Let's talk about track day brakes
  • Cephas
    • Apr 2012
    • 878
    #91
    Originally posted by 328ijunkie
    Plenty of pad, just lit them on fire. Wheel wells went up in flames after caliper piston popped out.
    That's crazy!
    Isn't it physically impossible for the piston to pop out unless the rotor shatters?
    • 328ijunkie
      • May 2007
      • 3961
      #92
      Originally posted by Skafrog
      They are pretty expensive once you get into the race kits. But the replacement parts (rotors/seals/etc) are really cheap. I love the life span of the pads, but the wilwood calipers flex quite a bit and cause the pads to wear uneven. And yeah sorry, I mean massive brakes.
      If you are planning on redoing your suspension at some point and dont have a lot of wheels / tires accumulated yet, I think that e36/e46 stuff makes more sense. But in my case, I had too much invested in my 4 lug setup to make a switch.
      Either way, not upgrading to a proper BBK is false economy. You end up spending more in the long run. I made my investment back within 3 years when I look at how much I used to spend on consumables vs what I spend now.
      How is pedal feel? I still love the feel of stock calipers (no matter the size). Every BBK weve ever installed in a customer car ive hated. Also i worry that the wilwoods will do the same stuff the UUC calipers have been plauged with no?
      Originally posted by Cephas
      That's crazy!
      or you bend a pad in half :(
      Check Us out on Facebook
      Full Product Line Tuning
      • TobyB
        • 5268
        #93
        I woulda thunk so. But once you unbolted the caliper, I could see it
        getting pulled out by a pad that's been mauled like that.
        You'd have to really stand on the pedal to get it to do that much damage...
        t
        • 328ijunkie
          • May 2007
          • 3961
          #94
          When you're doing 140+ and the brakes basically quit, you'll be pumping and standing on them too!
          • Cephas
            • Apr 2012
            • 878
            #95
            Yeah, that's a situation I hope to never be in!
            • kingston
              • Jun 2010
              • 2669
              #96
              I run the 300mm Massive Brakes 'Sport kit in the front of my track car. I went to an E30 M3 master cylinder and was much happier with the pedal feel afterwards.
              Originally posted by LJ851
              kingston is the play by play announcer for this thread.
              ‘Tis by the grace of God that my cars run!
              Originally posted by unloadedak
              #teamross
              Siobhan's Build Thread - UPDATED!
              • 2mAn
                Señior Mod
                • 20851
                #97
                Im jealous...
                Simon
                Current Cars:
                -1966 Lotus Elan
                -1986 German Car
                -2006 Volkswagen Jetta TDI
                Make R3V Great Again -2020
                • djjerme
                  • 5082
                  #98
                  If you had a E28, you could use them as well.
                  2016 Ford Flex
                  • 2mAn
                    Señior Mod
                    • 20851
                    #99
                    Is there a better OEM brake caliper? Girling or ATE? I want to rebuild a set of calipers and want to build the right ones
                    Simon
                    Current Cars:
                    -1966 Lotus Elan
                    -1986 German Car
                    • tinkerputzer
                      • Jun 2008
                      • 508
                      #100
                      Iirc ATE's have brass bushings which seems to be what most track guys prefer. I think they're a little more rare though.
                      • HennaE30
                        • Apr 2014
                        • 1965
                        #101
                        Negative. Brass bushings are an upgrade for the ATEs. The performance advantage between the two are so small it makes no difference.
                        Originally posted by flyboyx
                        how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                        Originally posted by Northern
                        beer is my new liver cleanse.
                        Henna - '84 Hennarot 325e
                        Lola - '89 Schwarz 325is - being saved
                        Christine - '88 Schwarz 325is - Spec E30 Racecar
                        '01 White F150 Lariat 4x4 Supercrew - Daily
                        Dad's '05 Interlagosblau M3
