car.
                      • Fidhle007
                        I can fly, motherfucker
                        • Oct 2005
                        • 7209
                        Current word on the street with the E36 guys is not enough heat can be harder on rotors than too much. What pads are you running?
                        '89 325is S50 Track Montser
                        '04 X5 Daily/Tow Vehicle
                        http://www.avarestoration.com
                        http://www.myspace.com/brendanfiddle
                        Click here if you want to be my zombie slave...
                        http://www.youtube.com/user/Fidhle007
                        • TobyB
                          • 5261
                          How about water spray like the V8's used to run?
                          heh
                          t
                          • TobyB
                            • 5261
                            Oh, and I used the Mason Engineering plates. Shimmed them to get them a little closer,
                            but they fit well and work just fine.
                            t
                            • seatown88
                              • 331
                              What temperatures are your rotors reaching? If you don't know I would suggest putting some temperature indicating paint in the rotors to find out.
                              You could have a pad compound that is really hard on rotor. Ducting won't help.
                              You could have rotor rings with "poor" metallurgy. I doubt this is the case with massive. Ducting may or may not help.
                              Your rotor temps may be too high, as indicated by the temperature paint. In this case ducting may help. I say may because I'm still not convinced of the correlation between rotor cracking and ducting. My understanding is that the cyclic high temperature events cause the cracking and adding ducting will not change the delta.
                              Your rotor For an S50 swapped e30 10-12hrs of track time may be all you can get. I certainly applaud and understand trying to get more out of your equipment. The past two years I have been racing on a college student budget and needed to push my equipment life to the limit... sometimes not working out for me though haha.
                              • z31maniac
                                • 17566
                                Are they "cracking" or are the "heat checking?"
                                10 hours seems pretty poor either way. You don't drag the brakes do you? IE use them much longer than necessary?
                                I thought I was doing pretty well until a different instructor drove my car with me a few weeks ago, I saw how much further I could compress the braking zone.
                                www.gutenparts.com
