24V = smithereens after 50 hours of racing
  • redsubdivisions
    • Feb 2011
    • 1762
    #46
    Originally posted by whodwho
    nahh, got to go with hockey pucks - true Lemons style!!
    LOL wow. Reminds me of some of the bozos I used to hang out with in my 240 days..
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
    • whodwho
      • Jun 2008
      • 1547
      #47
      Hey now, it's old school!! and it passed tech inspection with a chuckle, they like seeing budget based solutions 8^)
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • Nisse Järnet
        • Aug 2013
        • 1221
        #48
        Vanos or non-vanos?
        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
        E30 M50 6 spd 764whp @ 24psi.
        E30 M20 6 spd 675whp.
        • mr2peak
          • 2388
          #49
          Early S50 head?
          Drive it hard. Maintain it well.
          A Topless Memorandum
          • pandaboo911
            • 2070
            #50
            I'm pretty sure that's because you were running it over 7k rpm. Not because bmw engines suck
            Also running any sort of rebuilt anything motor in a lemons car is total BS.
            People running 24v e30s with rebuilt heads are ruining lemons. At least karma caught up with you.
            • Wanganstyle
              • 2828
              #51
              I'm pretty sure it blew up because racing; Also blew up because lemons.
              Don't be too serious about lemons - keep your whistleblowing to yourself.
              6,000 rpm rev limit would have killed it eventually; M52b28 and M50b25 and S52b32 all run the same valve spring retainer part number 11341432453;
              the valve spring retainer is what failed and caused the valve to drop and have sex with piston #6.
              S50b30 and s52b32 both have a 7,000 rpm factory rev limit with these spring retainers (pn 11341432453).
              racing is all about cheating; my friends race a Porsche in lemons; they have a $7,000 engine in it. So what? I don't whine or even give a shit.
              People spend money on lemons because they want to have a good racing weekend - not because they are trying to make you feel bad-
              Our actual junkyard M52 with 0 new parts in the cylinder head and the block offends you?
              - junk lifters, junk pistons and original mystery rings/bearings/mystery oil pump
              - stock head surfaced and valves/seats ground with a basic valve job, original springs and retainers re-used. M52b28 parts
              - original vanos never re-sealed has given us 0 problems; we do have a mystery junkyard spare as well.
              engine swaps blow up just as much if not more than stock engines; they are NOT advantageous if one desires to win lemons; they are great for messing with people all over the track with.
              This was a mystery junkyard M52 that anyone can go to PNP and buy on half off day for lemons money - nothing special under the sun. If you wish to buy me a set of VAC motorsports billet rocker arms I will happily put a M20 back into the car and murder the same cars I pass with the 24V engine.
              We have held pole with engine output in the same car in the same races between 150-200rwhp; power doesn;t mean that much.
              Originally posted by Nisse Järnet
              Vanos or non-vanos?
              M52b28 stock longmotor with 0 mechanical modifications; vanos
              Originally posted by mr2peak
              Early S50 head?
              no; s50 is the ultimate hater its even worse for head gasket/ valve issues - more than one friend has dropped a valve - S50 is worse than S52 for valve dropping
              • Nisse Järnet
                • Aug 2013
                • 1221
                #52
                Ain't the vanos valve springs to weak for 7k? Valve float?
                • SmokeE30
                  • 1730
                  #53
                  A number of reputable tuners think 7k is safe on vanos engines although I doubt all vanos motors share the same springs.
                  Shawn @ Bimmerbuddies
                  Bimmerbuddies LLC
                  717-388-1256
                  2971a Roundtop Rd, Middletown PA 17057
                  bimmerbuddiesllc@gmail.com
                  • Wanganstyle
                    • 2828
                    #54
                    No valve float; the retainer simply cracked from racing stress over time
                    Some vanos engines come from bmw with 7,000 rpm redline. I.e. my daily driver 1998 m3
                    Valve springs did not fail; a much worse problem happened - the retainer split and valve keepers pulled through.
                    Part # 11341432453 - failure point @ 50 hours racing - it split and dropped the valve; collets pulled through. All m50 family engines use this valve spring retainer; even the s52/s50 USA
                    m52 and m50 use valve spring part #: 11347504268
                    4 bangers and S52/s50 USA / s62 share a different valve spring Part#: 11341403709 (VALVE SPRING)
                    E36 M3 Coupe
                    E36 318i Convertible
                    E39 M5 Sedan
                    if the spring was a stronger unit I wonder if the failure would have happened earlier or later; we need a DIGGER to answer this question
                    • Chris916
                      • 183
                      #55
                      We have about 75+ race hours on our 320,000km junkyard M50 motor in our ChumpCar... and It still has 200 compression across the board.
                      I have about 20 hours on my s52 in my e30 that has also never been opened and hasn't skipped a beat.
                      Sounds like you had a bad experience, but let's not bash the reliability of these well built motors.
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        #56
                        I think that should be the takeaway here.
                        Side note, what oil were you running prior to engine failure?
                        • Wanganstyle
                          • 2828
                          #57
                          If you are not running in our conditions it's not apples to apples.
                          For here 50 hours is actually quite durable
                          Blowing Up Is Just part of racing; Don't Feel Butt Hurt About it.
                          • whodwho
                            • Jun 2008
                            • 1547
                            #58
                            So here is something to lighten up the thread...
                            So we all know how they like BMW entries in lemons races... NOT! so we are going thru tech(bone stock high mileage stripped 87 325i 4dr sitting for 10 years)... judge Phil is checking out the car... he pushes down on the front fender... he says "Ohh Squishy... I like it!" with a big smile on his face!
                            We got teched, handed over our best refreshment stash got our bribed stencil 0 penalty laps and had a great time, placed 24th overall with switching out 5 drivers and 3 penalties(2 off track, 1 speeding on paddock) and that is what 24 hrs of Lemons is all about 8^)
                            NeoMaxiZoomDweebies - Rude Dog and the Dweebs theme - Button Turrible 2014
                            • Bullhead
                              • Sep 2014
                              • 532
                              #59
                              I don't race in Lemons but this is some good reading. From my stand point it seems the OP is just saying that solid motor mounts may not be the best solution, imo I have not heard him say BMW engines suck or are unreliable 1 time. I could be wrong and please correct me if I am OP. I am sub'd though this is some good stuff, and that Rabbit launch was intense, I would think even more so for the guy in the yellow car lol.
                              sigpic87 325E The Honey Badger
                              • jalopi
                                • 2370
                                #60
                                What I got was OP said
                                Beat the fuck out of a stock engine for 50 hours + 7k rpms + solid mounts = you're probably gonna have a bad time. I can agree with the solid mounts statement, never been a big fan of those. Also, I did alot of reading on a Ford forum about high RPMS killing blocks - pretty much everyone's consensus was that if you keep it at a max of 6k rpms the stock block will last much, much longer. So yep, gonna have to agree with the 7k thing too
                                IMO 50 hours isn't too bad though, that's way more than what some teams let their engines go before doing a rebuild. Then again, I'll bet they have a slightly higher budget than a lemons team
