40 buck brake duct kit
  • p0cket penguins
    • Jul 2008
    • 481
    Originally posted by asubimmer
    I didn't say the car way going to take off like an airplane. But more air under the car does increase lift. Which on the track means snap understeer, oversteer, or traction in general, etc...
    using this logic you can assume that taking an IS lip off the car will cause the same phenomenon...... but i digress.... the duct are what they are and if you dont like them... thats ok ... its still a 40 dollar upgrade over the stock ones which fall out during track events....
    • scabzzzz
      Estado de mierda de encargo
      • 6871
      Id rather see plates designed to hold the duct in place, but I really cant see it hurting anything. If anything, it will just be barely efficient.
      • 2002maniac
        • 4260
        asubimmer, you crack me up! I cant beleive you are college educated.
        With his brake setup he'll never ever ever experience fade unless he runs street pads or something. With or without ducting.
        • Need4Speed
          • Jul 2008
          • 95
          These work http://www.r3vlimited.com/board/showthread.php?t=110742
          • p0cket penguins
            • Jul 2008
            • 481
            Originally posted by Need4Speed
            yes but they are also 7.125 times more expensive prior to shipping
            • p0cket penguins
              • Jul 2008
              • 481
              exact setup ..... but mine is closer to the center
              • p0cket penguins
                • Jul 2008
                • 481
                post 32 .... similar setup
                • kishg
                  • Sep 2006
                  • 2624
                  sheesh what a pointless argument. yes, having a backing plate probably is more efficient. not having one will not automatically cause your car to fly off the track due the "lift" generated and cause massive death and destruction either..
                  '12 F30 328i Sport Line
                  '91 SpecE30 #523
                  '00 Ford F-350 Dually Tow Vehicle
                  BMWCCA #360858 NASA #
                  128290
                  • n2bimmer
                    • Dec 2008
                    • 359
                    does anyone have a picture for the mounting plate that goes on the strut, tnx.
                    • Fidhle007
                      I can fly, motherfucker
                      • Oct 2005
                      • 7209
                      The lift argument is not entirely invalid but most of you with M20s will rarely ever see the kind of speeds where it becomes a factor.
                      '89 325is S50 Track Montser
                      '04 X5 Daily/Tow Vehicle
                      http://www.avarestoration.com
                      http://www.myspace.com/brendanfiddle
                      Click here if you want to be my zombie slave...
                      http://www.youtube.com/user/Fidhle007
                      • p0cket penguins
                        • Jul 2008
                        • 481
                        im not sure that even on a high speed track that i will do over 150... but there is an e36 m3 over at bimmerforums that has done 160 with a similar setup... so i think the ducting is sound
                        • Optimator
                          • 1396
                          Excuse me, asubimmer, what was your major while in college? I am thinking communications. That explains why your oral skills are matchless.
                          -OVULATOR (as named by jflip2002)
                          Past Cars: Schwarz 1990 325i-2 (crashed), Calypsorot 1991 325i-2 Sport (rear ended)
                          Now: Blake-stitched mediocrity :(
                          • asubimmer
                            • 6482
                            business managment.
                            and once again, I didn't say that having the hoses like that will make your car take off. But adding air under the car is never good. If you don't understand how a wing works then maybe its time to go back a few grades. A sedan will never have downforce, but you want to do all you can to reduce lift.
                            • p0cket penguins
                              • Jul 2008
                              • 481
                              business managment.
                              well you should add a front lip and is splitter on your car ... so the car will stay planted still i digress.... i just decided to put pics up incase anyone wanted to replicate a ducting kit at the fraction of the cost.
                              • asubimmer
                                • 6482
                                My car doesn't have anything on the front right now. I'm getting a SP1 BMP front bumper ready to go on the car for now. Its replacing the plastic bumper w/ an 87' 325is air dam. Although I'll prob get rid of it in a while. But yes on the track you want your lip/splitter as close to the ground as possible.
