10:5 CR and CA pump gas?
  • vWBIRDWv
    • Jan 2016
    • 43
    anyone running high cr on pump gas here in california and not having any problems with pinging or detonation or should i get a thick ass gasket and try to bring it down a little?
  • Chilezen
    I weld cats
    • Dec 2013
    • 1942
    Depends on the engine and engine management. A stock E36 with an M52B28 runs at 10.5:1 on 91 gas.
    Currently building a badass coffee table
    Random stuff on insta @kevanromero
    • packratbimmer
      • Dec 2009
      • 1335
      There is a pretty elevated brain trust operating here - please provide more info and I bet you will get some better feedback. What are you running? Engine type, fuel management, chip, induction, cam, and etc.
      • Chilezen
        I weld cats
        • Dec 2013
        • 1942
        Honestly this would be better asked in the engine subforum, not the CA subforum. "California gas" isn't the issue here.
        • vWBIRDWv
          • Jan 2016
          • 43
          m52b28 crank 130mm rods 10:4 OEM bmw pistons with the I style quench zones
          • McGyver
            • 4636
            Yeah, this is an "m20" question, not a "California" question. Putting it in the correct location would get ForcedFirebird or Digger to give you an answer (or tell you to search).
            M20 section: https://www.r3vlimited.com/board/for...drivetrain/m20
            • bmwman91
              • Oct 2004
              • 3134
              The 2.1L M42 that Metric Mechanic built me has static compression of 11.5:1. I run it on 91 octane pump gas and have had zero pinging after years of revving it up to 7500RPM. This was the case both with a bone stock M42 tune, and a very much optimized custom tune from Sssquid. The compression ratio and gas are probably secondary factors after your ignition timing and fuel trims.
              Transaction Feedback: LINK
              • vWBIRDWv
                • Jan 2016
                • 43
                Forced Fire bird is the one building my engine
