24V = smithereens after 50 hours of racing
  • Wanganstyle
    • 2828
    #61
    Originally posted by jalopi
    What I got was OP said
    Beat the fuck out of a stock engine for 50 hours + 7k rpms + solid mounts = you're probably gonna have a bad time. I can agree with the solid mounts statement, never been a big fan of those. Also, I did alot of reading on a Ford forum about high RPMS killing blocks - pretty much everyone's consensus was that if you keep it at a max of 6k rpms the stock block will last much, much longer. So yep, gonna have to agree with the 7k thing too
    IMO 50 hours isn't too bad though, that's way more than what some teams let their engines go before doing a rebuild. Then again, I'll bet they have a
    slightly higher budget than a lemons team
    so cool you know how to read!
    much wow!
    7k killed our junk engine quicker than 6k would have - this is the communication yes! :)
    50 hours was actually pretty good for a junk m52 with no money put into it.
    Next engine will be limited to 6,000 rpm and hopefully we can make some delrin dampers for the solid mounts or a tubular pickup to prevent break down.
    Solid mounts is suxor but when u have a budget of $0 and they are $0 then its kinda self limiting............
    - lemons budget is pretty low; kaboom is normal. I don't understand why some r3vtards don't get it?
    you race lemons = will blow up
    • jalopi
      • 2370
      #62
      if $0 is the budget I'd see if you can't find hockey pucks as someone else mentioned - yeah they're pretty much solid, but IMO they're much better than literally solid aluminum/steel mounts
      if I don't sell/part-out my car/moneysink/POS I'll probably be getting some kind of r3v limiter for my junk.
      • Jb325is
        • 2137
        #63
        Somone asked about overrevs earlier, and you mentioned raising the stock rev-limiter but I think he meant missed down shifts. It's extremely common in "real racing" and co-drivers always seem to forget about mentioning it. I work with "real" race cars quite a bit and solid mounts should not be grenading your motor. One or two 5th to 2nd downshifts though and that's what you usually end up with
        - '88 m54 coupe
        <3
        • djjerme
          • 5082
          #64
          That's why many of the larger teams run data loggers, and have clauses in the contract for "Money shifting" and clutch dumping to decelerate. Had a buddy have to buy a Grand Am motor because he over rev'd by a couple hundred RPM - and the motor blew in the race. Doesn't matter what the cause was - he violated the contract, so had to buy it..
          2016 Ford Flex
          • Jb325is
            • 2137
            #65
            We put memory tachs in the trunks of our rental cars. And yes, I know someone who had a similar story with a one-weekend Grand Am ride. Ended up costing 20k
            - '88 m54 coupe
            <3
            • gazellebeigem3
              • Jun 2005
              • 3712
              #66
              Root cause analysis is for the birds. Obviously it just exploded because old and solid mounts. Not because it was mechanically over revved or "built" without a proper eye for details etc etc
              • Wanganstyle
                • 2828
                #67
                Real or not real race car the failure was observed by 6 human beings as the car was in in the air on the lift.
                The car was running just fine until it dropped a valve at 2,000 rpm with all 4 wheels in the air.....in neutral.
                No miss shift here. Clean stress failure of valve spring retainer
                I guess being Involved with a real race car makes reading comprehension difficult
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #68
                  Are you saying you have difficulty with reading comprehension? :P
                  Actually we discussed this engine earlier, and I was surprised it happened on a lift.
                  Where's my dog ears? ;)
                  john@m20guru.com
                  Links:
                  • Wanganstyle
                    • 2828
                    #69
                    Ya it was a shocker..thank god for kill switch in regulation position as I was in in the car and didn't want to hit any teammates in the eye w a broken rod.
                    I an on attack track this week to find those plates!
                    • LJ851
                      • 7919
                      #70
                      The fact that it finally gave out at 2k on a lift has no bearing on when the damage was done.
                      Lorin
                      The M30 is God's engine.
                      • Jb325is
                        • 2137
                        #71
                        ^This
                        Wangan you seem to be wealth of knowledge in some areas, but you also seem like a pretty massive douche, that's too bad. Don't limit your revs to 6k, that's a very stupid thing for an intelligent person to do. Put a memory tach in your race car, check it every now and then, you'll be surprised. Have a wonderful evening
                        - '88 m54 coupe
                        <3
                        • Northern
                          I like cupcakes & sh!tboxes
                          • 5253
                          #72
                          Originally posted by priapism
                          Originally posted by shameson
                          • Bullhead
                            • Sep 2014
                            • 532
                            #73
                            Yeah I have dropped a valve before in some of my sbc's at idle after a hard run (1/8th mile) and sense they are minimal clearance motors it makes a real mess. All it take is for one little bitty retainer to give up the ghost and you have yourself some piston spaghetti goodness.
                            sigpic87 325E The Honey Badger
                            • Wanganstyle
                              • 2828
                              #74
                              If one has spent any time at reading the context of LEMONS RACING then nothing needs to be said about lemons racing.
                              the "damage" was 50 hours of endurance racing - engine was just doing its job. Perhaps ask your favorite PAUL BURKE for his opinion?
                              valve retainer cracked but didn't split; collets pulled through; if this happened at 7,000+ or on a miss shift it would make alot of sense - but would have exploded on the spot.
                              I don't understand what is so interesting about the fact that it wore out; nor the massive amount of butthurt some r3vtards feel when shown what actual racing stress can do to an engine.
                              the valve spring retainers cost is $3.90 each on real OEM; not expensive - a non-lemons team would be best just buying new pieces x 24.
                              • LJ851
                                • 7919
                                #75
                                Your crystal ball must be better than mine. I have pulled apart multiple engines (racing and not) with cracked keepers that had not failed yet. Often there is a window of time between fracture and failure in my personal experience.
                                I don't give a shit about your shitty worn out junkyard motor in your shitty racecar on shitty solid mounts eating it's own shitty valves, it's you talking out your ass that's annoying.
                                Lorin
