Let's talk about track day brakes
  • berlow94
    • Jan 2013
    • 1063
    #76
    The noise is definitely confidence inspiring.
    I run 17x8 Apex arc8's. With 235 Toyo Proxe rr's.
    15's and 16's won't fit over these brakes.
    Thanks!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
    • djjerme
      • 5082
      #77
      Something to consider:
      Rotor cost vs Pads.
      With racing, I would happily sacrifice rotors over pads. Rotors are something like $13 a pop vs $300 for pads. You can eat a lot of rotors in a season of PRO3 before it becomes cost prohibitive..
      Unless you are one of those people who still think drilled rotors are Racecar! ;)
      2016 Ford Flex
      • HennaE30
        • Apr 2014
        • 1965
        #78
        Rotor cost vs Pads.
        Where are you getting $13 rotors? I paid twice that for mine, and they were duralasts
        Originally posted by flyboyx
        how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
        Originally posted by Northern
        beer is my new liver cleanse.
        Henna - '84 Hennarot 325e
        Lola - '89 Schwarz 325is - being saved
        Christine - '88 Schwarz 325is - Spec E30 Racecar
        '01 White F150 Lariat 4x4 Supercrew - Daily
        Dad's '05 Interlagosblau M3
        • JGood
          • Jan 2004
          • 7959
          #79
          Rockauto has a pretty good selection of $12-$20 rotors, but any of the cheap online parts stores (partsgeek, autopartswarehouse, etc...) will have cheap rotors. I always just order from whoever is cheapest at the time.
          I run the $13 rotors on our Lemons car as well as on my v8 e30. I have over 250k miles on a few sets of those cheap rotors over the past 15 years, never had any issues with any of them.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • HennaE30
            • Apr 2014
            • 1965
            #80
            Hm. What make are these cheap rotors usually? Just out of curiosity.. I'll definitely look around again when it's time to do rotors on either of my E30s
            • JGood
              • Jan 2004
              • 7959
              #81
              Pronto, Centric, Wagner , etc...
              They're all G3000 grade castings, so they'll all work the same for most of us. If it was a $100k race car, I'd opt for one of the pricey discs...
              • HennaE30
                • Apr 2014
                • 1965
                #82
                Good info.
                Sticky worthy thread?
                • TobyB
                  • 5287
                  #83
                  Ironically, the more expensive Brembos tend to crack early and often on racey cars...
                  t
                  • agent
                    Vice Grand Pubaa
                    • 7960
                    #84
                    Yep. Here's one of the front (Brembo) rotors off the E30 I drove at the VIR 24 earlier this month. That one had to get changed in the pits, then the other one a couple hours later.
                    The pads were PFC 08s.
                    Originally posted by kronus
                    • TobyB
                      • 5287
                      #85
                      ...and yet the $13 rotors seem to last for at least 2 sets of pads, if you're a cheapskate...
                      t
                      • 328ijunkie
                        • May 2007
                        • 3961
                        #86
                        Figured it would chime in here with the beaters experience. I have run HT10, PFC08 and DTC60s. The DTC60s are the only ones that remain consistant no matter what till theyre gone. I lynch rotors on a daily basis at the track though no matter the brand. I have cooling ducts. At the end of the day its a problem of overall grip. Im running 205 star specs and the tires after a few laps are done under braking and i am forced to annilate them to get the damn car to stop. Im running consistant 145s at RA. Best time a 1:43.8
                        I am forced to go 5 lug now. I bet if i had stickies or 225s up front it wouldnt destroy the brakes as bad but i like beating up on people with more power and tire with my little turd ;)
                        Was sessioning my college roomates car while he chased me in mine and he had HP+s. Didnt end well. His car is basically same as mine but GC coilovers and FBO alum M52.
                        Left 10A at 110mph and pulled ebrake. If anyone here knows Road Atlanta i made it all the way to the bridge before i stopped :(.
                        Plenty of pad, just lit them on fire. Wheel wells went up in flames after caliper piston popped out.
                        Caused 3500 in damage and i didnt even hit anything technically :(
                        Check Us out on Facebook
                        Full Product Line Tuning
                        • Skafrog
                          • 1732
                          #87
                          Dave, I dont know what your overall plans are, but I have run massive brakes for 3+ years on my 4 lug setup without any complaints. I used to burn through pads and rotors like you, and now I can go 15+ weekends on a set of pads and rotors, and thats turning 1:40s at RA in a swapped e30 like yours. Very cost effective.
                          NASA MidSouth TT Director / GTS2 #018
                          Mods: Coastal PS Fluid, 10w40 Oil
                          Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                          • 328ijunkie
                            • May 2007
                            • 3961
                            #88
                            Massive != UUC right?
                            Whats the cost like? I would love to stay 4 lug, just getting pretty tired of not being able to stop.
                            • TobyB
                              • 5287
                              #89
                              Massive = Lee. He makes a lot of adaptors and such to use off- the- shelf parts.
                              t
                              • Skafrog
                                • 1732
                                #90
                                They are pretty expensive once you get into the race kits. But the replacement parts (rotors/seals/etc) are really cheap. I love the life span of the pads, but the wilwood calipers flex quite a bit and cause the pads to wear uneven. And yeah sorry, I mean massive brakes.
                                If you are planning on redoing your suspension at some point and dont have a lot of wheels / tires accumulated yet, I think that e36/e46 stuff makes more sense. But in my case, I had too much invested in my 4 lug setup to make a switch.
                                Either way, not upgrading to a proper BBK is false economy. You end up spending more in the long run. I made my investment back within 3 years when I look at how much I used to spend on consumables vs what I spend now.
